Old 09-20-2012, 07:47 PM   #1
acswatdouwant
Member#: 313938
2007 wrx
wrb
Default 06/07 wrx retrofit question
I've tried searching on google and here with no real answer.. Can anyone tell me what bixenon projectors will fit in my headlights?
acswatdouwant is offline   Reply With Quote
Old 09-20-2012, 08:29 PM   #2
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
what were your search parameters?
searching "06 retrofit projector"
yields a number of threads.
http://forums.nasioc.com/forums/show....php?t=2333721
that one is a FS on a quad projector setup
http://forums.nasioc.com/forums/show...ofit+projector
another older FS thread
There are a bunch of retrofit threads that may have info in them.
Not that hard to find, if you put forth the effort.
aerosaaber is offline   Reply With Quote
Old 09-20-2012, 10:21 PM   #3
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Almost any projector will fit, the question is how much work do you feel like doing and how much of the housing you are comfortable cutting away.
minifreak is offline   Reply With Quote
Old 09-21-2012, 12:01 PM   #4
acswatdouwant
Member#: 313938
2007 wrx
wrb
Thanks for those links. Apparently I suck at searching :/
Old 09-23-2012, 02:56 AM   #5
Ysidro
Member#: 197418
07 WRX Ltd
The Mighty Evo;Fun CRZ
Morimoto Bixenon with fx-r lens ftw!
Ysidro is offline   Reply With Quote
Old 09-23-2012, 03:06 AM   #6
acswatdouwant
Member#: 313938
2007 wrx
wrb
I didnt know the lenses were interchangeable. I thought the lenses were just a clear version of the oem ones that come on the projector
Old 09-23-2012, 09:43 AM   #7
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Old 09-23-2012, 06:33 PM   #8
Ysidro
Member#: 197418
07 WRX Ltd
Yes they are. As long as its 2.5 " it will fit.
Old 09-23-2012, 06:56 PM   #9
infinite012
Member#: 74392
2015 Forester
Incorrect. There are many different 2.5" lenses because each projector design uses a different focal length. Think of it like eye glasses. You can have the same frame shape/size, but different lenses to suit different eyes.
infinite012 is offline   Reply With Quote
Old 09-23-2012, 07:02 PM   #10
Bubakanush
Member#: 209975
2016 WRX
LBP
Yep, this. Not every 2.5 will fit. I personally have the TSX lenses on mine and they're great. Swap your lenses, OP. Trust me you will love it.
Bubakanush is offline   Reply With Quote
Old 09-24-2012, 05:30 PM   #11
acswatdouwant
Member#: 313938
2007 wrx
wrb
I was thinking about changing lenses but if I have the light opened up and the money for new projectors then why not. Any recommendations on good bixenon projectors? Best bang for the buck, sharpest cutoff etc.
Old 09-25-2012, 09:38 AM   #12
Bubakanush
Member#: 209975
2016 WRX
LBP
Your WRX already has somewhat decent projectors that will have a much improved performance if you do a lens swap. Like I said, I put the TSX clear lens swap on my lights and it made a huge difference, cutoff is perfect and has the "rainbow" line at the top, which I love. Not sure why you are looking for bixenon projectors though as our cars have a separate projector for the low beam and a jewel style high beam.
Old 09-26-2012, 02:15 AM   #13
acswatdouwant
Member#: 313938
2007 wrx
wrb
Well I was going to do bixenon mainly because I think it would be sweet but ill start off with lenses and if those don't end up being enough then ill follow through with a complete retrofit.
Old 09-26-2012, 09:53 AM   #14
infinite012
Member#: 74392
2015 Forester
Just swapping the lenses on halogen projectors won't do too much to improve your light output. Go for the bixenon projector swap with HIDs and aim them well.
Old 09-27-2012, 12:55 AM   #15
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
You "can" fit 3" projectors into the housing, but I had to extensive trimming of the backing plate and enlarging the shroud. The beam pattern was wider and more even than the other projectors I have used.
TSX/FX projectors are almost a direct bolt in.
The highbeams on the 06/07 are a bit too spot beam pattern in my opinion, the bixenons really complements that.
I am now running the FX projector but wish that I had done the clear lens mod for the better cut-off.
Old 09-28-2012, 12:41 PM   #16
acswatdouwant
Member#: 313938
2007 wrx
wrb
Hmm I guess ill save for the bixenons, school and a season pass just took all my money. I want some really good lights. can you run wires to the jewell style high beam and the solenoid for the projector to have 2 high beams?
Old 09-28-2012, 02:10 PM   #17
alt14
Member#: 271928
2014 WRX Limited
Crystal Black Silica
Do you mean having four projectors that all four bulbs will be on and switching to high beams all the solenoids will switch? If so then yes this can be done with splitters.
Or do you mean just to have the low beam bi-xenon projectors switch to high beams as well as the stock high beams coming on as well?
Either way both can be done, you would just have splitters hooked to the solenoids, to the high beam bulbs then back to the power for them. An extra splitter would be needed for a quad setup
alt14 is offline   Reply With Quote
Old 09-28-2012, 05:57 PM   #18
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
I spliced into the high beam wiring to trigger the shutter on my bi-xenon so I do end up with quad high beams (2x projector 2x reflector).
You can just see the stock highbeam in the centre.
Old 09-29-2012, 01:15 PM   #19
acswatdouwant
Member#: 313938
2007 wrx
wrb
If I had the money for it id do a quad retrofit. But this^ is exactly what I was wondering about. Is it worth it? Can you even tell that the stock high beams are on?
