Old 09-26-2012, 04:48 PM   #126
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Fozzy lifted,'01 RS 6spd
The difference in afr from the front o2 sensor and the wideband o2 sensor, then verified with a stethoscope.
theotherguy is offline   Reply With Quote
Old 10-02-2012, 10:03 PM   #127
hardhitter_alert
Member#: 293841
2007 STi
I wrapped the header with exhaust wrap and I'm working on wrapping the turbo. I also fabbed up a cai which lowered intake temps by about 40 degrees. I need to replace my clutch before I can continue testing.
Before CAI:
After:
Exhaust:
hardhitter_alert is offline   Reply With Quote
Old 10-02-2012, 11:13 PM   #128
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
You should really wrap the headers in something that will repel liquids, such as aluminum tape. A leak at that oil filter could spray the header with oil, which will soak into the wrap and start a fire that quite literally can not be put out, and would burn the car to the ground. It's happened before, it'll happen again, and if I hadn't wrapped my header and uppipe in tape it would have already happened to me.
Old 10-02-2012, 11:23 PM   #129
OC_Nooby
Member#: 311781
2003 WRX w STI V8
I had water on hand, it happened to me!
OC_Nooby is offline   Reply With Quote
Old 10-03-2012, 01:57 AM   #130
hardhitter_alert
Member#: 293841
2007 STi
You mean aluminum tape over the header wrap? I don't see the filter leaking but you never know I guess.
Old 10-03-2012, 02:28 AM   #131
JohnRish
Member#: 243144
2007 WRX
urban grey
I second removing the header wrap. Almost burned my car down due to a leak in my oil pressure sender plate. Luckily I had a gallon water jug in the car. They should make flammable wrap illegal. Sorry for ranting on your sweet thread
JohnRish is offline   Reply With Quote
Old 10-03-2012, 08:47 AM   #132
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Yes..
Psychoreo is offline   Reply With Quote
Old 10-03-2012, 09:21 AM   #133
Member#: 51961
2005 STi
2012 WRX
Yes, like this:
http://www.thesuicidaleggroll.com/st...7/DSCN0147.jpg
http://www.thesuicidaleggroll.com/st...7/DSCN0149.jpg
Old 10-03-2012, 08:08 PM   #134
hardhitter_alert
Member#: 293841
2007 STi
Better?
Old 10-03-2012, 08:10 PM   #135
Member#: 51961
2005 STi
2012 WRX
Indeed...that was fast
Old 10-03-2012, 08:23 PM   #136
hardhitter_alert
Member#: 293841
2007 STi
That's how we roll... eggroll style
Old 10-03-2012, 08:41 PM   #137
hardhitter_alert
Member#: 293841
2007 STi
Originally Posted by Aniel-Chan View Post
Someone answer me here please!! http://forums.nasioc.com/forums/newthread.php?=4579871
Thank you!
No...
Old 10-18-2012, 08:29 PM   #138
hardhitter_alert
Member#: 293841
2007 STi
Old 10-18-2012, 08:36 PM   #139
Psychoreo
Member#: 79643
2015 WRX STI
That doesn't look good
Old 10-18-2012, 08:38 PM   #140
silverboost0303
Member#: 83266
2011 WRX Sedan
Wowzers no it doesn't.
silverboost0303 is offline   Reply With Quote
Old 10-18-2012, 08:43 PM   #141
Member#: 51961
2005 STi
2012 WRX
Looks like the heat wrap breaking in to me...looks like it's coming from the header and uppipe. Probably smells like baking bread too. It'll stop after a few miles.
I got a bunch of weird looks the first time I went driving after wrapping my header/uppipe. Sitting at a stoplight with smoke billowing out of my hoodscoop...no cars would pull up next to me.
Old 10-18-2012, 11:21 PM   #142
hardhitter_alert
Member#: 293841
2007 STi
Yeah you got it. I wish I had a better picture because at one point it really looked like it was on fire. It's actually the header and wrapped turbo. I have the stock uppipe. It smells terrible though, not like baking bread.
Old 10-19-2012, 08:41 AM   #143
Alistairh
Member#: 268286
2011 STi
Dark Grey
Last time I broke in exhaust wrap on my DP's, it smelled exactly nothing like baking bread.
Was during the middle of winter too, so I still got the occasional whiff for a couple weeks afterwards.
Alistairh is offline   Reply With Quote
Old 11-06-2012, 12:46 PM   #144
claythrow
Member#: 283663
2004 STI
Root Beer
At what RPM should you be hitting full boost? on your setup vs stock?
Mine stock doesn't make full boost till 3k.
claythrow is offline   Reply With Quote
Old 11-06-2012, 12:47 PM   #145
claythrow
Member#: 283663
2004 STI
Root Beer
Oh, yeah, broken in two sets of heat wrap, both smelled terrible. And I was under the impression that heat wrap was flame proof but I checked mine out and even if you spray it with the sealer it is not flame proof. Time to grab that aluminum tape and go eggroll on it.
