Old 09-17-2012, 09:39 PM   #1
winglik
Member#: 317022
2013 Impreza Sport
Dark Grey Metallic
Default Impreza 2013 DLR and Fog light type?
Hi all, I want to change the DLR light to white LED bulb. I want to know the bulb type? The Subaru manual didn't mention about that. Also is the DRL also the high beam?
I also want to switch out the fog light, because the stock one didn't show much difference at night. Is the foglight type as PSX24W, any good replacement? Is it hard to replace the fog light bulb?
winglik is offline   Reply With Quote
Old 09-18-2012, 03:22 PM   #2
JDMSTA
Member#: 310615
1213 12'Sport+13'STi
Satin White Pearl
The DRL is the high beam which is a 9005 bulb type for the 2012. I'm pretty sure its the same for the 2013. As far as for the fog light bulbs. You don't have much options out there for the PSX24W bulb type unless you do a retrofit like I did.
JDMSTA is offline   Reply With Quote
Old 09-18-2012, 03:28 PM   #3
winglik
Member#: 317022
2013 Impreza Sport
Dark Grey Metallic
Hi JDMSTA, the 2013 is same as the 2012. I saw your post on retrofitting, you did a great job, I want to try on mine, but I'm too lazy to take apart the brand new light set. I have no complain about the stock low beam, I just try to change the fog light and the DRL to white if possible and with minimum work.
Do you use stock high beam as DRL or you changed to something else. How difficult is to change the fog light, I'm planning to do that. But the user manual didn't show any info on change the fog light. Also Do you have any idea how good these ebay LED light bulbs work.
Old 09-18-2012, 05:09 PM   #4
JDMSTA
Member#: 310615
Satin White Pearl
Thanks! Yeah I still uses the stock high beam as DRL and I just replaced the bulbs with a set of white CREE LED bulbs. To be honest, You really don't need it to be bright since its only a DRL so any LED bulbs would do in my opinion. As for the foglights. In order to gain access to the foglights. I just drive up a set of ramp and just go under the corners of the front bumper and pop out 3 clips and 1 screw for each side and you'll have complete access to it.
Old 09-18-2012, 07:31 PM   #5
winglik
Member#: 317022
2013 Impreza Sport
Dark Grey Metallic
Thanks for the info. I have a question. Isn't the stock DRL also the high beam? Does that mean they use the same bulb? or they are separate bulbs? If so, what's the DRL bulb type? I also want to get a white Cree LED as DRL, will that affect the high beam?
Old 09-19-2012, 02:53 PM   #6
JDMSTA
Member#: 310615
Satin White Pearl
DRL is the same as high beam so they uses the same bulb which is 9005 but DRL uses less voltage thats why it looks more dimmer than when you turn on the high beam. I don't recommend using the Cree LED as the DRL because its not as bright as your halogen bulbs when you want to use it as high beam. The reason why I use the LED bulbs on my high beam is because I had bi-xenon projectors retrofitted on my headlights so the stock high beam is pretty useless to me.
Old 09-19-2012, 02:58 PM   #7
winglik
Member#: 317022
2013 Impreza Sport
Dark Grey Metallic
Thanks again. That's what I thought, I guess I just stick with the DRL/High beam for now.
Thanks
Old 01-07-2013, 09:20 PM   #8
tenaciousZ
Member#: 342279
2012 Impreza Sport
Thanks
to be clear, ur using a 9005 LED bulb for ur DRLs that still function as ur high beam? (i.e. stock wiring) does any lighting guru have any input on this? I'd like to have 3000K DRLs/highs but I'm hesitant to buy new bulbs to accomplish this from reading about bulb burnout issues from the difference in voltage.. 2012 impreza, btw.
tenaciousZ is offline   Reply With Quote
Old 01-07-2013, 09:46 PM   #9
winglik
Member#: 317022
2013 Impreza Sport
Dark Grey Metallic
Mine is stock. At day time, the high beams are using as DRL at lower voltage. I was thinking to change it to HID and LED. But it's too much work and cost too much. Most people replaced their high beams bulbs with some cheap LED bulbs from eBay. And change the low beams to HID. Just search JDMSTA's post on his Awesome modification.
Old 01-07-2013, 10:07 PM   #10
tenaciousZ
Member#: 342279
2012 Impreza Sport
Gotcha, thanks.. I've also drooled over that retrofit, btw. phenomenal work.
Old 01-09-2013, 12:14 PM   #11
ZURCALED12
Member#: 309754
2012 Impreza Sport L
Ice Silver Metallic
I would like to explore into making the DRL's 9005 SMD & CREE bulbs. The only problem would be the voltage, since its at low voltage as a DRL and full voltage when used as a high beam. That would require two smart circuits, one for each side. I am going to look into this possibility.
ZURCALED12 is offline   Reply With Quote
Old 01-11-2013, 02:05 PM   #12
ZURCALED12
Member#: 309754
Ice Silver Metallic
PSX24W I have a set of these in H.I.D. and in SMD, If you want to try them out I will ship them to you. Instead of buying these and try to figure out what you want to do. I just want projectors in my fog lights. I have not figured out a way to do this without seperating the lens from the body.
Old 01-11-2013, 03:44 PM   #13
ZURCALED12
Member#: 309754
Ice Silver Metallic
Okay, here is the H.I.D. version of the bulbs in our foglight housings, just keep in mind there is NO defusser on the lens of the foglight, so you are going to get a lot of uncoming drivers flashing their high-beams at you. That is why I want to retrofit my fogs with projectors.
Old 01-11-2013, 03:49 PM   #14
ZURCALED12
Member#: 309754
Ice Silver Metallic
Old 01-11-2013, 03:50 PM   #15
ZURCALED12
Member#: 309754
Ice Silver Metallic
Old 04-24-2013, 02:57 AM   #16
azn87
Member#: 354422
has anyone install hid's into the fog light yet? how bright? how hot? any melting of the housing or lens? and any pics would be more then welcome
azn87 is offline   Reply With Quote
Old 04-28-2013, 11:52 AM   #17
LuckyNYC
Member#: 72812
2013 Impreza Sport
Ventian Red Pearl
Has anyone tried to fit cree led bulbs into the fog light housing? Curious if they will fit due to the weird shape
http://store.ijdmtoy.com/CREE-High-P...s-p/sku-4p.htm
LuckyNYC is offline   Reply With Quote
Old 04-28-2013, 01:11 PM   #18
Timmmaahh
Member#: 352233
2013 WRX Sedan
Rally Blue
Yes I just recently installed hid fog lights (3000K) love it not to hot and I bought yellow lamin-x over the lens also..... ill post a pic later.....
I've tried both hid's and led's in the fogs and can say that the hid's are much better
Timmmaahh is offline   Reply With Quote
Old 04-28-2013, 06:14 PM   #19
LuckyNYC
Member#: 72812
2013 Impreza Sport
Ventian Red Pearl
Did you try Cree LEDs? I'm looking for more light output from the fogs but don't want to go the HID route.
Old 04-28-2013, 06:37 PM   #20
Timmmaahh
Member#: 352233
2013 WRX Sedan
Rally Blue
I've never tried the Cree LED'S,,, I've always got my HID'S and LED'S from diode dynamics, never had a problem with their lights, and have great customer service.
