Old 09-15-2012, 03:59 PM   #1
GriffinW
Member#: 223081
2003 Wrx
Default 02-03 JDM v7 HID Headlight Install w/ LightWerkz Harness
Just did this in my 03 and couldn't find a complete start to finish write up, so here's my shot at it.
The previous owner installed some Non-HID v7's with a terribly wired retro fit as you will see. I picked up some HID's from a member here and a lightwerkz harness.
v7's:
OEM Ballasts:
Lightwerkz (LW) "JDM STi Wiring Harness" HID for OEM Ballasts:
-(2)Black and Yellow connectors go to High Beam on Lamp
-(2)Black Oval-ish connectors go to factory head light plugs
-(1)Red Eyelet to Positive Battery Terminal
-(1)Black Eyelet Ground to side of fender (Or where ever works best for you)
-(2 sets of 2)Black and Red female disconnects to ballast pigtail
Remove those headlights: how-to
Remove the battery and plastic air induction piece
Now you should see what we are working with, unfortunately my case was a bit different. Check out the previous owners "wiring skills". This nonsense was found throughout the install.
Lets move on,
Drivers Side:
This side is going to use the large portion of the harness, take the black oval connector and plug it into the existing factory headlamp plug. Again, thanks to the previous wiring job, this plug was cut off by the last owner and I had to splice the wires. Therefore I dont have a picture of that for you.
Next, Connect the black eyelet to the ground located on the drivers side fender
Now on to the ballast, Remove the ballast and plugs from the black plate that they are attached to. You will see 4 plugs: two plugged into the ballast, one white 3 pronged triangular plug and a grey plug with two wires (black and blue with white stripe) coming out of it and cut off. These 2 wires connect to the pair of black and red female disconnects on the Lightwerkz harness. NOT the long ones, those are to be ran to the passenger lamp.
Black to Black and Red to Blue/White Stripe
Passenger side is Black to Black and Red to Red/Blue Stripe
These
To These
Now you can either crimp male connectors onto those two wires coming from the ballast or, do as I did and cut the female ends off the LW harness and connect with a butt connector. Either way, connect the wires from the ballast to the pair of black and red female disconnects on the LW harness.
You may notice a small ground wire that was attached to the ballast mounting plate, for safe measure I extended this and grounded it to the fender with the black eyelet.
Now with the lamp still out of the car, run the other two female disconnects to the other side of the engine bay.
Put the Drivers side light into place good enough so it will hold itself in position but don't bolt it in.
Next connect the white three pronged triangular connector from the ballast to its match coming from the lamp.
Like So
Now you can attach the Yellow and Black Plug to the High Beams on the Lamp.
This
To This
Lastly for the drivers side connect to factory plug for the running lights into the connector on the new lamp.
For the Passenger side do the exact same thing with the remaining plugs on the harness
Once you finish that, bolt the lights in place and tidy up your wiring. Place the ballasts in spots where they wont move around.
The final step is to put your battery back in and connect the red eyelet from the harness to your positive battery terminal.
Enjoy the JDM goodness.
GriffinW is offline   Reply With Quote
Old 09-17-2012, 10:32 AM   #2
car_freak85
Member#: 13530
EA63 , EA81T, EG33,
EJ205
I'm really happy that you posted this when you did! I have a set of HIDs on the way and was trying to find a nice, condensed, pic-filled write-up. Thank you so much!
I plan on doing the LHD conversion on my lamps, along with the electronic leveling motor, and I would like to link to this thread once I create that how-to.
car_freak85 is offline   Reply With Quote
Old 12-09-2012, 01:12 AM   #3
novotny99
Member#: 339692
2003 WRX
This is great. I just ordered the same HIDs and harness. Do you have photos of the passenger side wires? Pics after install!!!?
novotny99 is offline   Reply With Quote
Old 12-17-2012, 09:19 PM   #4
2002Dubx
Member#: 177337
1 Dirty Old
Bugeye and an Xterra
I just got my jdm hid headlights in. I've never installed hid's before but obviously my bugeye didn't come with them. Do I need a plug and play kit or just cut wires and match accordingly? I can't believe there isn't a sticky on this *#%^.
2002Dubx is offline   Reply With Quote
Old 12-17-2012, 09:46 PM   #5
2002Dubx
Member#: 177337
1 Dirty Old
http://www.flickr.com/x/t/0091009/ph...dd/8283206906/
This is what it came with,
Old 01-02-2013, 10:57 PM   #6
jpmoto2928
Member#: 323058
so im looking at all of this and how dose the low beams turn on or off I see its pluged to the batt wouldent that make it always stay on I no im missin something hear can someone tell me what thank you
jpmoto2928 is offline   Reply With Quote
Old 01-02-2013, 11:48 PM   #7
novotny99
Member#: 339692
2003 WRX
Look into wire harness from lightwerkz.com and if your not going to swap the reflector plates they will do it for you or do a TSX Retrofit.
