Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 09-16-2012, 11:51 PM   #1
DieselMaytrain
Member#: 324363
2009 WRX
SSM
Default Cobb SF Intake W/O Accessport
I was looking into getting a Cobb SF Short Ram intake for my 09 WRX Sedan. Do i need to have the access port too?
I don't want to have to run with the check engine light on or mess my car up in any way so i decided to ask here first!
DieselMaytrain is offline   Reply With Quote
Old 09-17-2012, 12:01 AM   #2
Wicked Innovation
Member#: 265606
this intake requires tuning. you dont need an accessport, but you need to tune for it.
Wicked M@
Wicked Innovation is offline   Reply With Quote
Old 09-17-2012, 12:07 AM   #3
DieselMaytrain
Member#: 324363
2009 WRX
SSM
Great thanks. I guess that means don't run long w/out getting it tuned or getting the AP?
Old 09-17-2012, 12:11 AM   #4
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
^ What he said
Old 09-17-2012, 12:11 AM   #5
Member#: 51961
2005 STi
2012 WRX
Don't run it at all without a tune.
Old 09-17-2012, 12:28 AM   #6
DieselMaytrain
Member#: 324363
2009 WRX
SSM
That's what I thought. Thanks!
Old 09-18-2012, 01:43 PM   #7
Decipher
Member#: 262760
2011 WRX Hatch Limtd
Satin White Pearl
Some intakes are acceptable to run without a tune, such as the K&N. That intake doesn't change the diameter, therefore flow dynamics are unchanged, meaning no tune is required. Is it recommended? Oh yeah. Cobb does require a tune, so please consider your engine management before doing this or any intake.
Decipher is offline   Reply With Quote
Old 09-18-2012, 02:50 PM   #8
Member#: 51961
2005 STi
2012 WRX
It doesn't matter if the diameter is the same. The flow pattern is different, which throws off the MAF scaling.
ALL intakes for the 08+ WRX/STi need a tune...ALL of them, there are no exceptions. None of them measure close enough to stock to work with the stock scaling.
Old 09-18-2012, 02:54 PM   #9
s2ktosti
Member#: 70151
2011 WRX Limited
BINGO, except no substitute answers.
s2ktosti is offline   Reply With Quote
Old 09-18-2012, 03:04 PM   #10
mattminer
Member#: 90642
WKD Everything
this is absolutely my findings as well for 08+ cars.
Wicked M@
mattminer is offline   Reply With Quote
Old 09-18-2012, 03:15 PM   #11
silverboost0303
Member#: 83266
2011 WRX Sedan
Save your 275$ and buy the accessport. Stage 1 with that will produce a bigger smile than the intake. Trust me.
silverboost0303 is offline   Reply With Quote
Old 09-18-2012, 05:47 PM   #12
RallySport Direct
Member#: 33174
We are Open Late!
888-457-2559 Every day!
For any 08+ WRX and STi any intake changes require a tune. We did testing on this a few years ago when trying out different stuff on 08+ cars and ran into it the sensitivity issue of these cars and air flow.
This dyno plot shows the AFR curve, however we ended up having to richen the car out to correct for the change in flow when we did a drop in. I dont remember exactly the #'s but it was along the line of .5-.75:1 lean out when going from OEM to drop in high flow filter.
So in a nut shell, stick with OEM air filter and airbox unless you plan on tuning for it.
Kirill
RallySportDirect.com
RallySport Direct is offline   Reply With Quote
Old 09-18-2012, 06:31 PM   #13
Elky
Member#: 303906
2011 WRX Sedan
Spark Silver Metalic
Kirill
Curios why, if you know this, you don't always correct the vendors on your site when they tell people that they don't need to tune specific intakes. Might want to look into that so people don't make their engines go pop!
Elky is offline   Reply With Quote
Old 09-18-2012, 06:41 PM   #14
RallySport Direct
Member#: 33174
We are Open Late!
We do our best to educate our customers on stuff like this, however its ultimately their decision on what to get and how to modify their car.
Some manufactures state that tuning is not required based on how they designed the intake system. And others say they do, so we list information as the manufactures to stay consistent between them and us as we have not tested EVERY system on the market.
When a customer calls in and asks about it, our reps will specify that we suggest a tune for 08+ WRX's and STi's if any intake changes are made of how air flows over the MAF sensor.
