Old 06-01-2013, 01:31 AM   #126
WelDun1
Member#: 249130
1999 Ver5 STi RA
Originally Posted by Devilteg View Post
Yeah i'm with you I got the red/pink ones just haven't mounted them yet. Make sure when you move the pedal mount that you measure the distance from the top of dash I'm off by a half inch going to heat up and bend it into place. save yourself some headaches.
Thanx for the heads up!
WelDun1 is offline   Reply With Quote
Old 06-01-2013, 02:08 AM   #127
az ru
Member#: 342436
sweet build !!!!!!!!!!!!!
az ru is offline   Reply With Quote
Old 06-03-2013, 03:54 PM   #128
Rexinre
Member#: 153652
2006 STi
WRB on Gold
Wow... That is a ton of work. Good luck brother.
Rexinre is offline   Reply With Quote
Old 06-04-2013, 10:33 AM   #129
Devilteg
Member#: 127545
2013 XV
Dark Gray Metallic
The break down wasn't bad but the rebuild process has taken a lot longer then anticipated but its been a learning exercise that's for sure
Devilteg is offline   Reply With Quote
Old 06-04-2013, 10:39 AM   #130
brutnus
Member#: 257195
2004 WRX
2.1L 12k miles strong
Subed. Love this project.
brutnus is offline   Reply With Quote
Old 06-04-2013, 01:29 PM   #131
Devilteg
Member#: 127545
2013 XV
Dark Gray Metallic
[quote=WelDun1;39703660]
Update 12/20/2012
Sending these for powder
What size are the stock Type-R sway bars?
I don't know the diameter of the stock but these bars are think as $hit compared to the OEM bars I removed on the RS
Old 06-04-2013, 02:40 PM   #132
WelDun1
Member#: 249130
1999 Ver5 STi RA
No doubt. The bars that I took off of my L were no thicker than the hood stand thing. Lol
Old 06-14-2013, 10:41 AM   #133
Devilteg
Member#: 127545
2013 XV
Dark Gray Metallic
Circumstances outside my control this project may be for sale. PM with questions will list for sale in proper section.
Old 06-14-2013, 03:41 PM   #134
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
1998 Forester, lifted.
Damn, sorry to hear.
Everything OK?
Old 06-15-2013, 02:20 AM   #135
peter3147
Member#: 223510
2003 WRX Wagon
Midnight Black Pearl
Oh man Aaron,
Hope everythings alright, I was actually going to call you this weekend, I was going to be up in Maine and wanted to come by and see how things were going.
peter3147 is offline   Reply With Quote
Old 06-28-2013, 12:26 PM   #136
Devilteg
Member#: 127545
2013 XV
Dark Gray Metallic
Everything OK?
Yeah I'm good just some bumps in the road... I live to fight another day. good news is I'll keep working on the car but looks like shes going to go to another member to enjoy. I believe he intends to keep the thread going until completion hopefully I can build another one once I get back on track learned a lot turning my own wrenches on this build.
Take care
AB
Old 06-28-2013, 12:28 PM   #137
Devilteg
Member#: 127545
2013 XV
Dark Gray Metallic
Originally Posted by peter3147 View Post
Oh man Aaron,
Im good Pete how you doing man long time no see
Old 06-29-2013, 01:07 AM   #138
peter3147
Member#: 223510
2003 WRX Wagon
I've been better; my RS spun a bearing so shes just sitting in the garage until I can figure out what I'm going to do. Currently trying to find another RS short block to swap in to keep the cost low.
I'm up in Maine for what looks like the summer as of now, We should meet up one night and catch up.
Old 07-01-2013, 02:39 PM   #139
Devilteg
Member#: 127545
2013 XV
Dark Gray Metallic
Mine may still be sitting a sailsbury auto salvage that's where I scrapped it
Old 07-03-2013, 03:05 AM   #140
WelDun1
Member#: 249130
1999 Ver5 STi RA
So its all sold huh!?! Word
Old 07-04-2013, 07:26 PM   #141
Devilteg
Member#: 127545
2013 XV
Dark Gray Metallic
It's pending currently
Old 07-05-2013, 01:07 AM   #142
peter3147
Member#: 223510
2003 WRX Wagon
I want to see it once more before its gone. It was such a sick build.
Old 07-07-2013, 01:57 AM   #143
WelDun1
Member#: 249130
1999 Ver5 STi RA
So when it comes to swapping the pedals over, do I have to fabricate a bracket to mount the brake pedal? Or should I cut the braket that its already mounted on and weld it on the other side?
Old 07-08-2013, 11:42 AM   #144
Devilteg
Member#: 127545
2013 XV
Dark Gray Metallic
You shouldn't have to fabricate anything Ill take a few close up pictures and email them to you. keep up the good work!
Old 07-08-2013, 03:21 PM   #145
WelDun1
Member#: 249130
1999 Ver5 STi RA
The brake pedal is mounted with 4 bolts to the firewall, and then another 2 bolts mounted up top on a bracket that's spot welded to the upper part of the firewall right above the steering column. Since that bracket is spot welded to the firewall, I'm guna have to either make another or drill out the spot welds and relocate it to the right side
Old 07-08-2013, 05:04 PM   #146
Devilteg
Member#: 127545
2013 XV
Dark Gray Metallic
Yes post #120 3rd or fourth picture shows the relocated pedal mount, brake pedal and gas pedal are on one bracket they mouth with a 12mm bolt up high and the brake booster has threads that connect to the back of the pedal assembly that go through the 4 holes in the firewall.
Old 07-10-2013, 09:08 PM   #147
WrxInfantryGuy
Member#: 313306
2007 WRX
very cool
WrxInfantryGuy is offline   Reply With Quote
Old 07-11-2013, 04:14 PM   #148
Devilteg
Member#: 127545
2013 XV
Dark Gray Metallic
Just got a call from the powder coater 5 months later my parts are done parts back from powder better pics forth coming
Old 07-12-2013, 12:21 PM   #149
Devilteg
Member#: 127545
2013 XV
Dark Gray Metallic
well worth the wait!
Old 07-17-2013, 03:09 PM   #150
Devilteg
Member#: 127545
2013 XV
Dark Gray Metallic
Mocked up the two strut bars to make sure they still fit having changed the front and rear end links we appear to be ok so far.
shade of pink is a little off from the STI parts but a little road dirt they will all look the same
