Welcome to the North American Subaru Impreza Owners Club Sunday October 23, 2016
Old 09-22-2012, 01:47 AM   #1
Member#: 160098
02 AW wrx 2.5l
20g'd,44mm EWG, RA gears
Default Bugeye Morimoto Mini retrofit
Just finished my Morimoto Mini H1 5.0 retrofit...I'm pretty happy with the outcome so I thought i'd share! So, i wanted to do this for a while and after seeing countless posts i decided to go for it... i mean they are only headlights... Bought the Morimoto Mini H1 stage III (35 w and 5000k bulbs, gatling gun shrouds) kit from theretrofitsource.com. The guys TRS were extremely helpful! Anyways, onto some pics...
"stock" headlights...already koji modded them years ago...
time to start retrofitting!
testing the fitment
almost done...but not sure i like the gatling gun shrouds chrome...
time for some paint and some trimming so the projector pops out of the shroud further...
Much better
aaaand the only thing that matters..the output!
Let me know what you think
.whitewrx2002 is offline   Reply With Quote
Old 09-22-2012, 11:25 AM   #2
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Welcome to the club. I ended up with an e55r (TRS' EvoX-R) on my 2nd reftrofit. Now using my Mini D2S for daytime DRL duty only.
satrya is offline   Reply With Quote
Old 09-22-2012, 02:37 PM   #3
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
Looking good. Is the ground level with the garage door? If so your driver side would benefit from a little clockwise rotation. It is hard to get this level, on mine even if the projector is level in the heqdlight, somehow when I attach the headlight to the car it tends to be rotated. Try loosening the mounting screws of the headlight and angle it a bit. There might be enough slack to make the driver side level, and then retighten.
I also have to do that to mine, I think I'll enlarge the mounting holes slightly (the 2 towards grille) to have a bit more play to get like 1 extra degree.
frederik is offline   Reply With Quote
