Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 09-17-2012, 05:56 PM   #1
subarujimbo
Member#: 140702
07 Wrx Wagon
Garnet Red Pearl
Default 07 WRX AEM idle issues. HELP
I'm using a series 2 ems on a 07 WRX using a MP tuning patch harness to switch everything over to that of an 06 STI.
I've had to modify the accelerator pedal slightly to get the voltages requested in the manual and to calibrate the dbw system.
Car runs well and I've started tuning. At the moment I can't get the idle lower then about 1050 rpms without the idle position % going to zero. I've had to removed a lot of timing and I still cannot get the idle where I want it. I've checked for vacuum leaks, I've synced the timing and run the TPS calibration wizard( idle is working, TPS is set ok). I have also run the DBW calibration at least 10 times.
I'm wondering if anyone can provide any input. I currently run the idle at 1075rpm, as that's where I've been able to get the best idle. If I set the idle much lower the idle position % shows zero and I reach a mechanical limitation.
subarujimbo is offline   Reply With Quote
Old 09-18-2012, 04:29 PM   #2
subarujimbo
Member#: 140702
07 Wrx Wagon
Garnet Red Pearl
I had the charge pipe off this morning to check the throttle body and make sure nothing was jamming it open.
Does anyone know if the Ddw throttle body is capable of moving past its rest position?
At the moment it won't move past the car's off rest position. Yet by hand I can physically move the throttle blade more closed?
The car would idle correctly with the stock ems, so I know there is nothing wrong with the throttle body.
I can send copies of the calibration to anyone willing to take a look.
Old 10-17-2012, 12:47 AM   #3
recce02
Member#: 13815
02 GCRally prepped
277TQ 281HP 19PSI
There is a small Allen head on the throttle body housing. I have AEM EMS1, cable driven and I couldn't get my idle to drop below 1200. Found that screw, while idling I loosened the lock nut and then the Allen screw. Idle dropped to 950!! Not sure if this will help but might be worth a try.
recce02 is offline   Reply With Quote
Old 10-20-2012, 12:35 PM   #4
subarujimbo
Member#: 140702
07 Wrx Wagon
Garnet Red Pearl
Yeah I tried that. Since the car is DBW, the throttle body doesn't rely on it as a stop when powered up.
I send the ECM back to AEM, they said there was a relay or something inside that was bad. Long story short it still doesn't work.
So I've gone back to the stock computer and like magic the idle is perfect. I'll probably start tuning with the factory ecu and Access Race.
I have to assume there is a issue with either the patch harness or AEM ems that isn't obvious to me. I checked the for proper pin out and it was ok, but maybe there a bad connectivity issue or something in the patch harness.
Old 11-15-2012, 11:44 PM   #5
sleazy07sti
Member#: 273116
2007 Hawkeye Sti
0bp
bump from the dead...i just seen this post after sending you the money for the aem v2.was that relay fixed by aem as you said it was in perfectly fine working condition
sleazy07sti is online now   Reply With Quote
