Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 09-16-2012, 03:33 PM   #1
boostmasterflex
Member#: 237447
2002 Impreza WRX
WR Blue
Ok so I'm going to be buying a set of Rota Grid 17x9 wheels for my 02 WRX Sedan.
I'm curious what offset would be ok.
Tires-235/45/17
Kyb agx struts w/ eibach Pro kit.
Please help, will be ordering today.
Thanks.
boostmasterflex is offline   Reply With Quote
Old 09-16-2012, 04:12 PM   #2
MD04WRX
Member#: 72891
2014 Molten ST
2000 2.5RS - 2014 XV
You want some where around +38 to +42 range. I don't know what is available in that wheel. You will need to roll the rear to keep them from rubbing.
MD04WRX is offline   Reply With Quote
Old 09-16-2012, 04:30 PM   #3
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
^^^^ this I highly suggest not going less than +38 but depends what u r looking for do some searches lots of good info in here.
trev762 is offline   Reply With Quote
Old 09-16-2012, 06:07 PM   #4
sc00by4life
Member#: 97135
why 9" wheels when you only want to run a 235?
you'd do better going to a 235/40.
+42 and no less than a 245.
Old 09-16-2012, 06:35 PM   #5
boostmasterflex
Member#: 237447
2002 Impreza WRX
WR Blue
Only one available is a +35 in a 17x9... how much issue are we talking here?
Old 09-16-2012, 06:38 PM   #6
boostmasterflex
Member#: 237447
2002 Impreza WRX
WR Blue
I have a set of new 235/45/17...I want the concave look in the grid. if I can do that with a 17x8 or 17x8.5 I will. I currently have 5zigen fno1rc in a 17x8 +48....
I want no thinner than 17x8 but I also want an offset that will make the face concave some. Without a lot of suspension/body work.
Old 09-16-2012, 07:39 PM   #7
sc00by4life
Member#: 97135
at LEAST a roll all around, as well as some form of camber control f+r. you'll more than likely need more adjusment than stock front can offer, and there is no factory adjustment in the rear.
Old 09-16-2012, 08:04 PM   #8
boostmasterflex
Member#: 237447
2002 Impreza WRX
WR Blue
I have rear camber bolts. Any idea what width of tire+offset would sit flush w the fender or stick out juuuust a tad? Lowest number offset possible w a min. Of 8in width. I don't mind a small fender roll. Id rather not make any suspension mods tho.
Old 09-16-2012, 08:19 PM   #9
sc00by4life
Member#: 97135
if you want fender flush, there will need to be fender and suspension mods. period.
Old 09-16-2012, 08:28 PM   #10
boostmasterflex
Member#: 237447
2002 Impreza WRX
WR Blue
Alright....well last question
What size wheel and offset with 235 can I run to make the wheel have the concave look with no suspension mods? MINOR fender mods are ok. I appreciate this guys.
Old 09-16-2012, 08:39 PM   #11
Ghilleboy
Member#: 275527
i dont think you will need any fender work with the eibach pro kit. the drop is not low enough unless you would run with like a crazy 20" wheel or something.
if you want semi flush, than a +25 should be fairly good. having major poke would look goofy with a semi drop.
Ghilleboy is offline   Reply With Quote
Old 09-16-2012, 09:08 PM   #12
sc00by4life
Member#: 97135
Concave is all in the wheel design. Chances are you won't get something you "like" that is an easy fitment, and will require some form of fender modification.
horrible advice. know how I know you've never fit wheels?
a 9' +35 WILL require fender mods. PERIOD. stock height or otherwise, the lower you are, the more work will be required. at LEAST a roll, regardless of tire size.
the problem with running stretched tires on wide wheels is that if you aren't LOW it wont look how you think it will.
Old 09-16-2012, 09:24 PM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
you want dumb things
you already HAVE the perfect size wheels for your car
why do you want to cause yourself headaches
Old 09-16-2012, 09:28 PM   #14
onesicksoob
Member#: 215841
Dont PM me about
wheel specs
I'm with Uncle Scotty on this one, especially considering OPs proposed tire size. The only thing a wider wheel is going to do for you in this case is add weight and stress on other components.
onesicksoob is offline   Reply With Quote
Old 09-16-2012, 09:32 PM   #15
boostmasterflex
Member#: 237447
2002 Impreza WRX
WR Blue
One wheel is damaged and not repairable. I also cannot find the exact wheel local to replace.
Old 09-19-2012, 01:26 AM   #16
boostmasterflex
Member#: 237447
2002 Impreza WRX
WR Blue
Went with the Limited Enkie rpf1. 17x8 +45 in Black. Ill post pics up somewhere. Should arrive Friday.
Old 09-19-2012, 01:58 AM   #17
Uncle Scotty
Member#: 16200
OK buy Nates beans
now there ya go......perfect
Old 09-21-2012, 11:30 AM   #18
boostmasterflex
Member#: 237447
2002 Impreza WRX
WR Blue
Thank ya thank ya
