Old 09-17-2012, 04:06 PM   #1
besthaticouldo
Member#: 279660
Default 2011 WRX w/ EWG/FMIC/STGII++ tuned by Tim Bailey
Facility: COBBTuning SoCal
Tuner: Tim Bailey
Type of Dyno: Mustang
Boost: 16
Fuel: 91
Peak HP at RPM: 326whp
Peak Torque at RPM: 337wtq
Relevant Power Mods:
AEM Cold Air
Catless Downpipe
Invidia Q300 Catback
TurboXS Bypass Valve
Tial 38mm MV-S External Wastegate
Grimmspeed EWG Up-Pipe
COBB 3 Port EBCS
DW65C Fuel Pump
RacerX Front Mount
Here's a cell capture of the plot
Tim Bailey is the freakin man, this is the best the car has EVER driven. Couldn't be more happy with the numbers!!! Thanks COBB!
besthaticouldo is offline   Reply With Quote
Old 09-17-2012, 05:23 PM   #2
bluepearlrex12
Member#: 310184
2012 WRX
Blue Pearl
What turbo are you running? I can't see you making that much power on the vf at 16 psi on 91. nice numbers though. I have a similar setup with only bigger TMIC and was just curious.
bluepearlrex12 is offline   Reply With Quote
Old 09-17-2012, 05:41 PM   #3
besthaticouldo
Member#: 279660
VF52, stock turbo.
Old 09-17-2012, 07:04 PM   #4
CPU GUY
Member#: 203347
07 STi
nice numbers
CPU GUY is offline   Reply With Quote
Old 09-17-2012, 07:40 PM   #5
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
vf39 ewg tuned ppg gears
Nice numbers! But i cant imagine that with only 16psi n 91 oct....
dumpstercrusher is offline   Reply With Quote
Old 09-17-2012, 07:54 PM   #6
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
At peak power he's around 14-15psi. Just like all the other VF turbo's that are running "22psi!!11!!!". Phatron and Jr did this experiment not too long ago. Results are exactly as you see here. 22psi tapering to 14psi makes more peak torque, but similar peak power to a turbo that is 16psi tapering to 14psi.
xluben is offline   Reply With Quote
Old 09-17-2012, 08:18 PM   #7
besthaticouldo
Member#: 279660
Originally Posted by CPU GUY View Post
nice numbers
yep, thanks man!
lol, thanks, its a stock VF, 91 octane, and 16psi. lol proofs what it is.
yepppp...dont need a ton of boost to make power, sometimes more boost means more heat and isn't helping you at all. car makes great power and i love it, the drivability of this car is unreal.
Old 09-17-2012, 08:22 PM   #8
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Did you have a link to that?
There are various VF tuning theories, especially to keep them from tapering up so miserablely on 2.5's, but I can't find anything!
Zee Biker is offline   Reply With Quote
Old 09-17-2012, 08:35 PM   #9
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
This has nothing to do with stopping the taper, simply that you don't need a lot of peak boost to make power. All you need is about 15psi @ 5k-6k rpm's and you'll make good power. Here are the links.
http://forums.nasioc.com/forums/show...postcount=4974
http://forums.nasioc.com/forums/show...postcount=4979
The first is the HP curves from the dyno and the second is the logs from the dyno in Virtual Dyno (to see TQ and boost). Junior tuned one with a normal (22psi) curve, and the other with a purposely low boost that didn't spool until very late. He was just trying to prove a point.
In the case of besthaticouldo's tune, the reduced peak boost will give a much more linear power response and flatter torque curve. It will pull more smoothly and still have just as much top end as any other VF. I would have gone for more peak boost (because that's fun ), but this tune is probably a very nice one for drive-ability.
Old 09-17-2012, 10:09 PM   #10
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Very interesting stuffs! Still looking into how to stop the taper of power to hold a gear out for longer and having it make sense!
