Old 09-21-2012, 07:07 AM   #26
epistax
Member#: 224197
2015 435ix GC
Imperial Blue
Originally Posted by HinshawWRX
Define "heavily modified." From the sounds of the OP, it means anything past "stage 2."
I think some perspective is required here. My parents consider my Impreza heavily modified because it has mudflaps and I took out an unnecessary cargo shield thing.
epistax is offline   Reply With Quote
Old 09-21-2012, 08:17 AM   #27
stop_rallytime
Member#: 225515
Twin scroll 30r. On meth. Fully built bottom end with sti drivetrain 466 whp daily driven 2000 Rs coupe. Plan on being under hood atleast once a day cause **** can hit the fan fast. First motor lasted 30 k but I beat the crape out of it current setup is on 10k buddy had 100k on his wrx with 420 whp it all depends on the owner and how he takes care of it.
stop_rallytime is online now   Reply With Quote
Old 09-21-2012, 08:28 AM   #28
2.5L Monster
Member#: 307177
2k4 WRX/WRB
Shuckin' & Drivin'
My DD set-up...24/7/365. Rain, sleet, snow etc.
- PnP'd HTA68
- aps turbo-back exhaust
- 850cc injectors
- 255lph fuel pump
- downpipe/up-pipe
- aps intake
- V7 STi intercooler
- 3-port ebcs
- perrin turbo inlet
No problems so far.
2.5L Monster is offline   Reply With Quote
Old 09-21-2012, 08:53 AM   #29
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
Originally Posted by silverboost0303 View Post
I don't ever plan on digging into the motor
I don't plan on lowering it period
these two statements plus the fact that it is a 2011 tell me that you should stop your quest now...
if you aren't prepared to build/rebuild the motor, and if you aren't prepared to do suspension, and if you aren't prepared to have any possible powertrain or powerplant warranty claims denied, then you should seriously rethink this. fact of the matter is that even if you are on the best tune and the best behavior possible, **** still happens sometimes. driving a heavily built car daily is not exactly as predictable or reliable as before. if you don't have a fallback car or a rainy day fund, you are going to put yourself in a pretty rough situation.
also, if you aren't fairly knowledgeable in cars, performance mods, and have a slight idea of how and what to log and when, you are going to have a much harder time with this than someone who knows all that stuff.
amalgrover is offline   Reply With Quote
Old 09-21-2012, 10:19 AM   #30
silverboost0303
Member#: 83266
2011 WRX Sedan
Originally Posted by 575rider
If you aren't digging in to the motor, then what is your definition of "heavily modified"? A bunch of bolt ons?
I've had a vf34 set up on my car for over 90k miles with no issues or maintenance that's any different than a stock car. Well, 3rd gear broke but that may have happened with a stock turbo too. I've done a good amount of suspension work, put on 06 WRX brakes, track and autox the car.
I don't consider my car necessarily heavily modified. From someone driving a bone stock WRX it probably sure is, but someone with a forged internals, huge turbo, coil overs, roll cage, DOT tires, meth tuned STI would see it differently.
Why don't you tell us your plans for the car and people with those mods can give you a run down on their cars reliability.
Listen guys, I more or less wanted to hear some of your daily driven beast builds. I never once even said I was going to heavily modify my vehicle. I do not consider where I'm at (stage 2) to be heavily modified. I think the farthest I'll go with my 11' is pump, injectors, and a process west Tmic and a retune....until she's paid off. I know that probably won't reach my goal of 350 awhp, but I'm ok with that at this point. And ill never lower a vehicle in the area in which is reside. I scrape everywhere now lol. The plan is to kind of plan it by ear, because I am addicted to going fast, but I'm not really in a position to go all out at this point, but I hope to be in the near future. However I do appreciate the tips and advice
silverboost0303 is offline   Reply With Quote
Old 09-21-2012, 10:22 AM   #31
silverboost0303
Member#: 83266
2011 WRX Sedan
- PnP'd HTA68
- 850cc injectors
- 255lph fuel pump
- downpipe/up-pipe
- aps intake
- 3-port ebcs
No problems so far.
Nice setups guys!
Old 09-21-2012, 10:26 AM   #32
HighwayStarPP
Member#: 174548
2002 impreza
flat black
Very good points. I hear the kid ran a meth map on empty. He was obviously an idiot.
Wow, that's froggin awesome. All 175k yours?
no just 80k
HighwayStarPP is offline   Reply With Quote
Old 09-21-2012, 10:34 AM   #33
silverboost0303
Member#: 83266
2011 WRX Sedan
Originally Posted by HighwayStarPP
no just 80k
Still, quite an awesome achievement.
Old 09-21-2012, 10:42 AM   #34
07VTRex
Member#: 179023
07 CGM WRX TR
Dom 1.5xtr + PPG's
I dont know what counts as heavily modified, as i am so used to my car it doesnt "feel THAT modified" anymore...until i drive a regular car again, at which point i cant wait to get back in my suby!
these are all the mods ive one over the last 5 years. i stopped counting after i broke the $20k mark in mods...