Kirill
Old 09-18-2012, 06:46 PM   #15
Decipher
Member#: 262760
Satin White Pearl
I had this exact sediment before I did some heavy reading. Everything I read before indicated this very thing and, if you were to view my posting history, you can see just that. HOWEVER, after reading some very interesting data, I changed my feelings on this. I will try to dig up my sources and post them. I am not one to hand out poor, misinformed, and uneducated information. No matter what, I would never put an intake on and not tune for it. There are companies, however, who have the R&D into their intakes and say they run just fine without a tune. Let me find those articles.
Old 09-18-2012, 06:55 PM   #16
Member#: 51961
2005 STi
2012 WRX
Here's a figure showing the percent change in MAF readings for 6 different aftermarket intakes versus the stock intake. The K&N IS one of those being plotted here.
If you think a 10%+ lean shift at WOT is fine, then more power to you, but I don't, and I wouldn't go around telling other people that they don't need a tune for it either. The Perrin intake is also one of those being plotted here, it's actually SMALLER diameter that stock, yet it too has a 10%+ lean shift at WOT. Just the other day one of the Perrin reps posted in a thread in the Newbie forum and backed up that statement, the Perrin intake runs 10% lean at WOT on the stock tune. They are of the opinion that a 10% shift is not enough to warrant concern since the stock tune runs so rich anyway, but I don't agree with that sentiment.
Old 09-18-2012, 07:24 PM   #17
silverboost0303
Member#: 83266
2011 WRX Sedan
These cars are so touchy, pretty much anything aftermarket you install, has to be tuned. Like I said, get the AP, and get OTS maps for it. I STILL got a protune, but if you really wanna save some cash (and run a risk over time) just get the AP. Newer gen subaru's are too damn touchy not too. I remember on my bugeye when I had a catless blitz nur spec tbe. A tune was not needed. The car ran pig rich, which was fine. Albeit I wasn't getting the most potential out of the exhaust without the tune, I could still run it without issue. These days, you just can't.
Old 09-18-2012, 09:50 PM   #18
Decipher
Member#: 262760
Satin White Pearl
I'm quoting myself to show just what I said. Some manufacturers say it's okay to run without a tune. They claim it's safe. Would I run without one? No. Did I tell the OP to run without one? No. Quite the contrary. Maybe I wasn't clear enough in my statement that the sediments of not tuning were that of manufacturers and not me. Note: I have my car tuned to my intake.
I've done my part to save face. Apologies if this wasn't clear. Nonetheless, a 10% increase in lean spots on an already grossly lean OEM tune is not acceptable by any standard.
Old 09-18-2012, 10:51 PM   #19
Member#: 51961
2005 STi
2012 WRX
I didn't catch that in your post, no worries. I guess K&N is like Perrin in that they assume a 10% lean shift isn't enough to warrant concern on a stock tune.
Old 09-19-2012, 07:28 AM   #20
Decipher
Member#: 262760
Satin White Pearl
That's truly unbelievable. Anyways, I strongly look down on those who hand out bad info just to bump their post count. The last thing I want to do is spread bad info. Either way, Perrin and presumably K&N's stance on this lean spot is amazingly sad.
Old 10-24-2012, 02:51 PM   #21
Subarusaurus_Rex
Member#: 336002
2012 WRX Limited
Default good advice
I just ordered a cobb sf intake and thought that it was not necessary to tune it, but this thread has inspired me to order the accessport. I want to do this car right!
Subarusaurus_Rex is offline   Reply With Quote
Old 10-24-2012, 05:51 PM   #22
Decipher
Member#: 262760
Satin White Pearl
Great choice. You won't regret it.
Old 10-24-2012, 06:05 PM   #23
STI_4TW
Member#: 333307
2013 STI
Pretty sure MAF diameter changes, so in order for your MAF to read correctly, you need a tune / or access port to rescale for the car to run properly.
STI_4TW is offline   Reply With Quote
Old 10-24-2012, 08:01 PM   #24
Member#: 51961
2005 STi
2012 WRX
What on earth gave you that idea? EVERYTHING, including the website where you buy the intake, says that it MUST be tuned for.
http://www.cobbtuning.com/Subaru-SF-...t-p/715100.htm
It's even highlighted in bold red print...
Old 10-25-2012, 09:51 AM   #25
Tripintaz
Member#: 245218
2013 STI Limited
Ice Silver
You should just install it and report back here after 5000 miles and let us know if your engine is still alive.
Tripintaz is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 12:24 AM.
