Welcome to the North American Subaru Impreza Owners Club Sunday August 30, 2015
Old 09-22-2012, 02:26 AM   #1
armintheman
Member#: 316460
2008 STI
Snow White
Arrow grimmspeed ebc solenoid with stage 2?
hey guys im new to accessport and curious if with the list of mods i have it's best to just put the stage 2 map on the car or go with a dyno tune open source? my mods are:
turbo inlet
front mount
injen short ram
up pipe
turbo back
blitz bov
cobb pulley
everything else is stock...
armintheman is offline   Reply With Quote
Old 09-22-2012, 02:38 AM   #2
addictionsoLA
Member#: 301236
2010 Wrx
Grayish!
Negative, Grimmspeed EBCS absolutely HAS to be tuned for, and the injen short ram would be safer with a tune as well.
addictionsoLA is offline   Reply With Quote
Old 09-22-2012, 02:45 AM   #3
ColeBerkenbile
Member#: 316278
2010 WRX Sedan
Torqued performance can email you a specialized tune specific to your mods for relatively cheap that you can simply load to your accessport
ColeBerkenbile is offline   Reply With Quote
Old 09-22-2012, 02:48 AM   #4
armintheman
Member#: 316460
2008 STI
Snow White
so not worth it to get the accessport if im going to tune it once and not mess with it much after that? i know accessport has alot of cool features but if i have to pay extra for a special tune then i dont think it'll be worth it...thoughts?
Old 09-22-2012, 02:50 AM   #5
ColeBerkenbile
Member#: 316278
2010 WRX Sedan
The AP is definitely worth it, especially if you can find one used. It is by far the most simple way of tuning and monitoring these cars
Old 09-22-2012, 03:09 AM   #6
armintheman
Member#: 316460
2008 STI
Snow White
how much is a specialized tune generally run? and whats a good price on a used ap?
Old 09-22-2012, 03:20 AM   #7
Andrewxxcarlson
Member#: 316415
2006 WRX
I hope you're not running the turboback without a tune!! And the accessport is well worth it! Can help you solve a lot of problems with the car at the same time flashing maps.
Andrewxxcarlson is offline   Reply With Quote
Old 09-22-2012, 04:10 AM   #8
ColeBerkenbile
Member#: 316278
2010 WRX Sedan
Around 100 from tp, I got my AP for 330 on eBay
Old 09-22-2012, 05:12 AM   #9
chemtek
Member#: 310710
2008 Impreza WRX
85 for my map from TP plus amazing customer support.
chemtek is offline   Reply With Quote
Old 09-22-2012, 09:36 AM   #10
armintheman
Member#: 316460
2008 STI
Snow White
Ok thanks guys. And I'm running all those mods with no tune right now I know that's why I'm trying to do it now. But haven't drivin the car hard at all. Highest rev I've hit has been maybe 4k
Old 09-22-2012, 09:39 AM   #11
Andrewxxcarlson
Member#: 316415
2006 WRX
Try not to see boost anymore til you get a tune bud. Save you a very big headache.
Old 09-22-2012, 11:21 AM   #12
armintheman
Member#: 316460
2008 STI
Snow White
will do! thanks guys. this process has been such a headache... mostly my fault because i was determined to make a v5 jdm manifold work so i dont have to worry about my tgv delete (when i did the tgv delete i has a vacuum leak so decided to do the manifold) and realised it takes alot of work to make it work. so giving up and puting the stock tgv back in and pulling off the plates to maybe help a little bit but not throw a code and slap on the tune...i guess i shouldnt try to take short cuts anymore...
Old 09-22-2012, 11:51 AM   #13
Andrewxxcarlson
Member#: 316415
2006 WRX
At least your learning! Take things with these cars slow and make sure you understanding what you are doing and what it needs to be accommodated by. One step at a time with good decisions will yield greater outcomes. If you haven't yet go read Unabombers Manifesto, just search for it. Tons of good information. I'd link it for you but I'm on my phone! Good luck!
Old 09-22-2012, 12:31 PM   #14
armintheman
Member#: 316460
2008 STI
Snow White
thanks man!
Old 09-22-2012, 01:18 PM   #15
Cone Klr
Member#: 73072
02 wrx, 04sti
WRB squared!
Default tune
You should unplug the boost controller so the car can only run waste gate boost. With that exhaust you should still see boost creep in the higher rpm range but if you stay out of that range you should be ok. only running waste gate boost would be the "safest" way to drive the car without a tune.
Cone Klr is offline   Reply With Quote
Old 09-22-2012, 02:10 PM   #16
armintheman
Member#: 316460
2008 STI
Snow White
honestly right now my car hasn't seen more then 5lbs anyway...driving like a grandma! lol can't wait till after the tune to see what this car can do!
Old 09-23-2012, 03:05 AM   #17
addictionsoLA
Member#: 301236
2010 Wrx
Grayish!
As long as you can resist "getting on it" you'll be okay. The thing with accessport is yes, it allows you to monitor and reflash maps, but it's also expensive. If you wanted to tune your car once and leave it you'd be just as well off getting a pro-tune/dyno-tune. Thing with a pro-tune is it is tailored for your car and your car parts as is (meaning you can't change up the parts without having to worry about the tune). It's also semi-expensive at $350.00+, but it's also one of the best investments you'll make.
Old 09-23-2012, 06:00 PM   #18
Dka67
Member#: 296721
11 5door
Whatever u do, do it soon. All those mods without a tune is a BAD IDEA!
Dka67 is offline   Reply With Quote
