Old 09-21-2012, 01:50 AM   #1
bshep211
Member#: 332839
Default Knock & lower DAM in logs
I bought this car a year ago. Its a 05 sti with full exhaust, pop charger intake, BOV & cold air ram from fog light housing. I have audible knock when I am a quart low on oil. The car uses 1 quart every 1500 miles. The motors passed a cylinder compression & leakage test a year ago. The car runs strong. No oil leaks or smells. No smoke on startup. I have had -4 learning knock with dam loss when pushing it hard. I logged a few 3rd gear runs. Here are the logs. Please tell me what you think.
Thank you
bshep
https://docs.google.com/spreadsheet/...0anpIMUE#gid=0
https://docs.google.com/spreadsheet/...RazdSdFE#gid=0
bshep211 is offline   Reply With Quote
Old 09-21-2012, 02:46 AM   #2
addictionsoLA
Member#: 301236
2010 Wrx
Grayish!
Need to make the logs public.
addictionsoLA is offline   Reply With Quote
Old 09-21-2012, 09:09 AM   #3
bshep211
Member#: 332839
Sorry about that. The logs should be public now.
Old 09-21-2012, 09:26 AM   #4
Cobb Tuning
Member#: 4803
Thank you
bshep
Are you using a custom tuned map or our off-the-shelf map? If our OTS map, which map are you running?
Bill
Old 09-21-2012, 02:30 PM   #5
bshep211
Member#: 332839
Bill
I am using stage 2 91 OTS map.
Old 09-21-2012, 02:58 PM   #6
addictionsoLA
Member#: 301236
2010 Wrx
Grayish!
That map isn't made for an intake, and the BOV isn't helping your cause either.
Old 09-22-2012, 08:18 AM   #7
Cobb Tuning
Member#: 4803
Your dynamic advance multiplier (DAM) has dropped very low, indicating that the ECU has perceived a number of knock events. Only the stock or Cobb SF intake is compatible with these maps and because using the wrong intake can potentially cause fueling and ign. timing errors (and knock), the first thing to do would be to switch to one of the supported intakes. I would also reflash our most conservative map, which is the 91ACN. If you have any other mechanical issues, you should fix those now. If you have any un-diagnosed issues (such as a past check engine light), you would want to get those addressed now.
I would then drive around through a tank of gas (drive normally with no heavy throttle pulls at this point) and we can look at your long-term fuel trims (A/F Learning 1 A,B,C,D). If those look OK (within around +/- 5%), then we can generally rule out additional fueling issue. At that point, you can get some WOT pulls and we can see what it looks like.
Bill
Old 09-22-2012, 12:11 PM   #8
bshep211
Member#: 332839
Bill
Thanks for the support and great product. I will post more results once I have gone through a tank of gas.
