Old 09-06-2002, 04:12 AM   #1
Mazdryk
Member#: 23873
2003 wrx sedan
black
Default Turboxs UTEC Pros/Cons ?
IS the Turboxs UTEC the best at what it does and what i am looking for? I want one device to control my boost levels duty cycles of injectors air/fuel ratios. Will i need a seperate boost controller with this device? Can it handle over 20 psi of boost level? Is there any other possible electronics that i will need or does this thing cover them all? If it is the best why? or why not? Im not worried about not knowing how to use it im sure i can learn.
Mazdryk is offline   Reply With Quote
Old 09-06-2002, 04:16 AM   #2
mlambert
Member#: 13831
from what ive heard the UTEC handles boost great...A/F isnt a problem and the cool thing is that it properly handles timing where you want it to.
mlambert is offline   Reply With Quote
Old 09-06-2002, 08:30 AM   #3
jesse370
Member#: 12147
2005 g-35
ivory pearl
you should really go read the while utec thread before you get flamed. Every question you asked in answered in there and then some. Yes it controls boost, it is rock solid at what you set it at. It will allow you to tune every aspect of your engine if you choose to do that. It will come with there stage maps loaded in stock.
jesse370 is offline   Reply With Quote
Old 09-06-2002, 08:56 AM   #4
Ryan23
Member#: 15116
2000 Ver6 STi Type-R
EJ257/GT35R
As noted by Jesse, I'd recommend (re)reading the Utec thread above. You do not need a seperate boost controller. I am running 20 PSI on the stock solenoid, Phil is running 22 (at the track) on it, and Jorge has run everything from 14~19 I believe. It works and it's accurate. No need to drop money on extras. That's why my EBC went up for sale. Yes the Utec will do fuel/timing management as wellb (provided you know what you are doing). A better suggestion would be to get it tuned, on a dyno. It's worth every penny.
Ryan
Ryan23 is offline   Reply With Quote
TurboXS UTEC and TurboXS Tuner Pro medrad_man Engine/Power/Exhaust 8 03-26-2009 01:40 PM
CHEAP: TurboXS Tuner Pro, 04' TurboXS UTEC blitzs2000 Engine/Power/Exhaust 4 08-27-2008 11:40 PM
FS: TurboXS UTEC w/ Tuna Pro kingston Private 'For Sale' Classifieds 25 07-20-2006 09:39 AM
COBB AccessPORT, StreetTUNER & PRO TUNER SERVICES FOR COBB, TurboXS Utecs- IN STOCK P&L Motorsports Inc. Engine/Power/Exhaust 20 11-15-2005 10:51 AM
TurboXS Type H BOV - pros/con UU AR EX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-07-2001 07:18 AM
