Old 09-20-2012, 09:15 PM   #1
bmcgovern
Member#: 261947
2012 WRX
Default Cobb stage 2 AEM 93 oct logs 2012
personally these logs look good to me from my experience my a/f is my only concern but according to the cobb video i saw as long as its not past -8.00 im ok. well here are the logs the first one is a 3rd gear pull and then the second is a 2nd gear pull thanks for the insight & help
https://docs.google.com/spreadsheet/...0pWZXZNdEtJWnc
https://docs.google.com/spreadsheet/...lVDc0VIM05GT2c
Mod list Invidia catless dp, forge bpv, AEM cai
bmcgovern is offline   Reply With Quote
Old 09-20-2012, 10:51 PM   #2
kaczmarz
Member#: 307624
2008 WRX Hatch
325/347, 380XT, 8 cm2
Very nice (WOT)!
Monitor your "A/F Learning 1": it should be +/-5%, some say +/- 8%.
Make long log of regular driving.
If "A/F Learning 1" is lower than -8% (too rich) than you have to clean your MAF and air filter, check for boost leak, then adjust your tune.
kaczmarz is offline   Reply With Quote
Old 09-20-2012, 11:57 PM   #3
bacalhau16
Member#: 297565
2011 WRX hatch
Your log looks pretty good. Nothing obscure to me.
Future reference, logs in 3rd gear are your best option.
Also, the whole 8% vs 5%, typically Sti's can reach up to 8% with no concerns and regular wrx's are the 5%. I believe i read that not too long ago.
bacalhau16 is offline   Reply With Quote
Old 09-21-2012, 08:59 AM   #4
Cobb Tuning
Member#: 4803
Logs look good. The A/F Learning has some borderline extreme values - something I would keep an eye on over time. There have been reports of intake tract leaks on brand-new Subarus from the factory. If it gets much worse than -7% (i.e. -8%, -9% etc.), then it would be something to check out.
Bill
Old 09-21-2012, 11:48 AM   #5
bmcgovern
Member#: 261947
2012 WRX
Thanks guys really appreciate the insight I will post up some new logs after 100 miles or so
Old 09-21-2012, 02:38 PM   #6
bmcgovern
Member#: 261947
2012 WRX
Bill
hey bill my A/f today was @ -8.6 so i decided to reflash the car and i drove for about 30miles then re logged here are the new ones and i think they look awesome...input please and thank you btw both are 3rd gear pulls
https://docs.google.com/spreadsheet/...3IzdjNlNE00c2c
https://docs.google.com/spreadsheet/...FpQM0hMMlEzQkE
Old 09-22-2012, 09:07 AM   #7
Cobb Tuning
Member#: 4803
Reflashing the car also clears the fuel trims, so the fact that they are low now does not tell you anything. They can take time to populate accurately. Since you were approaching -9% before and given this is a very new car, you most likely have a boost leak. Apparently, Subaru has been having problems with this from the factory lately. From what I've read from other reporting the issue, it may be the throttle body to intercooler coupler. But, I would consider getting a pressure/smoke test of the intake tract done to find any leaks. The dealership isn't going to care about this unless there's something obvious (like a check engine light or a noticeable noise), so you may be on your own for diagnosis.
Bill
Old 09-22-2012, 03:08 PM   #8
bmcgovern
Member#: 261947
2012 WRX
Bill
so after driving around today i looked at my air learning it is terrible i am going to get this checked out and i have logged it. My question is...is it ok for me to drive no boosting for a few days??
https://docs.google.com/spreadsheet/...jRUUlBBb0VMOWc
Old 09-23-2012, 11:33 AM   #9
Cobb Tuning
Member#: 4803
You'll be fine, just drive conservatively and do not do any heavy throttle runs.
Bill
Old 09-26-2012, 05:16 PM   #10
bmcgovern
Member#: 261947
2012 WRX
Bill
Hey bill finally got a pressure / smoke test done at AMR performance(rob was a great help) I had a huge leak in my Intake mani as well as my BPV so i switched the BPV back to stock and they fixed the intake mani. my A/F learning is still on the extreme side the one of the maps is me cruising the other is a 3rd gear log. Input please (maybe i need a protune) i would like you help thank you
https://docs.google.com/spreadsheet/...F9qdmkyLTM0OEE
https://docs.google.com/spreadsheet/...3hOOVJ4R2l1REE
Old 09-27-2012, 10:24 AM   #11
Cobb Tuning
Member#: 4803
Did you reset the ECU (via troubleshooting menu on AP) or disconnect the car's battery after fixing the leaks?
Bill
Old 09-27-2012, 11:48 AM   #12
bmcgovern
Member#: 261947
2012 WRX
Bill
I reflashed the car it's gone down to -5.5 %learning and in learning c it's -5.4%
Old 09-27-2012, 12:09 PM   #13
Cobb Tuning
Member#: 4803
If you did a reflash (and not a realtime flash) or a reset, then the trims should have started at zero and then started moving at some point once you began driving.
Bill
Old 09-27-2012, 12:12 PM   #14
bmcgovern
Member#: 261947
2012 WRX
Bill
Yes I did reflash the car and now 20 min ago a reset the ecu so on my way home today ill see if it changes back to the same trim... Should I log my cruise driving home?
Old 09-27-2012, 04:36 PM   #15
bmcgovern
Member#: 261947
2012 WRX
so after i did this drove for about 10-15miles high way and here are the logs one cruising on the high way and the other driving around the streets.thanks bill
https://docs.google.com/spreadsheet/...VIwUEw0YXI4QXc
https://docs.google.com/spreadsheet/...DVSMW9zZi1HSVE
Old 09-28-2012, 12:23 AM   #16
bmcgovern
Member#: 261947
2012 WRX
Bill now heres on about 10 more miles added on and it seems to be getting worse again well heres the log i took from the on ramp to getting on the high way
https://docs.google.com/spreadsheet/...1RERHNoM0JDYlE
Old 09-28-2012, 09:38 AM   #17
Cobb Tuning
Member#: 4803
Just keep monitoring it and see where it goes over time (through at least a tank of gas or so). Those values are borderline at this point.
Bill
Old 10-03-2012, 06:55 PM   #18
bmcgovern
Member#: 261947
2012 WRX
Bill
Just an update I decided that the best thing for my car would be a protune seeing that the a/f was not looking good. I brought it over to rob at AMR performance and now I couldn't be happier thanks bill for your help
