South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 09-14-2012, 10:02 PM   #1
03.dub.r.x
Member#: 307997
1996 Impreza
Glacier White (230)
Default Little Help Please
My right side is squeeking. when i press the break at low speeds. also ebrake light tends to light on and off
03.dub.r.x is offline   Reply With Quote
Old 09-14-2012, 11:32 PM   #2
FastS2k
Member#: 59577
04 fxt notansti
s2000 reallynotthatfast
"Ebrake" light could be low brake fluid, check it. Squeak could be time for new pads or maybe a rock caught in the pad.
FastS2k is offline   Reply With Quote
Old 09-14-2012, 11:42 PM   #3
WRX357
Member#: 224249
2002 Subiworx built/
Soulless tuned Bugeye
You need a new set of pre owned modded injectors. That'll fix just about any problem on your wrx including the current problem you're having. And you're in luck, I just happen to have a set..
WRX357 is offline   Reply With Quote
Old 09-14-2012, 11:48 PM   #4
03.dub.r.x
Member#: 307997
1996 Impreza
Glacier White (230)
thanks S2K but thats odd only on 1 wheel?
hey jared you should stop by and i think ur ryte
Old 09-14-2012, 11:53 PM   #5
FastS2k
Member#: 59577
04 fxt notansti
Brake pads can wear at different rates depending on the situation. You could have a sticking caliper or like I said, a rock somewhere in the brake system. It is only squeaking when you brake right?
Old 09-15-2012, 12:04 AM   #6
03.dub.r.x
Member#: 307997
1996 Impreza
Glacier White (230)
yeah man or when im going really slow
Old 09-15-2012, 12:11 AM   #7
FastS2k
Member#: 59577
04 fxt notansti
Did you check the fluid yet? Could also explain the brake light. As your pads wear, the calipers adjust and the fluid lowers.
Old 09-15-2012, 01:56 AM   #8
03.dub.r.x
Member#: 307997
1996 Impreza
Glacier White (230)
was the pads sor thanks man
Old 09-15-2012, 01:59 AM   #9
WRX357
Member#: 224249
I could help you replace pads if you need it.
Old 09-15-2012, 02:01 AM   #10
03.dub.r.x
Member#: 307997
1996 Impreza
Glacier White (230)
come on over and bring those injectors im feelin fortunate tonight
Old 09-15-2012, 09:09 AM   #11
WRX357
Member#: 224249
Dang. I freakin passed out after I wrote that last post.
