Go Back   NASIOC > NASIOC Technical > FB Series Normally Aspirated Powertrain
Old 09-17-2012, 03:13 PM   #1
nels0300
Member#: 331332
2014 Camry SE V6
Default FB engine and head gasket design
I've read somewhere, can't remember, that Subaru has changed the head/head gasket design on the new FB engines. Does anyone have additional detail on this? Are they trying to address the head gasket problems that the 2.5L is having?
I didn't realize the head gasket issue on the 2.5L was so widespread until I joined this site.
I would assume Subaru would have addressed this with the new FB engines....but I also would have assumed they would have addressed the issue after a few years of the 2.5L and from what I've read, they didn't.
I understand time will tell with the FB, but I am curious to hear what the Subaru experts/techs on this site think about the FB and potential head gasket issues.
nels0300 is offline   Reply With Quote
Old 09-18-2012, 12:15 AM   #2
GEE-OTTO
Member#: 201277
2009 Legacy GT
HG's problems are so 98-04
GEE-OTTO is offline   Reply With Quote
Old 09-19-2012, 12:56 AM   #3
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
05-07 have suffered from it as well. Bloody single-layered steel gasket design on the EJ251 and EJ253, which was also very sensitive to coolant acidity. 08-11 havent yet massively reached the usual 100 000 mile mark where most issues occured, but I wouldn't expect them to be much more robust.
As for the FB25 or the FA20, no freaking clue - the oldest ones are 11' Foresters, so too low of a mileage to judge. Given an engine redesign and a well known problem I'd suspect SOJ did spend a few pennies to fix the issue.
Old 09-19-2012, 12:57 AM   #4
Bluefoton
Member#: 141373
2008 2.5i-hatch -
double post
Old 09-19-2012, 02:57 AM   #5
GrundleJuice
Member#: 165749
Not to mention Toyota has some input in its design.
Old 09-19-2012, 08:42 AM   #6
nels0300
Member#: 331332
2014 Camry SE V6
There is someone at Edmunds saying the FB engine's heads have their own coolant supply and that the coolant doesn't even flow from the block to the head through the gasket. I haven't been able to verify this anywhere else though. Does anyone have a picture of the gasket or head to verify?
Old 09-19-2012, 10:30 AM   #7
GrundleJuice
Member#: 165749
If that is true that would be a genius solution in one sense. But I would think it would add another complexity to the cooling system like external lines and/or thermostats/valves.
And besides the coolant, there lots of external oil gasket leaks.
Old 09-20-2012, 08:33 PM   #8
Supraru
Member#: 23313
99' 2.5Rs
black
Toyota had nothing to do with the design of the FB.
Supraru is offline   Reply With Quote
Old 09-20-2012, 08:40 PM   #9
GrundleJuice
Member#: 165749
Whichever one is in the brz they had some input
Old 09-20-2012, 08:52 PM   #10
DohcEj22e
Member#: 289011
That is the FA & Toyota designed the direct injection for that engine. That engine is also used in the JDM Legacy in turbocharged form.
DohcEj22e is offline   Reply With Quote
Old 09-20-2012, 09:02 PM   #11
GrundleJuice
Member#: 165749
Do the FA and FB have different head/case designs besides dimension and displacement?
Old 09-20-2012, 09:13 PM   #12
xilles
Member#: 147056
the fb motor is a timing chain motor, the whole timing cover is sealed with fuji bond and there is a supplied coolant from head to head. no block interference. if you look on the drivers side head there is a plastic port ontop for coolant crossover. any tech that has gone through chain driven motor class can give a better description. if you want i can post up an assembled fb shortblock
xilles is offline   Reply With Quote
Old 09-20-2012, 09:16 PM   #13
Supraru
Member#: 23313
99' 2.5Rs
black
This is why you should not make statements if you have no clue what you're talking about.
Old 09-21-2012, 12:12 AM   #14
coupedupsubie
Member#: 290761
Along with the FB having a timing chain it also uses a diagonally split connecting rod allowing it to have a longer stroke. This design came from the diesel engines that Subaru has in Europe.
coupedupsubie is offline   Reply With Quote
Old 09-21-2012, 03:23 PM   #15
GrundleJuice
Member#: 165749
Give yourself a pat on the back for that useful post.
I obviously have no idea about anything.
Old 09-21-2012, 03:42 PM   #16
Supraru
Member#: 23313
99' 2.5Rs
black
It was a useful post. Hopefully next time you try to make a post to act like you know what you're talking about you'll think twice so you don't look dumb. Sorry guy just the way it is. You'll learn some day.
Old 09-21-2012, 04:51 PM   #17
alt14
Member#: 271928
2014 WRX Limited
Crystal Black Silica
I however would like to see one
alt14 is offline   Reply With Quote
Old 11-04-2014, 04:15 PM   #18
Domingomp5
Member#: 201118
2014 XV Crosstrek
Dark Gray
I would like to see one as well.
Domingomp5 is offline   Reply With Quote
