Old 09-16-2012, 01:52 AM   #1
Oldporkfat
Member#: 328183
2009 WRX
Default underboosting?
target boost is 15 but tappers down to just under 12psi
Oldporkfat is offline   Reply With Quote
Old 09-16-2012, 03:18 AM   #2
addictionsoLA
Member#: 301236
2010 Wrx
Grayish!
You should host this file in google docs. . .
addictionsoLA is offline   Reply With Quote
Old 09-16-2012, 09:44 AM   #3
Cobb Tuning
Member#: 4803
Boost tapering is normal and expected at higher RPM. If your map calls for 15 psig of boost, that is what you should expect at peak boost (in higher gears), but the target will still taper at higher RPM (more and more as you approach redline).
Bill
