Old 10-25-2012, 11:37 AM   #1
Wikki
Member#: 331744
2006 Subaru WRX
Default Bov stuck?
So I'm still boosting At full psi but when the turbo starts to spool it sounds like alot of air is just being sucked in like I have a hose loose or something... I checked my hoses this morning an everything is tight the only thing I can think of would be can the bov be stuck open? Because there is no blow off from the pressure when I shift or anything
Wikki is offline   Reply With Quote
Old 10-25-2012, 11:40 AM   #2
Wikki
Member#: 331744
2006 Subaru WRX
Oh and it is a tial bov in a 2006 Wrx with upgraded turbo tmic and turbo back exhaust
Old 10-25-2012, 12:23 PM   #3
clipsy
Member#: 227451
2006 wrx
white
take it apart an oil it up. Its just like an oil change you need to do it every 25-4k miles.
clipsy is offline   Reply With Quote
Old 10-25-2012, 12:35 PM   #4
k04sti
Member#: 171773
04 wrx sti
jbp dom 3 xtr w meth!
take off that dumbass bov and get a bpv. /endthread
k04sti is offline   Reply With Quote
Old 10-25-2012, 12:49 PM   #5
Wikki
Member#: 331744
2006 Subaru WRX
I would and am planning on it ponce I have the money to
Old 10-25-2012, 12:52 PM   #6
Wikki
Member#: 331744
2006 Subaru WRX
Does what I explained sound like it is opening early? Or gettin stuck open? Cause it closes at idle or do you think I may need to change out the spring on it?
Old 10-25-2012, 12:57 PM   #7
k04sti
Member#: 171773
04 wrx sti
Then put on your stock one for now. You can always crush it if you need to. This way you can see if this is your problem or not.
Old 10-25-2012, 01:22 PM   #8
clipsy
Member#: 227451
2006 wrx
white
yea i have stock bpv on my car, runs great, and im pushing 315whp.
Old 10-25-2012, 01:23 PM   #9
clipsy
Member#: 227451
2006 wrx
white
Only one way to find out, take it off an lub it up lol
Old 10-25-2012, 01:29 PM   #10
Wikki
Member#: 331744
2006 Subaru WRX
Lol alright any suggestions on oil for it? Or anything?
Old 10-25-2012, 01:38 PM   #11
Wikki
Member#: 331744
2006 Subaru WRX
unfortunatly i dont have the stock one... this is the way i bought it and previous owner didnt have any of the things that had gotten replaced
Old 10-25-2012, 01:38 PM   #12
Wikki
Member#: 331744
2006 Subaru WRX
wow... yeah im pushing 273 WHP right now...
Old 10-25-2012, 01:39 PM   #13
2.5ReallySexy
Member#: 167943
Any motor oil will do..
2.5ReallySexy is offline   Reply With Quote
Old 10-25-2012, 01:41 PM   #14
Wikki
Member#: 331744
2006 Subaru WRX
thanks... and what specifically should i lube? the port where it opens im assuming?
Old 10-25-2012, 01:41 PM   #15
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
vf39 ewg tuned ppg gears
yea i say u lube it with a thin coat of motor oil and should be fine. i had the same problem but mine was stuck shut and i lube it and it was fine.
dumpstercrusher is offline   Reply With Quote
Old 10-25-2012, 02:02 PM   #16
Wikki
Member#: 331744
2006 Subaru WRX
just lube the stem right?
Old 10-25-2012, 06:23 PM   #17
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
what kind of bov? mine was a turbosmart dual port that had a brass piston inside. i jus unscrewed the top while it was still attached to thr car, off of course, and i dipped my finger in motor oil im not using (brand new) and coated the piston and inside the chamber the piston sits to create lubrication and it was fine
Old 10-25-2012, 06:28 PM   #18
Wikki
Member#: 331744
2006 Subaru WRX
Tial Q
Old 10-25-2012, 06:35 PM   #19
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
Tial Q
ive never seen a tial Q in person so i wouldnt know, but im sure u can open it and lube it. but also if its stuck open u should see it open while its idling. Could be another problem
Old 10-25-2012, 06:44 PM   #20
5050
Member#: 252122
2007 Sti
OPB
:b anana:
5050 is offline   Reply With Quote
Old 10-25-2012, 07:38 PM   #21
Wikki
Member#: 331744
2006 Subaru WRX
Originally Posted by 5050 View Post
:b anana:
haha already been looking in to them today checkin on here and junkyards... so it will soon be done!
