#1 |
Member#: 175478
Vehicle:2002 WRX Stage 3 PSM |
Just kind of a general question. It's a 2002 WRX Sedan, AP V1, running VF39 93 Octane Map. VF39, TurboXS Mid, Down, and Up, HKS Hi-Power, STi Pinks, SSAC Front Mount, Perrin Short Ram Intake.
Currently the car is getting terrible gas mileage and hesitating mid-rpm. The exhaust has the non-fouler on the second O2 sensor. With the new map, does the ecu need the rear O2 to read true numbers to function correctly? Could this be causing a rich condition?
#2 |
Member#: 201804
Vehicle:2012 Impreza WRX WRB |
Does it smell like raw gas coming out your tail pipe
#3 |
Member#: 175478
Not that i can tell
#4 |
Member#: 274499
NESIC
Vehicle:2007 CGM VF'd WRX 12.9 @ 105mph |
#5 |
Member#: 175478
From what I can tell, the Perrin is identical to the Cobb, and I am running the Cobb SF Intake map. The SSAC is going to hurt response, but I don't think it is going to make it run rich.
#6 | |
NASIOC Manufacturer
Member#: 4803
I would consider trading in the v1 AccessPORT for a v2 AccessPORT. This will give you the capability to data log to see what is going on, along with a lot of other features including live data monitors from a large selection of parameters, launch control, free AccessTUNER Race tuning software, and more. We do offer a $200 credit towards a new v2 AccessPORT when you trade in your old one to us: http://www.cobbtuning.com/AccessPort...in-s/70459.htm If that is not in the budget, then I would at least get a cable to use with open source logging software (RomRaider) and get some logs. You may be able to do this with the v1 cable if you get a decent serial to USB converter (and install its drivers). If you want to keep your mods as is, you will need to get a custom tune. Bill |
