Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 09-19-2012, 11:30 PM   #1
ASF Machine
Member#: 236349
1993 Impreza
OD Green
OMGHi2U ASF Impreza L OD Green "Crotch Car"
This will serve as documentation from commuter zero to 600whp lightweight hero.
Where to begin?
Part way through the beginning, of course.
Car came into my life from a girl the we think might have been a stripper on the other side of the state. Anyway it started life as an EJ18 5 M/T beater AWD sedan.
Later on it was a EJ257-K hybrid sleeper powered by an old school FP Green & E85. Can you say 120+mph traps @ 4800ft above sea level in a turd?
Cobbled together on a fresh out of college & just bought a house budget. Looks yuck and went like yuck.
Here's short dyno vid hanging out with the always wonderful Boost Creep.
Looks even worse next to the R32 GTR.
ASF Machine is offline   Reply With Quote
Old 09-19-2012, 11:43 PM   #2
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Body work & fresh non dented fenders.
Stripped & primed.
Jambs, nooks & crannies sprayed OD green.
Old 09-19-2012, 11:51 PM   #3
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Suspension progress.
Borg Warner EFR 8374 forward facing mockup.
Getting down on some brakes & suspension.
Old 09-20-2012, 12:06 AM   #4
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Engine time:
Engine:
2.33L
EJ257 case ASF sleeved with Dartons
EJ205 late revised oiling, ASF balanced crank
ASF H beam +2mm rods
ASF spec Ross FSR pistons 10.2:1 CR
Total Seal AP Conventional rings
ACL H-series bearings
11mm oil pump
EJ251 SOHC Heads
Assymetric P&P
Radius valve job
Ferrea valves staggered +1/-1mm
ASF Single Spring Kit (70 lbs on the seat, 180+ on the nose)
Ti retainers
Delta 1500hl cams (.490" lift on intake)
ARP2000 Head Studs
Cometic head gaskets
Crawford timing adjusters
Gates blue belt
Early EJ20 oil pickup
ASF Big Plenum intake manifold
FIC 2150 injectors
ZeroDrift Fuel Rails
GM LS2 coil near plug
PTE 6466 .83 T3 hotside
Custom forward facing manifold
We'll begin with weirdo SOHC heads.
+2mm Rod assembly fun
Shorty is together
Old school pickup
Degreeing the cams.
Engine is in, much cleaning to do.
Old 09-20-2012, 12:08 AM   #5
ASF Machine
Member#: 236349
1993 Impreza
OD Green
I always like to design before building.
Old 09-20-2012, 12:15 AM   #6
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Version 8 tranny & R180 to go.
Getting closer on the lift.
Front tie beam is in, EFR is out PTE is in.
Harness & Big plenum NA manifold in the works.
Manifold getting closer.
Cole Mr. JCFabworks, doing up the 4" DP.
DP is in.
DP with twisty dump tube.
Old 09-20-2012, 12:25 AM   #7
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Intake manifold done and induction setup mocked up at an IDRC event.
Intercooler now in the works.
Mean mug.
Old 09-20-2012, 12:29 AM   #8
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Time for cooling system.
Weird, that doesn't look right.
1.25" 6061 into a Mishimoto "Universal" radiator.
Old 09-20-2012, 12:31 AM   #9
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Ready to live on the dyno.
Early morning sneak attack.
Old 09-20-2012, 12:43 AM   #10
ASF Machine
Member#: 236349
1993 Impreza
OD Green
On our dyno. Don't be alarmed by the smoke as we still haven't sorted our oil return lines; Turbowerks said the scavenge pump should do its job with a -6 return, PTE says to run -10.
A little test drive.
As she sits we're at 59Xwhp @ 28 psi revving out to 8000 rpm. Stay tuned for updates.
Old 09-20-2012, 11:23 AM   #11
biodude
Member#: 271720
I was just reading through Killer B's low front mount thread in proven power bragging, and I was wondering if you had anything on yours posted..
and like magic. it appears.
biodude is offline   Reply With Quote
Old 09-20-2012, 03:29 PM   #12
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Any more pictures of the polyquad style head work?
Crystal_Imprezav is offline   Reply With Quote
Old 09-20-2012, 05:50 PM   #13
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Maybe? :ninja:
Old 09-21-2012, 10:55 AM   #14
motohippy
Member#: 225882
2000 OBS
'88 BMW K75S
I don't know exactly why, but this project is making me giggle. Pure nutty awesomeness!
motohippy is offline   Reply With Quote
Old 09-21-2012, 02:35 PM   #15
wtyree
Member#: 29879
2002 WRX Wagon
subscribed
wtyree is offline   Reply With Quote
Old 09-22-2012, 03:42 PM   #16
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Whoops!!!....good thing for rev limiters and cat like reflexes.
Old 09-25-2012, 11:55 AM   #17
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Couldn't hold teh boost? Blew the throttle body right off?
geronimo81 is offline   Reply With Quote
Old 09-26-2012, 12:23 PM   #18
ASF Machine
Member#: 236349
1993 Impreza
OD Green
TB & flange was intact, it blew the flat top of the plenum box off. Attribute that my overuse of the smoothing tools.
Old 09-26-2012, 03:04 PM   #19
Mishimoto
NASIOC Manufacturer
Member#: 207954
Awesome build! Subscribed.
Mishimoto is offline   Reply With Quote
Old 09-26-2012, 11:37 PM   #20
cineris
Member#: 263329
2011 Impreza WRX
Fuuuuun subscribed.
cineris is offline   Reply With Quote
Old 10-06-2012, 02:48 AM   #21
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Maiden voyage down the 1320' was [email protected], slip picture will be posted when I get to a PC.
There's more in it.
Not too bad for a lowly SOHC.
Old 10-06-2012, 05:58 PM   #22
c1iffyp
Member#: 334272
2004 WRX
Off-White-Grey
Saw where you were doing some welding, Just wanted say I AM SUPER JELLY!!! I wish I had the resources to do that! Loving the car! Great work. Subscribed!!
c1iffyp is offline   Reply With Quote
Old 10-07-2012, 06:02 PM   #23
25rsti
Member#: 166324
The fact that it's SOHC is what's making this thing incredible! Good work.
Old 10-08-2012, 02:03 PM   #24
davetsbass
Member#: 169729
2002 a6 2.7t
There's more in it.
That time has got to be up there with the fastest impreza in CO..
davetsbass is offline   Reply With Quote
Old 10-08-2012, 08:48 PM   #25
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Quickest CO Subie was [email protected]...
