Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 09-18-2012, 02:23 AM   #1
toxin
Member#: 51259
2007 WRX
СGM
Default knock at low load/RPM
Hi everyone,
I'm breaking in my rebuilt engine after ringland crack. Driving around, I'm seeing some feedback knock corrections at low load and RPM.
The engine was built with stock internals, except the Mahle Powerpak pistons.
According to Mahle, the dish is -22cc vs stock EJ255 pistons -25cc. Thus, the compression ratio supposed to be slightly more than stock EJ255's 8.5
Could this CR increase cause the knock?
Code:
A/F IAM 	RPM	Load 	FbKC FLKC	PSI
13.44	1	1881	0.86	0	0	-4.79
13.21	1	1880	0.83	0	0	-4.5
12.98	1	1910	0.78	0	0	-4.5
12.75	1	1920	0.74	0	0	-4.5
12.63	1	1943	0.72	0	0	-4.64
12.63	1	1948	0.73	0	0	-4.64
12.52	1	1947	0.72	-1.4	0	-4.64
12.4	1	1982	0.71	-2.8	0	-4.64
12.4	1	1991	0.71	-2.8	0	-4.64
12.4	1	2013	0.7	-2.8	0	-4.79
12.52	1	2028	0.71	-2.8	0	-4.79
12.75	1	2032	0.71	-2.8	0	-4.79
12.86	1	2040	0.7	-2.8	0	-4.79
12.86	1	2081	0.7	-2.8	0	-4.79
12.86	1	2104	0.68	-2.8	0	-5.08
12.86	1	2092	0.66	-2.8	0	-5.22
12.75	1	2088	0.66	-2.8	0	-5.37
12.63	1	2113	0.65	-2.8	0	-5.51
12.63	1	2151	0.64	-2.8	0	-5.66
12.63	1	2176	0.65	-2.8	0	-5.66
12.63	1	2164	0.71	-2.8	0	-5.51
12.86	1	2161	0.72	-2.8	0	-5.22
12.98	1	2192	0.78	-2.8	0	-4.79
13.09	1	2233	0.83	-2.8	0	-4.35
13.09	1	2260	0.84	-2.8	0	-4.21
13.09	1	2243	0.8	-2.8	0	-4.21
12.86	1	2259	0.78	-2.45	0	-4.35
12.75	1	2294	0.77	-2.45	0	-4.5
12.75	1	2319	0.77	-2.45	0	-4.64
12.86	1	2330	0.76	-2.45	0	-4.64
12.86	1	2332	0.76	-2.45	0	-4.64
12.86	1	2352	0.77	-2.45	0	-4.64
12.86	1	2383	0.76	-2.45	0	-4.64
12.86	1	2406	0.76	-2.45	0	-4.79
12.86	1	2420	0.77	-2.45	0	-4.79
12.86	1	2424	0.74	-2.45	0	-4.79
12.86	1	2436	0.76	-2.45	0	-4.79
12.86	1	2466	0.75	-2.45	0	-4.79
12.98	1	2491	0.74	-2.45	0	-4.93
12.98	1	2497	0.75	-2.45	0	-4.93
13.09	1	2500	0.75	-2.45	0	-4.93
12.98	1	2537	0.74	-2.45	0	-4.93
12.98	1	2565	0.74	-2.45	0	-5.08
13.09	1	2583	0.73	-2.45	0	-5.08
13.09	1	2588	0.74	-2.45	0	-5.08
13.21	1	2579	0.74	-2.45	0	-5.08
13.32	1	2599	0.75	-2.1	0	-5.08
13.44	1	2634	0.77	-2.1	0	-4.93
13.55	1	2669	0.82	-2.1	0	-4.5
13.55	1	2676	0.92	-2.1	0	-3.92
13.55	1	2688	0.93	-2.1	0	-3.48
13.44	1	2719	0.95	-2.1	0	-3.19
13.44	1	2753	0.95	-2.1	0	-2.9
13.44	1	2755	0.95	-2.1	0	-2.9
13.44	1	2757	0.96	-2.1	0	-2.9
13.21	1	2816	0.96	-2.1	0	-2.9
13.09	1	2841	0.94	-2.1	0	-2.76
12.86	1	2832	0.95	-2.1	0	-2.76
12.75	1	2868	0.95	-2.1	0	-2.76
12.63	1	2894	0.92	-2.1	0	-2.76
12.63	1	2935	0.91	-2.1	0	-2.9
12.52	1	2941	0.9	-2.1	0	-2.9
12.63	1	2934	0.91	-2.1	0	-2.76
12.63	1	2986	0.92	-2.1	0	-2.9
12.63	1	3001	0.9	-2.1	0	-2.9
