Old 02-01-2014, 06:49 PM   #326
barkley2-6
Member#: 221961
My flares showed up last week and now I get to walk by them sitting in my basement every day, since I decided to order a diffuser and rear spats which come from China which will likely change how I mount them, and any mods I need to make to the flares.
Oh well, it's cold outside anyways.
barkley2-6 is offline   Reply With Quote
Old 03-28-2014, 12:00 PM   #327
Pound
Member#: 371629
2008 FXT
APT tuning is out of stock. where else can I purchase these for $50?
Pound is offline   Reply With Quote
Old 03-28-2014, 12:01 PM   #328
Platinlord
Member#: 336281
2003 Peanut Wagon
Classic Blue - 23W
ebay.
Platinlord is offline   Reply With Quote
Old 03-28-2014, 01:30 PM   #329
jimbosv650
Member#: 261307
04 wrx wagon
Or a junkyard
jimbosv650 is offline   Reply With Quote
Old 05-01-2014, 12:18 PM   #330
jdmshocker
Member#: 194422
2004 WRX Wagon
Did some more research on this, but it looks like Corrado G60's had even wider flares.....|
BTW, if this wasn't mentioned yet..the difference between no molding and thick molding is that the "thick molding" model has a piece that sticks out "flow" with the molding on the jetta if it came with side moldings. Correct me if im wrong?
Early on, all flares were the same size (and only came on GTI, GLI, and some Jetta GL models).
85-87 are all the same with no built-in side trim extensions (side trim was glued to the body).
88-early 90 small bumper cars had the same size flares with fat side trim built in.
90-92 big bumper flares have skinny side trim built in, as well as the side skirt extensions.
They come in two types: GTI 8v, Jetta GL and Jetta GLI all had the "8v" flares.
GTI 16vs in the USA and GTI G60s elsewhere around the world came with the extra-wide flares and notched fenders (GTi 16vs worldwide had normal flares, it was only here in the USA they got the wider flares).
No GLIs had the extra wide flares, though they'll fit on any big bumper GLI with some fender mods.
For the rock guard flares, there is the 85-87 type, and the 88-92 type (and big bumper cars had extra protectors near the bumpers as well). Take note that the holes are different between the 85-87 and 88-92 bodies. So the later style guards will leave a hole exposed, and the earlier guards won't mount correctly on an 88-92 body.
sourced from http://forums.kilometermagazine.com/...lare-Questions
jdmshocker is offline   Reply With Quote
Old 05-01-2014, 03:51 PM   #331
ej25_TS
Member#: 59670
2008 Lexus IS250
Starfire Pearl
Hey guys I'm looking for the MK2 flares but can't seem to find them. I checked ebay and onlt find MK3 flares... Will these work?
ej25_TS is offline   Reply With Quote
Old 05-01-2014, 03:55 PM   #332
jdmshocker
Member#: 194422
2004 WRX Wagon
Link of the 1st page. I just ordered a set
Old 05-01-2014, 04:05 PM   #333
ProjectShadow
Member#: 389624
2006 Impreza WRX STi
Obsidian Black Pearl
Cool
Would look sick if the tires stuck out a bit. Give it that stance
ProjectShadow is offline   Reply With Quote
Old 05-01-2014, 05:46 PM   #334
ej25_TS
Member#: 59670
2008 Lexus IS250
Starfire Pearl
They were sold out last time I checked. I'll try again
Old 05-10-2014, 02:36 PM   #335
VtLeggy
Member#: 267738
2004 WRX Wagon
I'm sure it's somewhere in this thread but couldn't seem to find it. Anyone tried these with a regular wagon front end but with STI splitters? I really like the look of these but I dremeled into my bumper to fit the splitters so there is no taking them off.
VtLeggy is offline   Reply With Quote
Old 05-10-2014, 02:56 PM   #336
jimbosv650
Member#: 261307
04 wrx wagon
I don't see it being an issue, just carefully notch around the swell in the splitters.
Old 05-11-2014, 03:02 PM   #337
gratton
Member#: 319385
2002 impreza 2.5 Ts
army green and black
all done !!!
gratton is offline   Reply With Quote
Old 05-11-2014, 03:21 PM   #338
VtLeggy
Member#: 267738
2004 WRX Wagon
What tools did you guys use? Dremel, sand paper, color matched spray paint, screw driver and screws, jack/stands anything else required or would at least be helpful? Also the consensus is the ones without molding are the way to go correct?
Old 05-11-2014, 03:56 PM   #339
jimbosv650
Member#: 261307
04 wrx wagon
Not at all trying to be rude, but there's a lot of info in this thread. I've done like 3 separate write-ups alone on the first couple of pages. Check em out.
Old 05-11-2014, 04:31 PM   #340
jimbosv650
Member#: 261307
04 wrx wagon
Double post
Old 05-12-2014, 07:28 AM   #341
KANGA
Member#: 390584
wow clean as
KANGA is offline   Reply With Quote
Old 05-12-2014, 11:52 AM   #342
Serkan
Member#: 180514
2004 Sti
I really like your two tone theme.
You definitely need some wider wheel/tire setup to fill the gap a lil.
Looks great. Has the oem quality look.
Serkan is offline   Reply With Quote
Old 05-12-2014, 06:20 PM   #343
gratton
Member#: 319385
2002 impreza 2.5 Ts
thank , but for more larger tires or more offset , it impossible , whit this wheels and tires (225-60-16 (26.6 inch)) , when i turn steering , my tire pass very tight whit the inside of my fender .
Old 05-12-2014, 10:29 PM   #344
Serkan
Member#: 180514
2004 Sti
Well if you go with a different wheel/tire setup you can run lower profile tires (25 in) and run some extra caster to push the wheels forward. That will also improve your handling
Old 05-13-2014, 05:12 PM   #345
gratton
Member#: 319385
2002 impreza 2.5 Ts
no , this size is realy perfect to me , i just want a real mud tires and in this size 225-60-16
, not easy to find
Old 05-20-2014, 11:06 AM   #346
jdmshocker
Member#: 194422
2004 WRX Wagon
Bought a set but I think I want to get wider flares. Anyone want to buy these off me?
Old 05-22-2014, 07:57 PM   #347
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
I'm actually now going a different route, so I'm selling my ABW Motorsports flares if anyone is interested
$450 shipped:
Not my car:
Taped on my car:
BeBop86 is offline   Reply With Quote
Old 05-29-2014, 02:55 PM   #348
gdale08
Member#: 392179
Default Legit
gdale08 is offline   Reply With Quote
Old 05-31-2014, 08:52 PM   #349
Lukedean
Member#: 385231
2004 WRX
World Rally Blue
Jdmshocker. Im interested in them!!
Lukedean is offline   Reply With Quote
Old 06-03-2014, 03:05 PM   #350
Al_swank
Member#: 380213
04 STIswap wagon
My mk2 flares just came in! I'll put them on my wagon this week. I have some 18x9.5 et30 wheels I'll be stuffing under them and I'll be putting on 15-20mm spacers as well.
I originally fit these wheels on the stock fenders with a roll and slight pull and was able to sit just about wheel lip to fender with a 205/40 on the 9.5(yes I'm one of those "stance kids"). With these flares I want to mount a 225/35 or 235/35 on the wheels, run the spacers and be able to tuck just a bit of tire. *stay tuned*
Al_swank is offline   Reply With Quote
