Welcome to the North American Subaru Impreza Owners Club Friday October 28, 2016
Old 05-09-2001, 11:33 PM   #1
Member#: 2053
Post question about the steering in my 65' mustang..
ok it don't have power steering..
when i go over a small hill in the road at say 50+ Mph i can "feel" the wheel sort of wiggle in my hands and the tires actually MOVE directions, and the tires squeal like crazy..
it has the same shocks on the car that it had in 1965 i believe,
so i will be putting new ones on it this weekend, could that be whats causing my steering problems?
or is it normal for this to happen since it is such an old car??
or is it niether, and i should have my whole frond end checked??
when i let go of the wheel on a str8 road it stays str8 and doesnt pull..
~~PeAcE~~ John www.impreza25RS.cjb.net
SuBaRu-ImPrEzA_RS is offline   Reply With Quote
Old 05-10-2001, 12:07 AM   #2
Member#: 524
04 STi
Could be the rack isn't in very well, or your alignment is REALLY screwed. My SHO had an interestign alingment and over speedbumps the steering wheel would turn 90 degrees to the right. It would do this regardless if you were holing on or not so you learn quickly to let go as the car still would go straight and it hurts alot less. $40 and a day later the alignment shop had the car to where the steering wheel didn't move at ALL over speedbumps!!!
XT6Wagon is offline   Reply With Quote
Old 05-10-2001, 12:39 AM   #3
Member#: 2272
2016 Commodore SS
Heron Blue
We have a 65 mustang too (Auto, V6, Power steering and Knock-Off hup caps... thats about it) and it just drives like crap! Thats your problem
I notice that same thing though, its just the car showing its age...
Old 05-10-2001, 12:46 AM   #4
Member#: 3346
In before the move..
Adrian128 is offline   Reply With Quote
Old 05-10-2001, 05:05 AM   #5
Member#: 2715
70 911T
Sure a 35+ year old car won't handle like a new one - so what?
Seriously, I would check the tie rods and ball joints for wear and overall loosening. Also check the steering box (this doesn't have rack & pinion). Definitely replace the shocks and all the suspension rubber. Fortunately with Mustangs there are numerous aftermarket suppliers - you could even go with polyurethane bushings if you wanted. Once all that's done do an alignment. Check the tires for uneven wear. If you have bias plies on there, switch to radials. Authenticity nuts will scream but if it's a driver you'll be glad for it.
Just a few random thoughts from someone who owned one.
lark6 is offline   Reply With Quote
Old 05-10-2001, 05:10 AM   #6
Member#: 2196
well I had something similar going on in my '69 malibu, and it turns out one of the a-arm bushings had COMPLETELY dry-rotted and it was allowing the a-arm to move about a quarter inch in each direction... no fun at all. Anyway, you should check them and replace with polygraphite ones if they are bad.
ins8ibl is offline   Reply With Quote
Questions about Royal Purple in my 2007 (yes, i read the sticky) GreenLantern Service & Maintenance 25 10-29-2008 08:31 PM
Question about the engine in the 99 Legacy GT josh04 Legacy Forum 4 08-15-2005 10:24 PM
Question about the turbo from my 99 Integra GSR. breathinez General Community 2 05-12-2005 10:21 PM
some question about the set up my friend is getting WuWrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 03-22-2004 05:57 PM
I Have A Good Question About The Antenna On My WRX? tricked-out Car Audio, Video & Security 2 04-07-2002 08:19 PM