Old 09-18-2012, 04:39 AM   #11
CPU GUY
Member#: 203347
07 STi
thanks
Old 09-18-2012, 09:30 AM   #12
Tripintaz
Member#: 245218
2013 STI Limited
16 psi peak? no way.
Tripintaz is offline   Reply With Quote
Old 09-18-2012, 10:01 AM   #13
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
BTW Tim Bailey is the master in this biz. He tuned my 07 STI, his work like magic. Take a look on my dyno graph
http://accessecu.com/dyno/graph.php?...rgb2=204000000
My setup:
Cobb SF intake
Invidia catted dp
Invidia cat-back
You should make your own thread.
See my posts above. Peak boost gives you high peak torque numbers. Boost at peak power is similar on this car as it is on most "22psi" VF setups.
Old 09-18-2012, 11:56 AM   #14
Subiesaurus Rex
Member#: 188552
PM SKIMSTI 4 help
installin your Downpipe!
I think hes running like 84.5 octane so 16psi is the most he could get without knock. (sarcasm lol)
I am not sure where this boost was measured, pre or post FMIC.... would you believe the graph if he told you it was 17psi?
Subiesaurus Rex is online now   Reply With Quote
Old 09-18-2012, 12:33 PM   #15
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
My setup:
Cobb SF intake
Invidia catted dp
Invidia cat-back
I will agree with this. If you want to post and discuss your own results you can make your own thread. Please try not to derail someone else's "bragging" thread with your own data unless they've asked for it. Thanks.
Scooby921 is offline   Reply With Quote
Old 09-18-2012, 01:23 PM   #16
breaksOFTEN
Member#: 260549
'69 Camaro '76XS750
'77CB750
Great work! Now get some bigger injectors a boost a pump and run some E85!
breaksOFTEN is offline   Reply With Quote
Old 09-18-2012, 01:36 PM   #17
colbygrease
Member#: 311468
'13 STI Hatch
****ing awesome! I wanna see a video of this bad boy.
colbygrease is offline   Reply With Quote
Old 09-18-2012, 01:38 PM   #18
besthaticouldo
Member#: 279660
rofl! it is what it is, the power is what it's making, the boost is 16psi. idk what else to tell you.
HAHA! soon man, be patient. time to finish up that suspension now
i'll get some vids soon, i'll have some autox vids from subiefest for sure.
Old 09-18-2012, 01:48 PM   #19
Tripintaz
Member#: 245218
2013 STI Limited
Let me correct myself. I see 16.4 on the dyno graph. However, the dyno numbers are irrelevant IMO without baseline numbers. That's what I was really getting at.
Old 09-18-2012, 02:37 PM   #20
besthaticouldo
Member#: 279660
same dyno, 8 months ago i made 306whp/336wtq on 19.5 psi on a stageII protune (intake, dp, CBE, 3port) not tuned by tim, that tune sucked.
Old 09-19-2012, 08:12 AM   #21
CPU GUY
Member#: 203347
07 STi
I just wanted to share my result to prove how good is Tim Bailey
Old 09-19-2012, 11:19 AM   #22
spdracerut
Member#: 269226
It's called a bigger turbo the little stock compressor wheel can only flow so much.
spdracerut is offline   Reply With Quote
Old 09-19-2012, 01:44 PM   #23
Spooky
Member#: 58864
Icanhaz ride??
Spooky is offline   Reply With Quote
Old 09-19-2012, 03:33 PM   #24
bluepearlrex12
Member#: 310184
2012 WRX
Blue Pearl
Correct me if im wrong, but those graph are from E85? We are talking 91 oct. I get the point but noty necessarily a fair match up.
Old 09-19-2012, 04:27 PM   #25
northman
Member#: 163631
07 Forester XT
Dom 1.5XT-R
Should not make much difference if you are only boosting 16 psi. The benefit of E85 is that you can run more boost without detonation. The point is that VF turbos are not big enough to flow high pressure at high RPM, it is like trying to go fast on a single speed bike.
northman is offline   Reply With Quote