Suspension/Divetrain
ANDREWTECH built ppg 5 speed w/ helical cut gears 1-4
ACT heavy duty street clutch
RCE Yellow Springs
TOKICO D-Spec adjustable struts
GROUP N Top Hats
TORQUE SOLUTIONS Engine mounts
TORQUE SOLUTIONS Transmission mounts
STI Aluminum control arms + free castor mod
SPT Subframe Brace
SPT Short shifter kit/linkage
KARTBOY Shifter bushings (front + rear)
KARTBOY Rear subframe lock bolts
KARTBOY Endlinks (front + rear)
KARTBOY Pitch stop mount
WHITELINE 24mm adj. Front Swaybar @23.5mm
WHITELINE 22mm adj. Rear Sway bar @23mm
WHITELINE Steering rack bushings
WHITELINE Anti-Lift Kit (comfort)
WHITELINE Roll-Center Adjusters and Bump Steer Kit
MSI Lateral links + TiC lateral link bushings
TiC X-Brace
TiC Shifter pivot bushings
TiC Shift linkage bushings
TiC Differential Outrigger Bushings (comfort)
TiC Rear Differential Mount Bushings (comfort)
TiC Transmission Crossmember Bushings
TiC Fender Braces
SUPERPRO Trailingarm Bushings (front + rear)
SUPERPRO Front inner control arm bushings
IXIZ Clutch Stop
VOLK Racing Le37t 17x8.5 +50 with 255/40/17 Hankook Evo (summer)
04 STI BBS wheels 17x7.5 +53 witth 225/45/17 Dunlop Wintersport 3d (winter)
Alignment set at 0o toe F/R, -2o camber Front, -1o camber Rear
Power
Blouch Dom 1.5xtr w/ 8cm housing and ceramic coated hotside
Deatchswerks 750cc injectors
STI TMIC
TurboXS uppipe w/ Tial 44mm EWG
HKS flat flange downpipe 3” (catless)
MADDAD midpipe 3”
STROMUNG axleback 3”
GRIMMSPEED Ceramic coated crosspipe
GRIMMSPEED port and polish stock manifold
GRIMMSPEED 3port electronic boost control solenoid
SPT Short ram intake (wrapped in heat reflective tape)
SPT Intake heat shield
SPT Turbo heat shield
SAMCO Turbo inlet hose
GIZZMO phenolic thermal intake manifold gaskets
WARLBORO 255 fuel pump
STI intercooler splitter and bellows
Brakes
BF GOODRIDGE Stainless Steel Brake Lines
HAWK HPS brake pads
PERRIN master cylinder brace “Stiffi”
ATE Superblue Racing Brake Fluid
Exterior
02-05 WRX sideskirts w/ front aero guards and side strakes
WRX rear spats
D.I.Y. cleared and painted headlights black
04/05 STI Tail lights w/ tinted inserts
USDM WRX fog lights (yellow PIAA bulbs)
20% tint
LED parking light and license plate light conversion
Replica STI polyurethane front lip
WRX front license plate delete
RALLYARMOR UR mud flaps
Grillcraft lower and upper grills (black)
SharpHID conversion kit 35w 4300k
Interioir
STI “Cherry Blossom Red” Pedals
STI Floor mats
JDM red hazard button
JDM STI 5-speed gear pattern
STI shifter surround (polished)
"Bugeye" front seats
JDM v7 STI rear seats
D.I.Y. Plasti-Dip interior trim black (dash panels, vent rings, A/B/C pillars)
D.I.Y. Black Sueded headliner
Bunches of shift knobs
DEFI Boost + Oil Press. + EGT gauges in ATI pod
AEM UEGO Wideband gauge in MB pod
ALPINE CDA-9887 head unit
MEMPHIS M-Class speakers (front + rear)
ALPINE 500watt amplifier
MOMO/POLK AUDIO 10” subwoofer
picture is from 6 months ago. i have since removed the aero guards and rear strakes....considering putting the rear strakes back on. should i???
07VTRex is offline   Reply With Quote
Old 09-21-2012, 10:50 AM   #35
aggie113
Member#: 146311
Saab '05 HTA68 Built
2.5L E85 6MT > STI :)
Built STI shortblock hybrid 2.5L with built 6MT. Daily drive it on e85 tune. I only wish this town had on ramps to get the most fun from the tune but that's not the car's fault
Probably have under 12K miles on this last rebuild. Does come with a price, I've probably put about 15k more than I expect to spend into this car due to previous transmission/engine issues.
aggie113 is online now   Reply With Quote
Old 09-21-2012, 12:07 PM   #36
silverboost0303
Member#: 83266
2011 WRX Sedan
RCE Yellow Springs
GROUP N Top Hats
SPT Subframe Brace
WHITELINE 24mm adj. Front Sway bar @23.5mm
TiC X-Brace
TiC Fender Braces
SUPERPRO Trailing arm Bushings (front + rear)
IXIZ Clutch Stop
Power
STI TMIC
MADDAD midpipe 3”
Brakes
HAWK HPS brake pads
Exterior
WRX rear spats
20% tint
Interioir
STI Floor mats
Beautiful car dude. Not really a fan of hawkeyes but that thing is art. Put the rear strikes back on.
