Old 12-12-2006, 09:49 PM   #1
decay
Member#: 107265
2006 2.5i sedan
Something Grey Metallic
Default Intake on my 06 2.5i w/pics
I recently had an intake installed on my stock 06. It was put on Saturday at All Aspects by Vern. He pieced it together himself and did a great job. I've been driving for work and have traveled around 100 miles with it on. The car is noticeably quicker and sounds pretty neat .
He did a base line and a dyno run after putting it on.
Please excuse the night shots. I decided to take these at the last minute.
He t'd off the two valve cover and the crank case breather lines and ran then into the intake.
to keep the filter from moving he attached it to a bolt right below it.
he did a great job and I'm definitely going back there for anything else. I can't wait for Kienan to get the OpenECU to get it tuned and see what happens.
decay is offline   Reply With Quote
Old 12-12-2006, 10:25 PM   #2
lYNEl
Member#: 134706
2007 Forester X
What type of Intake is that? who makes it I mean
lYNEl is offline   Reply With Quote
Old 12-12-2006, 11:21 PM   #3
SubaDuba420
Member#: 102793
2008 STi
Very nice, thanks for the pics & driving impressions, keep us updated. I'll be installing one of these on mine this weekend, as well as installing my Tactrix cable to start data logging.
P.S.:quick tip since I don't see one, get a grounding kit installed, and make sure 1 of the wires attaches to the bolt holding the throttle body on. Doesn't fix the DBW issues, but I noticed an improvement in throttle response.
SubaDuba420 is offline   Reply With Quote
Old 12-12-2006, 11:32 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
But .... but ... but ... the stock intake is better! If you remove the torque box you'll lose low end torque!! My butt dyno says so!!
Nice to see further proof that all the naysayers that claim aftermarket intakes are bad have no idea what they're talking about. Note that the AFR curves for the two runs are essentially right on top of each other, which shows that the gains you're seeing are strictly from making it easier for the engine to suck air in. That's just basic Engine Mods 101, but so many people here (for some reason) don't believe it.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 12-12-2006, 11:39 PM   #5
midnighted
Member#: 131869
2002 BMW M3
Topaz Blue
wow thats a nice gain. How much did it set you back?
midnighted is offline   Reply With Quote
Old 12-13-2006, 12:00 AM   #6
sc00ter
Member#: 117767
2007 WRX Limited
OBP - VF48
Yeah I don't care what anyone says, after market CAI and SRI make a noticeable difference
sc00ter is offline   Reply With Quote
Old 12-13-2006, 02:16 AM   #7
J-Chow
Member#: 104722
2006 2.5i - Gray
NO MORE MODS! I'm Done!
very nice! Think you could possibly get some close ups and/or clearer pics? I might wanna do something like that with a buddy of mine. But I can't see where all the connections are going to in the above pics
J-Chow is offline   Reply With Quote
Old 12-13-2006, 03:51 AM   #8
X4 SRT
Member#: 40636
2001 2.5 RS Coupe
Those are some really good gains for an intake. Almost 15whp, and about 12 lbs/ft torque to the wheels is nothing to sneeze at. The new 2.5i seems to be responding really well to mods. Would be interesting to see the gains with an intake, full exhaust, and some sort of em. Keep up the good work.
X4 SRT is offline   Reply With Quote
Old 12-13-2006, 10:43 AM   #9
Sir-Knight
Member#: 73636
2007 Impreza 2.5i SE
newport blue pearl
is there any danger of that thing sucking in water where it is?
Sir-Knight is offline   Reply With Quote
Old 12-13-2006, 10:57 AM   #10
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
98 RSti in the works
You wouldnt happen to know what thats giving you at the crank would you?
evan_impreza is online now   Reply With Quote
Old 12-13-2006, 10:58 AM   #11
imprezaowner27
Member#: 131299
2006 Impreza
i want one of these, but it requires some fabrication....something im not so good at.
imprezaowner27 is offline   Reply With Quote
Old 12-13-2006, 11:02 AM   #12
hawker800mech
Member#: 53923
2004 Impreza TS
I did an eBay custom intake to my wife's 06 Legacy and noticed a nice power increase. Nice to see that it's proven on paper. There is a thread about it on legacygt.com. Bunch of people have done it. I'll be doing one to my new Tribeca soon, too.
My question is, what did he use for the MAF housing?
hawker800mech is offline   Reply With Quote
Old 12-13-2006, 11:37 AM   #13
SubaDuba420
Member#: 102793
2008 STi
I believe it's the stock section with an adapter for the filter and the silicone coupler attaching the tube on the other side. Probably a good idea, perhaps better than a true aftermarket intake that would mount it directly in the intake tube, since I believe changing the diameter of the tube the MAF is mounted in could throw off the readings.
