Old 09-18-2012, 09:06 AM   #1
TADpole
Member#: 32760
2000 '05 FXTi
13' Outback 6 Speed
Default 17x7.5" Wheels that Clears Brembos (STC)
I am looking for some wheels that are lightweight and clear Brembos. They cannot be wider than 7.5" for AutoX STC class. Yes, that means that they are for a GC Impreza. They also need to be light. 17 lbs or lighter please. Which probably means no Rota's. I would be good with Enkei's if they have a set that clears on a 7.5 inch wheel.
I know that Brembos are kinda overkill for a 170 hp, 2800lbs car, but it is my girlfriends car and we do take it to the track fairly often as well. I want to know that she is safe, and I had a set for her to use.
I also know that from reading the sticky on wheels that clear a 2004 STI will fit, but I don't know that you can still buy a lot of those wheels new. It would be really easy if tire rack sold a set that cleared, but I would be willing to buy used too, I just need to be able to find them. So if you know of a wheel, please let me know where I can buy some as well.
TADpole is offline   Reply With Quote
Old 09-18-2012, 09:22 AM   #2
SparkSilver10NM
Member#: 302438
10 WRX
SS DMrally tuned!
dude, check the for sale area for wheels right on this site. I found 5 04 bbs sti wheels used on the first tww pages.
I'm not gonna flame you for not searching, but be warned. Others here will eat you alive for this kind of post. good luck searching.
SparkSilver10NM is offline   Reply With Quote
Old 09-18-2012, 09:26 AM   #3
TADpole
Member#: 32760
2000 '05 FXTi
13' Outback 6 Speed
Thanks, I should have wrote that I don't want +53 offset wheels. This car came with +53 stock wheels and I don't want them even closer to the suspension (because of wider wheels and tires). If you have ever owned a GC, you would know that it is very tight in the wheel wells, even on 225 tires without pulling. I want around a +45 offset.
Old 09-18-2012, 09:28 AM   #4
Mach V Dan
Member#: 12029
Rota Group A 17x7.5" fits.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 09-18-2012, 02:04 PM   #5
TADpole
Member#: 32760
2000 '05 FXTi
13' Outback 6 Speed
Thanks Dan, I may have to use Rota's but trying to find something lighter for now.
Old 09-18-2012, 02:12 PM   #6
Badler
Member#: 133597
Sounds like you have very specific needs. Have custom wheels made.
Badler is online now   Reply With Quote
Old 09-18-2012, 02:27 PM   #7
TADpole
Member#: 32760
2000 '05 FXTi
13' Outback 6 Speed
WedsSport SA-70 will fit. I just need to find some of those somewhere. I actually think that tire rack used to sell them, but they don't anymore. I am wondering if a PF01 in a 7.5 width +45 would fit. I know that the 8 inch width in a +50 fits, but that is for 5x114.3.
Old 09-18-2012, 02:37 PM   #8
Badler
Member#: 133597
Are spacers not allowed I assume?
Old 09-18-2012, 02:41 PM   #9
TADpole
Member#: 32760
2000 '05 FXTi
13' Outback 6 Speed
I am actually not sure, but I am obviously being picky and don't want to use spacers. It will be worth it for me to just find a set that fits.
Old 09-18-2012, 03:06 PM   #10
Badler
Member#: 133597
Not really if a pair of 3mm spacers opens you up to easier to get wheels.
Old 09-19-2012, 10:40 AM   #11
rudymcskoody
Member#: 257618
2006 wrx
aspen white
Why not get 4/2 pots instead of brembos?
rudymcskoody is offline   Reply With Quote
Old 09-19-2012, 11:29 AM   #12
TADpole
Member#: 32760
2000 '05 FXTi
13' Outback 6 Speed
Cause I already have brembos.
Also, about the 3 mm spacers, the reason I am posting here is to find something that I do not need spacers for. If I don't find something, then I might have to do that.
Old 09-20-2012, 09:38 AM   #13
TADpole
Member#: 32760
2000 '05 FXTi
13' Outback 6 Speed
Trying to find out if the PF01 17x7.5 +45 fits. If it does then I am getting them.
