Old 10-03-2012, 01:20 PM   #26
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
I noticed oil consumption can also depend on driving. I burned some oil heading through the mountains with a lot of boost and then engine braking.
Since getting back I haven't burned any at all for a couple months. 10C of temp difference isn't going to change how much oil you burn.
tebriel is offline   Reply With Quote
Old 10-03-2012, 01:24 PM   #27
bako
Member#: 226211
2002 impreza WRX JDM
blue
yes, 10c won't change anything, but I think if turbo can be overheated and burn oil after that
bako is offline   Reply With Quote
Old 10-04-2012, 12:02 PM   #28
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
i think you dont know what the hell you are doing
Old 10-04-2012, 07:05 PM   #29
Newkid17
Member#: 334165
I agree a PVC valve is cheap and easy to change! As well as a good place to start!
Newkid17 is offline   Reply With Quote
Old 10-05-2012, 12:36 AM   #30
bako
Member#: 226211
blue
you think turbo can't leak oil from hot side to exaust? (yes, turbo can't BURN though, it can leak )
just want to know if such a consumption (if this is turbo related) can be seen from downpipe side when I remove it...
Old 10-05-2012, 12:49 AM   #31
chrisparno
Member#: 334185
i had the same problem and it led to me blowing my number 2 piston and it went through my oil pan not the block. but im looking for a new engine and dont know if i can put a 2000 impreza engine in a 2002 impreza wrx
chrisparno is offline   Reply With Quote
Old 10-07-2012, 09:59 AM   #32
itr.#1446
Member#: 162447
03 Wrx
Sonic yellow
Well I replaced the turbo with a vf43 that was used, rinsed the intercooler out with gas, put a new pcv valve in and changed the oil from Mobil 1 which the po used to rotella t6 and all seems good again ( crossing fingers). We will see on start up this morning how it goes.
itr.#1446 is offline   Reply With Quote
Old 10-09-2012, 03:09 AM   #33
bako
Member#: 226211
blue
report back after 300 miles too.
Old 10-09-2012, 03:28 AM   #34
zashoe
Member#: 329523
2002 Impreza WRX
World Rally Blue
you should be fine now, provided you got a tune. my wrx looked like a smoke machine til i replaced the turbo. not a bit of smoke since!
zashoe is offline   Reply With Quote
Old 10-09-2012, 10:42 AM   #35
itr.#1446
Member#: 162447
03 Wrx
Sonic yellow
Yes my car was tuned by Sti Mikey..... I also forgot to mention the next day after I got it running I made a vent to atmosphere catch can for the block to inlet and valve covers to inlet lines until I can afford something nicer, turbo put me back for alittle. I did not want to start building a film back up in the freshly cleaned intercooler.
Old 10-14-2012, 12:23 PM   #36
bako
Member#: 226211
blue
report back please
Old 12-13-2012, 09:28 PM   #37
devilmademedoit
Member#: 289267
03 wrx
wrb
Any update on this? I have same symptoms . Gonna do compression test this weekend and if ok, setting up appointment for a leak down test. I thought it was head gaskets but now I'm second guessing myself. Hope it's not rings.
devilmademedoit is offline   Reply With Quote
Old 12-14-2012, 06:12 PM   #38
Cois32
Member#: 294755
2004 Impreza WRX
WRB vf39'd
Originally Posted by scooby717 View Post
I'm interested in seeing if an aos would fix the issue. I have almost the exact same symptoms with excessive smoke on startup and lots of oil in my intake track. This must have been happening to my 04 wrx for some time because when i first removed the hard black line that attaches to the tmic, it was 75% clogged with gunk. Compression test came out good, and it wasn't the turbo for i replaced that as well. I will be replacing the pvc to see of that helps
valves seals. happened to me with good compression and a couple turbo swaps
Cois32 is offline   Reply With Quote
