Old 09-17-2012, 08:40 PM   #1
hotshot2109
Member#: 94785
04 WRX STi
Default 2.35 Long rod build with ej22t fully closed deck block?
Plans are in motion for my 2.35 long rod build. I have an EJ22T short block, would it be better to do 99.5mm sleeves in that block and build it with an ej207 crank vs 99.5 sleeves in my stock ej257 block?
hotshot2109 is offline   Reply With Quote
Old 09-18-2012, 12:12 PM   #2
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Unless you plan on installin darton sleeves in your EJ22T case you won't be getting 99.5mm pistons in it and if you where sleeving it it would matter what case you started with.
Old 09-18-2012, 02:45 PM   #3
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
In the end it would essentially be the same for either block if you go with the same size sleeves, same crank and same rods.
The only Advantage here is the 2.2L has a fully closed deck with oil squirters (not sure if machining for sleeves eliminates the squirters though). If it does.... I would go with the 2.5L block but send it to Outfront motorsports to be fully closed after the sleeves are installed. The only disadvantage of the 2.2L is that it only uses 4 bellhousing bolts vs 8 on the 2.5L block.
So OP, it really comes down to what would be more cost effective if the 2.2L can retain the squirters after machining!
UK-Wagon is offline   Reply With Quote
Old 09-18-2012, 04:04 PM   #4
hotshot2109
Member#: 94785
04 WRX STi
I'll have it looked into. I want to keep my STi motor whole and build separate heads and block.
Old 10-03-2012, 11:42 AM   #5
hotshot2109
Member#: 94785
04 WRX STi
I see to many built subaru motors fail, so I'm trying to make sure I build it the best cost effective way as possible. closed deck seems like the toughest way. oil enquirers should be fine.
Old 10-03-2012, 11:49 AM   #6
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
They fail typically from user error, shortcuts in the build process or put together too loose. You can spend tens of thousands of dollars on parts and sill put it together wrong, miss shift, over rev, lack of oil..... ect. Most people out there dont want to tell the whole story as to why it failed, they blame the tuner, the builder or anyone else they can before they would ever say they miss shifted or over reved the piss out of an engine.
Old 10-03-2012, 11:55 AM   #7
hotshot2109
Member#: 94785
04 WRX STi
I plan to over rev it, looking for 9,000-9,500 rpms and ~30psi. Basically going for what I can get on pump gas. cosworth 280 cams, cosworth oil pump, acl bearings seem to be the way. I don't want to get into a build sheet but I'm pretty sure I have the parts list down. Just questioning the block part of the build.
Old 10-03-2012, 12:04 PM   #8
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
PLEEASE keep this updated! I plan on destroking my EJ257 and going a similar route but there is a serious lack of information out there! Good luck with everything.
Steve.804 is offline   Reply With Quote