12.63	1	3028	0.85	-2.1	0	-3.48
12.63	1	3012	0.75	-1.75	0	-4.06
12.17	1	3044	0.71	-1.75	0	-4.5
12.17	1	3079	0.7	-1.75	0	-4.93
12.17	1	3085	0.66	-1.75	0	-5.37
12.29	1	3099	0.44	-1.75	0	-7.4
12.06	1	3034	0.22	-1.05	0	-8.85
11.71	1	3014	0.11	0	0	-10.16
11.37	1	2966	0.06	0	0	-11.03
11.14	1	2931	0.05	0	0	-11.61
11.14	1	2834	0.04	0	0	-11.75
11.14	1	2768	0.05	0	0	-11.9
11.25	1	2701	0.05	0	0	-11.9
11.6	1	2631	0.05	0	0	-12.04
12.06	1	2560	0.05	0	0	-12.04
12.4	1	2454	0.06	0	0	-12.04
12.75	1	2379	0.08	0	0	-12.04
13.21	1	2304	0.11	0	0	-11.9
13.67	1	2260	0.13	0	0	-11.75
Any input will be highly appreciated.
toxin is offline   Reply With Quote
Old 09-18-2012, 08:18 AM   #2
quazimoto
Member#: 70395
I would check the knock sensor. There is a specific way it has to go on. I doubt you are seeing rell knock. Could also be piston slap. Is the car fully warmed up?
quazimoto is offline   Reply With Quote
Old 09-18-2012, 08:27 AM   #3
toxin
Member#: 51259
2007 WRX
СGM
Thanks dude,
I'll see my mechanic to make sure the knock sensor is tighten per specs.
Yes, the car is fully warmed up. I can't notice any piston slap after cold start.
I intentionally bought 4032 alloy pistons for my build to set p/w clearance .0025 to avoid the piston slap.
Anton.
Old 09-27-2012, 02:36 PM   #4
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Can you log again, this time add total timing? Maybe your timing is too low/high in those areas?
wgr73 is offline   Reply With Quote
Old 09-28-2012, 10:45 AM   #5
bmx045
Member#: 262684
2015 Impreza Sport
ISM
knock sensor is extremely sensitive to incorrect torque specs.
bmx045 is offline   Reply With Quote
Old 09-28-2012, 11:01 AM   #6
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
And stray bolts sitting on top of the engine block, I uh figured that out.
lukeskywrx is offline   Reply With Quote
Old 09-28-2012, 11:18 AM   #7
CrashTestRacer
Member#: 66394
2004 WRX Wagon
Don't forget the angle, I just went through that myself:
CrashTestRacer is offline   Reply With Quote
Old 10-08-2012, 12:07 AM   #8
04ScottWRX
Member#: 155412
2004 WRX Wagon
I has to be something acoustic. There is no reason your engine should be knocking under those light loads and rich AFR's----What's up with that anyways---front mount IC?
04ScottWRX is offline   Reply With Quote
Old 10-09-2012, 04:12 AM   #9
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
I agree, it's almost certainly not real knock.
I have a stock 09 LGT ROM in front of me, and it completely ignores the knock sensor below 0.75 g/rev. If yours did too, we wouldn't be having this conversation.
