Old 09-16-2012, 08:18 PM   #1
S1CkWrx
Member#: 325249
2012 wrx
dgm
Default Stage one Cobb AP Datalogs please review
just got the AP and did two runs.... i have no idea what im looking at.....
https://docs.google.com/spreadsheet/...nE5d3lpdWEwX1E
and
https://docs.google.com/spreadsheet/...mRaNzNOSGpSZ3c
map is 91 oct, SF intake Stage one.
running 93 oct gas.
S1CkWrx is offline   Reply With Quote
Old 09-16-2012, 09:48 PM   #2
bacalhau16
Member#: 297565
2011 WRX hatch
logs looks pretty good. Im assuming u have a 2008+ here. If so, boost is right on point. your first log is a bit short. in the future, make log more like ur second log. Ideally around 2500 rpm to redline and WOT.
bacalhau16 is offline   Reply With Quote
Old 09-16-2012, 10:10 PM   #3
S1CkWrx
Member#: 325249
2012 wrx
dgm
its a 2012.
is everything else checking out good?
Old 09-17-2012, 09:40 AM   #4
Cobb Tuning
Member#: 4803
and
running 93 oct gas.
Log looks good. You may want to get a more extended run (start at a lower RPM, but above 2000 RPM) for future runs.
Bill
Old 09-17-2012, 05:43 PM   #5
S1CkWrx
Member#: 325249
2012 wrx
dgm
thanks!!
Old 09-18-2012, 02:16 PM   #6
S1CkWrx
Member#: 325249
2012 wrx
dgm
Cobb Tuning i filled up today with 93 oct from local sonoco a few subie owners from the area go their so i decided as well... did a log lmk how it is...
https://docs.google.com/spreadsheet/...XVtN3hzeHBtMHc
ive put over 100 miles on this tune already.
Old 09-18-2012, 06:50 PM   #7
bacalhau16
Member#: 297565
2011 WRX hatch
Im not Cobb tuning, but i can say that you may have experienced knock during this run. It was as soon as u went WOT throttle which is strange. Your dam is 1, which is great and your boost is spot on.
Continue to drive and post another log, hopefully that knock will have gone away.
Old 09-18-2012, 09:06 PM   #8
hutch959
Member#: 267463
actually... this is not strange... its typical. as you go wot it is typical to get a single knock event, and this is what this is. then the ecu straightens things out and all is well...
I personally would not want it to do this, so if everytime you go wot you see this you may want to flash "down" a map.
hutch959 is offline   Reply With Quote
Old 09-19-2012, 07:07 AM   #9
S1CkWrx
Member#: 325249
2012 wrx
dgm
flash down? to what.....
Old 09-19-2012, 08:31 AM   #10
Cobb Tuning
Member#: 4803
Log looks good. The single count of feedback knock correction is normal noise. It is typical to see that type of correction during large throttle transients (and even sometimes less severe transients). It may not happen every time, but when it does, it is not generally a concern.
Bill
Old 09-19-2012, 11:36 AM   #11
S1CkWrx
Member#: 325249
2012 wrx
dgm
Alright i saw that and was nervous. Bill should i stick to sonoco? Or go back to regular stations i was using before i had the log above?
Thanks!!
Old 09-19-2012, 12:31 PM   #12
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
So, how many threads did you make... With the same logs?
Black94Snake is offline   Reply With Quote
Old 09-19-2012, 02:49 PM   #13
S1CkWrx
Member#: 325249
2012 wrx
dgm
Only 2 with dff titles to get responces. Rather have a few answers than just one.
Old 09-19-2012, 07:19 PM   #14
bacalhau16
Member#: 297565
2011 WRX hatch
lol, listening to too many people will sometimes only confuse you. Bill says your good to go. I trust him. You should too
Old 09-20-2012, 09:28 AM   #15
Cobb Tuning
Member#: 4803
Thanks!!
I would go ahead and get a few more logs - doesn't hurt and always a good idea to get multiple logs to make sure there isn't any intermittent knock or other issues.
Bill
Old 09-20-2012, 08:03 PM   #16
S1CkWrx
Member#: 325249
2012 wrx
dgm
bill i took two more tonight....
to me they seem really good.......
but il let you decide that haha
https://docs.google.com/spreadsheet/...2dRVnBHdTFPbkE
and
https://docs.google.com/spreadsheet/...0hvbFpncU8wTVE
car seems to run strong!
Old 09-21-2012, 07:55 AM   #17
Cobb Tuning
Member#: 4803
and
Logs look good!
Bill
Old 09-21-2012, 09:11 AM   #18
S1CkWrx
Member#: 325249
2012 wrx
dgm
Nothing to keep an eye out on bill?
And thanks for the support!!
Old 09-21-2012, 09:22 AM   #19
Cobb Tuning
Member#: 4803
Good practice to check your A/F Learning 1 A,B,C,D fuel trims every once in a while over time. They should be within around +/- 5%. If you start seeing any values outside of +/- 8% or so, you might have a fueling issue. New turbo Subarus have been having issues with some intake tract leaks from the factory.
Bill
Old 09-22-2012, 11:31 AM   #20
S1CkWrx
Member#: 325249
2012 wrx
dgm
alright thanks!
Old 09-24-2012, 06:58 PM   #21
S1CkWrx
Member#: 325249
2012 wrx
dgm
did another log had some slight fine knock everything else checked out. i guess it just happend for ****s and giggles...
https://docs.google.com/spreadsheet/...DczeC1ldEVwQWc
Old 09-25-2012, 09:45 AM   #22
Cobb Tuning
Member#: 4803
Keep driving on it and see where your fuel trims end up over time. Your load is a bit high for a stage 1 2008 WRX, which makes me think you may have a boost leak. Let's see where your A/F Learning 1 A,B,C,D values end up.
Bill
Old 09-25-2012, 11:37 AM   #23
S1CkWrx
Member#: 325249
2012 wrx
dgm
I double checked my intake and boost gauge wiring i dont see anything loose. Everything is on toght and secured with a ziptie.... What should the a\f be at?
Old 09-25-2012, 08:06 PM   #24
S1CkWrx
Member#: 325249
2012 wrx
dgm
Bill
bill i did another two tonight they seemed to clear up alot with fine knock...
https://docs.google.com/spreadsheet/...E9SRjc3bzNQWnc
and
https://docs.google.com/spreadsheet/...DlScnNQdjhWcVE
any better?
Old 09-26-2012, 08:32 AM   #25
Cobb Tuning
Member#: 4803
and
any better?
Looks good. I would just keep an eye on the A/F Learning 1 A,B,C,D over time (say every once in a while through a couple of tanks of gas). You can view each of these via live data. They should generally be within +/- 5%.
Bill