Old 09-21-2012, 12:14 PM   #37
Davenow
Member#: 23676
This monster was my daily driver
I had more money in my heads alone than what most have into their subies Ok maybe not than most, but more than a lot. Total investment, including the 26k I paid for the car itself, came out to a little over $60k.
Yeah, 34k in mods.
Old 09-21-2012, 12:15 PM   #38
silverboost0303
Member#: 83266
2011 WRX Sedan
I hear ya, that's why it's a tough decision. I'll probably wait until the car is paid off to go hard or go home
Old 09-21-2012, 12:26 PM   #39
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yeah, 34k in mods.
This looks nice. I like fast Foresters! What fuel did you have it on? Any dyno numbers or 1/4 slips?
xluben is offline   Reply With Quote
Old 09-21-2012, 12:31 PM   #40
Davenow
Member#: 23676
Pump plus meth injection. No dyno numbers because dynos are for dyno queens.
It got wheelspin from a roll in 4th gear Based on my experience building other high end subies for customers, 500whp is a safe assumption.
Old 09-21-2012, 12:53 PM   #41
07VTRex
Member#: 179023
07 CGM WRX TR
Dom 1.5xtr + PPG's
i think that will be my afternoon activity after work today
ALSO, that forester's idle is just ferocious. i cant imagine how much that thing hauls
Old 09-21-2012, 12:56 PM   #42
Davenow
Member#: 23676
In theory, rolling to about half throttle in 6th gear may or may not have gotten it up to a completely arbitrary 147.9mph (gps high score on my head unit, had it ever happened) while feeling like it was in a gentle cruise.
Of course this is just speaking hypothetically.
They were Cosworth cams. With this much porting work on the heads
With Ferrea stainless intake valves and Manley inconel exh valves.
And this turbo setup
Old 09-21-2012, 01:08 PM   #43
A Fatal Ode
Member#: 243616
2010 WRX 336/384
2006 STI 627/484 2015 BRZ
A Fatal Ode is offline   Reply With Quote
Old 09-21-2012, 02:09 PM   #44
pearljam11
Member#: 113335
13 WRB BRZ Limited
05 STi AgileTuned 320/352
- PnP'd HTA68
- 850cc injectors
- 255lph fuel pump
- downpipe/up-pipe
- aps intake
- 3-port ebcs
No problems so far.
A good setup nonetheless... But that's a basic turbo upgrade with supporting mods. There's not really a built car. Built - motor work. I think this thread is about reliability on built motors and alternative fuels.
pearljam11 is offline   Reply With Quote
Old 09-21-2012, 02:19 PM   #45
silverboost0303
Member#: 83266
2011 WRX Sedan
I respectfully disagree sir. The point of this thread, was basically geared towards anyone around stage 3 or higher. In that way I kinda left it open ended just to hear set ups and mileage. But built motors and alternative fuels such as E85 are obviously welcomed.
Old 09-21-2012, 02:38 PM   #46
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Wheelspin in 4th? Seems like bad tires or wet roads or something. That looks like an awesome setup, but $34k is a ton of money for 500WHP. I'm guessing that not all of that money went into go-fast parts.
Old 09-21-2012, 03:03 PM   #47
shiplemw
Member#: 203905
That's a good guess because you can see coilovers, a sway bar, BBS wheels and Brembos in the photo.
shiplemw is offline   Reply With Quote
Old 09-21-2012, 03:47 PM   #48
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
It is probably possible to spend that much on a built short block, built heads, rotated turbo kit, FMIC, all new fuel setup, etc. But that total probably does include wheels/Brembo's/etc...
Old 09-21-2012, 03:57 PM   #49
Syrius78
Member#: 267996
2011 Wrx
Rallye blue
Originally Posted by onesicksoob
I delivered pizza for several years in a caged, coilovered, ej207'd, seam welded, etc etc etc 95 impreza coupe while on 275/35-18 slicks.
Great!!! The only pizza delivery here got some beat up tercel (yes pre-1998) or cavalier.
Syrius78 is offline   Reply With Quote
Old 09-21-2012, 04:08 PM   #50
Syrius78
Member#: 267996
2011 Wrx
Rallye blue
For your mod I got one rule
Plan for the worse... Or I prefer: ***** will happen. Plan accordingly.
If your pocket cannot handle a break down for your daily drive, don't go that way. Everything can go wrong even is everyone run ok.
Modding is a uncertain hobby. Sometimes it's strong sometime it can easily broke.
Sure monitoring your car is better, but nothing can guarantee it.
If you have an accident does insurance cover the mod? If not it cold cost you a lot of money to repair.
