Welcome to the North American Subaru Impreza Owners Club Sunday February 1, 2015
Old 09-21-2012, 10:17 PM   #1
ajmillan
Member#: 298536
2013 STI
Satin white
Default 2011 wrx cobb stage 1 + SF Intake (not reaching target boost)
https://docs.google.com/spreadsheet/...k1JeEtqWHJsUUE
Mods: Cobb SF Intake, Invidia Catback exhaust, Cobb accessport.
i am not sure what is wrong, boost creeped only once in the beginning and now it won't go past 15psi and i have reflashed.
ajmillan is offline   Reply With Quote
Old 09-22-2012, 12:58 AM   #2
tman7510
Member#: 332937
Check out cobbs website they have maps with high and low waste gates address the problem you are having.
tman7510 is offline   Reply With Quote
Old 09-22-2012, 01:11 AM   #3
ajmillan
Member#: 298536
2013 STI
Satin white
I already tried the LWG map and it still did 14.5 psi max not sure if HWG will be a good idea.
Old 09-22-2012, 09:24 AM   #4
Cobb Tuning
Member#: 4803
Originally Posted by ajmillan View Post
https://docs.google.com/open?id=0B0u...GZwQmxmY3lhOE0
Can you convert the log to google doc's native format (with preview)? I am not able to DL logs with my Cobb account.
Thanks,
Bill
Old 09-22-2012, 09:24 AM   #5
bacalhau16
Member#: 297565
2011 WRX hatch
The LWG map would have a lower target boost. If you are not achieving the boost u want with the LWG or normal map, then the HWGap is the map you want to use. On my 2011, I had to use the HWG map when i was jot stage 1 and stage 2.
bacalhau16 is offline   Reply With Quote
Old 09-22-2012, 12:43 PM   #6
ajmillan
Member#: 298536
2013 STI
Satin white
So you had to use the highwaste map?
Old 09-22-2012, 12:51 PM   #7
ajmillan
Member#: 298536
2013 STI
Satin white
Thanks,
Bill
There i think you should be able to preview now, also my mpg seem to have decreased with light driving conditions.
Old 09-23-2012, 11:31 AM   #8
Cobb Tuning
Member#: 4803
Log looks fine except for the underboost. You can download the high wastegate (HWG) version of the map from the maps section at cobbtuning.com. Use the AccessPORT Manager software to transfer the downloaded map from your computer to the AccessPORT and reflash it to the car.
Mileage should not be notably impacted by these maps, but you will have more power across most of the RPM range, so if you take advantage of that to accelerate faster than you would before, mileage could decrease a little.
Bill
Old 09-23-2012, 01:44 PM   #9
ajmillan
Member#: 298536
2013 STI
Satin white
Bill
Yes my tire preassure light went on so i guess that was the cause of the mpg drop, as for underboosting it is now reaching 16psi which i think is acceptable due to the high temperatures and humidity.
Old 09-30-2012, 11:43 PM   #10
MtnXfreeride
Member#: 228010
2012 WRX Prem Hatch
Dark Gray Metalic
Just out of curiosity - how did you do your test run? I thought I was underboosting because no one ever told me (even cobb after showing them my datalogs) how to log a proper run. Once I put the car in third and floored it at 2K, I saw a proper boost build, peak, and trail off through the RPM range until redline.
In your log I see you didnt step on it till 3200K (i think since its cut off). And we dont know what gear you are in.
After I did it the way I described above I saw I was actually over-boosting a bit at 17.23psi.
MtnXfreeride is offline   Reply With Quote
Old 10-01-2012, 12:19 AM   #11
ajmillan
Member#: 298536
2013 STI
Satin white
Yeah that wasn't right I usually floor it at 2500rpm to redline on 3rd gear, that is what the cobb recommends.
