Old 09-17-2012, 11:42 AM   #1
Ruiner46
Member#: 213209
2007 STI
Satin White Pearl
Default Just bought 2007 STI - OTS Map question
I just purchased a 2007 STI. The car came with two protunes on an accessport, but when I checked the DAM, it was only 0.8 on one of the maps. I loaded the other map which I'm guessing is less aggressive due to the naming of the file, but the DAM has been sitting at 0.5 for two days of driving and hasn't increased yet.
I'm thinking about loading the OTS Stage 2 map (91 octane since I live in CO), but I'm a little worried about the exhaust mods that it has. The car came with a Crucial Racing catless turbo back exhaust with divorced wastegate. It also has ported and coated exhaust manifolds, and a grimmspeed high flow crosspipe. I'm not sure what the up-pipe is. No other engine mods, stock intake, injectors, VF43, intercooler, etc.
My question is: Are these exhaust mods, namely the ported manifolds and crosspipe, ok for an OTS map, or are they outside the range of safe tuning? I don't really care about power right now, I just want a safe tune to daily drive on for a few months until I can afford a few mods and a dyno tune from my tuner.
Ruiner46 is offline   Reply With Quote
Old 09-17-2012, 12:50 PM   #2
Ruiner46
Member#: 213209
2007 STI
Satin White Pearl
Ok, I reloaded the original protune map and did a datalog today starting in 3rd and shifting to 4th. The only concern I have is a little bit of knock after the shift from 3rd to 4th when I still have a DAM of 0.5. Is it normal to get knock before the timing has even increased?
https://docs.google.com/spreadsheet/...W50YzhEYVpHb0E
Old 09-18-2012, 10:07 AM   #3
Cobb Tuning
Member#: 4803
A single count of feedback knock is fairly common on or shortly after hard shifts (or when mashing the throttle) and is generally just noise. The log looks fine, except for the DAM being 0.5. The DAM will reset to the default (determined by the map) when you reflash the map, so it is hard to say whether or not it has dropped due to knock or has just not learned up to 1.0 yet. You could reset the ECU (via troubleshooting menu) and then immediately look at the DAM. If it is at 0.5, then that would be the reset default. If it goes up, then your DAM has dropped. 0.5 is the factory default, but often tuners will raise this (not always, but not an uncommon change).
Your mods aren't too out of scope of the map. But, if you decide to try the OTS map, I would start with the most conservative map (ACN91) and get data logs.
Bill
Old 09-18-2012, 01:57 PM   #4
Ruiner46
Member#: 213209
2007 STI
Satin White Pearl
Thanks for the response. It's good to know that the one knock event is ok. I did a 2nd to 3rd gear log also and there is no knock whatsoever in that map. I did reset the ecu, so that is the reason for the 0.5 DAM. This 07 STI seems to take a long time to learn compared to my old 03 WRX. The 03 would learn up to its max value within 20 minutes of driving.
Old 09-19-2012, 09:18 AM   #5
Cobb Tuning
Member#: 4803
Try moderate, steady boost to raise the DAM. Generally, the 2.5L cars on the stock map will get up to 1.0 pretty quickly, but this speed can be impacted by specific changes to the tune, so it is possible that the custom tune is such that it takes longer.
Bill