Old 02-19-2013, 03:50 PM   #8
jdmjack
Member#: 248430
2003 PSM Bugeye
Anyone know the answer for this? Is a plug n play harness needed or can you hook it up without one? I think the high beams may be an issue without a harness
jdmjack is offline   Reply With Quote
Old 02-19-2013, 03:54 PM   #9
2002Dubx
Member#: 177337
1 Dirty Old
I hard wired everything and I do have an issue with no high beams. I am going to rewire it all one day but for now it can stay the way it is. Somehow daytime running lights (previously disabled) keep going on and off when the lights aren't on at all.
Old 02-19-2013, 04:14 PM   #10
jdmjack
Member#: 248430
2003 PSM Bugeye
Damn I was afraid you'd say that....looks like I need to get a harness
Old 02-19-2013, 04:35 PM   #11
2002Dubx
Member#: 177337
1 Dirty Old
Please do!
Old 02-21-2013, 10:39 AM   #12
jdmjack
Member#: 248430
2003 PSM Bugeye
2002dubx what method did you use to disable your DRLs?
Old 02-21-2013, 10:54 AM   #13
2002Dubx
Member#: 177337
1 Dirty Old
I unplugged the connector. When we ran the new wiring, I think my buddy grabbed it and connected that again. Now my lights are on as long as the car is on unless ebrake is pulled. I can't wait to have some time to re-do it all. I am just going to pull everything out and start fresh with a wiring harness this next time.
Old 02-21-2013, 10:58 AM   #14
jdmjack
Member#: 248430
2003 PSM Bugeye
What are the pros and cons of having a wiring harness vs not?
Old 02-21-2013, 11:14 AM   #15
2002Dubx
Member#: 177337
1 Dirty Old
Pro - Having everything wired correctly and in place.
Con - Ending up like me from a DIY gone bad.
Old 02-21-2013, 11:25 AM   #16
jdmjack
Member#: 248430
2003 PSM Bugeye
Hmm well I took mine to a shop the other day to get mine installed and they got the high and low beams hooked up and working right. I disabled the DRLs to be safe via under the glovebox. I'm a noob with lighting so I'm pretty positive there was no wiring harness in what I gave them but they wired it all up professional so either they made one or got them to work some other way. PO had put some HID bulbs w/ ballasts into stock housing.
Old 01-27-2014, 04:14 PM   #17
BugEyeBuilder
Member#: 364594
2002 WRX Sedan
I installed my jdm HID's last night, using a Lightwerks harness. I also used these instructions, since the harness came with none. (Really appreciate this thread.) Everything works properly but the low beams, (projectors). I opened the fuse box and saw the 30AMP fuse is broken. When I look at the wiring coming from my oem ballasts, (Which are the same ones pictured), the black, square plug, (not the grey plug w/triangular end), has a brown and orange-ish wire, as pictured, but it is not connected to another plug with a black wire and a blue wire. On the driver's side, I currently have the black female connector on the L.W. harness attached plugged onto the male prong on the brown side and the red female attached to the male prong on the orange-ish side. Same on the passenger side. Should I try revering this since the fuse blew?
BugEyeBuilder is offline   Reply With Quote
Old 04-22-2014, 03:21 AM   #18
scylar
Member#: 369585
Sorry yo bring up such an old post but im currently doing the same thing and the same thing happened to me. The fuse blew. Can anyone help us get an idea of what to do. As the socket that came with my ballast did not have the socket where theres the black and blue wire. Any help would be greatly appreciated
scylar is offline   Reply With Quote
Old 05-21-2015, 09:28 PM   #19
thathalfginger
Member#: 393760
2002 WRX Wagon
Platinum Sliver
Just finished test wiring my Sti projectors with the lightwerks harness. High and low beams work great but I don't have DRL's or side turn signals anymore? Any advice?
thathalfginger is offline   Reply With Quote
Old 09-01-2015, 10:41 AM   #20
Jimz02WRX
Member#: 338477
I also did this modification. However, my drivers side high beam and corner light do not work!!
Anyone out there run in to this same issue? Wondering if it has to do with the harness or if it a problem with the light housing wiring?
Any info is much appreciated. Doing all this work and to not have it work perfect is a bummer!
Thanks
Jimz02WRX is offline   Reply With Quote
Old 09-01-2015, 11:27 AM   #21
car_freak85
Member#: 13530
EA63 , EA81T, EG33,
EJ205
Did you check that the bulbs aren't burned out?
Old 09-01-2015, 12:10 PM   #22
Jimz02WRX
Member#: 338477
They are all brand new bulbs and I even switched them out to the other side to make sure they are working.
Old 09-01-2015, 12:48 PM   #23
dsolis
Member#: 121775
2008 STi Hatch
Aspen White | Gold BBS!
I'd recommend checking that the plug is making full contact and that no pins are bent from the blue connector to the factory plug.
dsolis is offline   Reply With Quote
Old 09-01-2015, 01:14 PM   #24
Jimz02WRX
Member#: 338477
OK....will do that when I get a chance. Will stop in to update once done.