"You wouldnt happen to know what thats giving you at the crank would you?"
based on factory specs of 173hp/166tq at the crank stock it would extrapolate out to approx. 190hp/181tq based on his stock VS intake figures.
Old 12-13-2006, 11:40 AM   #14
sc00ter
Member#: 117767
2007 WRX Limited
OBP - VF48
Not at all, water doesn't typically reach the top of the engine bay unless you wanna drive into a lake.
Old 12-13-2006, 12:55 PM   #15
decay
Member#: 107265
2006 2.5i sedan
thanks for all of the positive input and i'm glad to see so much interest so quickly. it gives me hope for the NA people.
lYNEl: the intake was put together by a guy Vern at a local shop, All Aspects.
SubaDuba420: Good luck with the install this weekend. if you have any questions feel free to ask in this thread and I'm sure Vern (Vmiz on the board) would be willing to help, and i will if i can. I'll definitely look into the grounding thing. thanks for the advice. You are correct that the stock MAF housing was used and how it was used.
J-Chow: I'll try to get some clearer daytime pics when i have the time, i just figured something was better than nothing for now.
Just on for a break at work for a sec, i'll check back later today when i get the chance.
Old 12-13-2006, 01:56 PM   #16
SiFuSpEc
Top Scoob 008
Member#: 77299
'05 2.5RS
#78 ST, MAXIMUM ATTACK!
+1 Patrick Olsen,
Thank you for taking the time to dyno before and after.
SiFuSpEc is offline   Reply With Quote
Old 12-13-2006, 04:15 PM   #17
Dash_Martino
Member#: 78728
04 STi
wowweee nice gains! I would think the Injen intakes would give similar if not greater gains!
Dash_Martino is offline   Reply With Quote
Old 12-13-2006, 04:23 PM   #18
tacomaprime
Member#: 70572
2005 Tacoma
Pat Olsen
I thought people said that were talking about intakes on the WRX and STI. He has a 2.5I. Big difference.
tacomaprime is offline   Reply With Quote
Old 12-13-2006, 04:33 PM   #19
cmiovino
Member#: 134005
2004 WRX Premium
Yea, that's a great gain for just an intake. Looks like he does good work . Have fun with it.
Old 12-13-2006, 06:53 PM   #20
v8_killa
Member#: 121536
06 2.5i R.I.P. STi
man, must be nice. i wish i could have those gains at my altitude.
v8_killa is offline   Reply With Quote
Old 12-13-2006, 10:30 PM   #21
SiFuSpEc
Top Scoob 008
Member#: 77299
'05 2.5RS
Nope, once speculation spread; ppl assumed he was right, started to spread the word and none backed it up
Old 12-13-2006, 11:30 PM   #22
redevil
Member#: 112637
2008 Forester 2.5 XT
Dark Grey Metallic
Oh I so need to do this to mine!
redevil is offline   Reply With Quote
Old 12-14-2006, 12:48 AM   #23
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
That's quite a gain from just an intake. Me wants.
Counterfit is online now   Reply With Quote
Old 12-14-2006, 01:21 AM   #24
l67cooled
Member#: 134812
2006 2.5i
Grey
If there is interest in having these made specifically for our 2.5i's let me know. If needed I can have a prototype out in 2 weeks . Will look very simular to one posted above. I will also just have a adapter and filter kit so you can just use stock intake tube.
Props on the dyno results. I must say im very suprised. Never seen a NA car so restricted through the airbox before. Looks nice.
l67cooled is offline   Reply With Quote
Old 12-14-2006, 01:29 AM   #25
redevil
Member#: 112637
Dark Grey Metallic
Be interesting to see one made. Keep us posted
Will this bolt on my 06 2.5i? jphillis89 Normally Aspirated Powertrain 9 03-17-2010 06:30 PM
Question on my 2007 2.5i Intake Install LD VADER Normally Aspirated Powertrain 8 11-08-2008 02:16 AM
05 wrx sideskirts on my 06 2.5i LandoCommando Interior & Exterior Modification 3 04-09-2007 07:49 PM
06 WRX rsb onto my 06 2.5i lethal1 Brakes, Steering & Suspension 5 09-04-2006 06:25 PM
need help on an 05 injen intake install on an 06 2.5i skribblez32 Normally Aspirated Powertrain 3 08-23-2006 08:11 PM
Message Board Statistics All times are GMT -4. The time now is 10:12 PM.
