Old 09-19-2012, 03:41 AM   #1
Therosser
Member#: 314882
2012 WRX
At the Track Video: In car '12 Wrx Buttonwillow Raceway
Hey Everyone,
I did a 2 day event at Buttonwillow this last weekend and I thought I would share my experience. This was my first time on a proper road course, (some autox)
Track Configuration #1 Counterclockwise
http://youtu.be/bhk-ai86kJo
Words can not explain how much fun I had, after a few sessions learning the track and becoming more comfortable I became more aggressive, and did quite well! Its amazing how much I learned.
Car:
2012 WRX limited
TBE
Cobb intake
TP stage 2 map
Feal Coilovers
Whileline 24mm Front, 22MM rear
18x9.5 with 265-35 Toyo R1R's
Hawk HP+, High temp brake fluid
I timed it to about a 2.19 minute lap which is not half bad on Track configuration 1 CCW!
Feed back appriciated
Therosser is offline   Reply With Quote
Old 09-19-2012, 04:01 AM   #2
Jcorp
Member#: 325395
Nice run and set up. Been thinking of the white line 24mm front, 22mm rear set up like yours, but i'll be running stock suspension. Did you notice a huge difference in the characteristic of the car when you added the anti roll bars? Less understeer due to the larger front sways ? My other option was to go a lil conservative and do 22mm Front/20 rear.
Jcorp is offline   Reply With Quote
Old 09-19-2012, 10:46 AM   #3
mjfubar101
Member#: 132061
2006 STI
Awesome glad you had a great time out there, I wish more subie guys would hit the track. You should check out Extreme Speeds AWD Competition myself and a few others from here are in it. We also compete in their Subie Extreme track day, last time they gave away a bunch of prizes plus it was fun to run with a bunch of subies.
www.extremespeedtrackevents.com
www.subiextreme.com
mjfubar101 is offline   Reply With Quote
Old 09-19-2012, 02:34 PM   #4
Therosser
Member#: 314882
2012 WRX
The 24/22 made a huge difference, The car felt much better. But I did mine along with epic lowering springs at the time.
Stock dampers work well for street use with stock tires, But when you go to a bigger/stickier tire the suspension seems to be over-worked.
www.subiextreme.com
Awesome thanks for the links!!
I May do the subiextreme in Nov, I am doing Laguna Seca next month so I will see if that cures my track day bug for the year. If Not Ill be there!
Old 09-20-2013, 07:54 PM   #5
fiatlux
Member#: 340639
2013 WRX STi Sedan
WR Blue Pearl
How much do you feel the tires, brakes, and coilovers helped? I was at Buttonwillow a couple months ago too and the best I could pull with my stage 2 STi was 2:22 on stock rubber and brakes, Whiteline sways, and RCE springs.
fiatlux is offline   Reply With Quote
Old 09-22-2013, 05:03 PM   #6
mjfubar101
Member#: 132061
2006 STI
Fialux- so much to learn and do without coils. Brakes on are cars are a must go with at least a street/track pad if not just a track pad. With a stage 2 STI you have plenty of power to get you in trouble. Tires ya you can go with a rs3, star spec, kumho xs, nt05 or whatever you would like I recommend going with tire you can flip to get the most use out of it. Buttonwillow is a track with a lot of tricks. And just as a I kinda know what I am doing I have run a 1:55 at brp on street tires in my STI. Also when I was stage 2 with lowering springs I ran a 2:02.
Old 09-22-2013, 07:01 PM   #7
bslate3
Member#: 246271
2011 WRX
How do you like the Feal 441's? What spring rates are you running? I'm looking to get these.
I have a 2011 wrx with the whiteline 24/22 combo and Dunlop z2's. It's a great setup but there is SO much pitch and dive it's crazy.
bslate3 is offline   Reply With Quote
Old 10-13-2013, 04:53 PM   #8
Therosser
Member#: 314882
2012 WRX
Originally Posted by bslate3 View Post
How do you like the Feal 441's? What spring rates are you running? I'm looking to get these. I have a 2011 wrx with the whiteline 24/22 combo and Dunlop z2's. It's a great setup but there is SO much pitch and dive it's crazy.
The Feal 441s are a great 'bank for your buck' coilover. I think the swift springs really make this coilover as well. I am using the default 8k front and rear. I am now running 275 series r888 so I will probably go to 10k springs and have them re damped next year.
I am really impressed with the communication at Feal. I have spoken with Odi a few times with questions and he is very helpful! If you are thinking entry level track\ auto cross coilover I highly recommend the 441's
Old 10-15-2013, 10:18 AM   #9
Teutonic Speedracer
Member#: 333819
2013 WRX Hatch
Ice Silver
Did you log any OBDII data while on track?
Teutonic Speedracer is offline   Reply With Quote
Old 10-18-2013, 03:13 AM   #10
Therosser
Member#: 314882
2012 WRX
No I have not, car is tuned at 300whp and seems to run well. Why do you ask?
Old 10-19-2013, 02:45 PM   #11
Teutonic Speedracer
Member#: 333819
2013 WRX Hatch
Ice Silver
I'm currently on TP stage 2 and thought it might be a bit aggressive for track duty. Was curious to see if there was any knock and what temperatures you saw during an extended session.
Old 10-20-2013, 03:33 PM   #12
Therosser
Member#: 314882
2012 WRX
This thread is dated to last year and at that time I was running the TP tune. It ran well but a few months later I had #4 cylinder ringland failure at the track with the TP tune.
I am by no means blaming it in the tune, I suspect that it was due to not having any sort of catch can/air-oil separator at the time.
Now I am dyno tuned with less boost than the TP And making more power safely. I would recommend highly getting a tune on a dyno if you plan to track the car, also use good oil (I use she'll rotella t6) and an air oil separator.
Old 10-21-2013, 01:23 PM   #13
Teutonic Speedracer
Member#: 333819
2013 WRX Hatch
Ice Silver
That seems to be the consensus. I run T6, have a Crawford AOS V2, and will be getting a new street and track tunes soon. As an added precaution, I also have injectors, killerB combo, dw65, and colder plugs.
Old 10-22-2013, 01:00 AM   #14
Therosser
Member#: 314882
2012 WRX
Very nice looks like you have all bases covered. I try to use about 3-5 gallons of 100 octane at the track too.
