Old 09-17-2012, 08:52 PM   #1
omnynce
Member#: 314224
04 WRX
Default 1997 Impreza Brighton motor question
If I'm looking at buying an Impreza Brighton, and was told the motor jumped timing, quick question hopefully simple answer, do I just need to re-time the motor, or should I plan a R&R. I've gotten mixed reviews when looking it up. I already have a L wagon, but am looking for something smaller and less weight to have fun with. Thanks in advanced!
omnynce is offline   Reply With Quote
Old 09-17-2012, 08:53 PM   #2
omnynce
Member#: 314224
04 WRX
Its a ej22 if that helps.
Old 09-17-2012, 09:40 PM   #3
seat safety switch
Member#: 204265
2006 WRX Wagon
CGM
97+ should be the phase 2 EJ22 which means that it is an interference motor so valves might have been damaged.
Do a compression and leakdown test first (once you retime it), maybe you got lucky. If not, you might be able to get away with buying a used EJ22 for cheap rather than doing some headwork.
seat safety switch is offline   Reply With Quote
Old 09-17-2012, 09:56 PM   #4
omnynce
Member#: 314224
04 WRX
Thanks I just checked it out and played around with it, it seems like the front compression is extremely high (170+ psi range) and the rears are reading nothing
Old 09-18-2012, 10:03 PM   #5
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Valve job
Old 09-18-2012, 11:42 PM   #6
omnynce
Member#: 314224
04 WRX
Well thats no fun. Thanks for helping me out! Ill start looking for another motor then before I decide to buy it.
