Old 09-22-2012, 10:47 PM   #1
Jackulous
Member#: 312637
2008 WRX hatch
Default Car is running SO much better
so, i finally got the access port, plugged it in, installed the stage 2 93 map, and boom. car is running perfect. only problem i've had is i've overboosted a couple times now. seems to be pushing too many psi on the wastegate. does anyone know how i can fix this with the accessport?
Jackulous is offline   Reply With Quote
Old 09-22-2012, 10:59 PM   #2
Ptown_finezT
Member#: 308190
2012 wrx hatch
dgm,2010 swp legacy prem.
Try to upload the lwg stage 2 map from cobb,the map will make the wastegate cycle start early and help you reduce your overboost issue.
Ptown_finezT is offline   Reply With Quote
Old 09-22-2012, 11:16 PM   #3
Jackulous
Member#: 312637
2008 WRX hatch
awesome man. thanks a ton. just downloaded the map. about to go install it.
Old 09-23-2012, 12:09 AM   #4
Ptown_finezT
Member#: 308190
2012 wrx hatch
^^^ no problem anytime.
Old 09-23-2012, 08:41 AM   #5
fr0st
Member#: 41618
2008 WRX Hatch
wrb
I had the same issue. It would hitover boost but on rare occasions. I had a pretty good spike in 4 th gear.
LWG map FTW
fr0st is offline   Reply With Quote
Old 09-23-2012, 11:11 AM   #6
Cobb Tuning
Member#: 4803
As suggested by others, reflashing the low wastegate (LWG) map is the proper procedure when you are overboosting. Be sure to get a data log after you reflash the LWG map (if you can do so safely):
Bill
Old 09-23-2012, 08:59 PM   #7
Jackulous
Member#: 312637
2008 WRX hatch
Car is still over boosting. Even with the LWG map installed. OBd at like 4k-4500 rpm in 3rd. Any ideas?
Old 09-23-2012, 09:07 PM   #8
Cobb Tuning
Member#: 4803
What are your mods? Are you getting the overboost check engine light and code or are you just seeing elevated boost via monitoring? Have you taken any data logs?
Bill
Old 09-23-2012, 09:12 PM   #9
Jackulous
Member#: 312637
2008 WRX hatch
Throwing codes. Logging now. Have taken one other the other day.
Old 09-23-2012, 09:15 PM   #10
robsuerto
Member#: 331899
2012 WRX
John Shafer tuned
cobb offers a SWG (severe low wastegate map), I suggest you download and install that one. Fixed my problem
robsuerto is offline   Reply With Quote
Old 09-23-2012, 09:43 PM   #11
Jackulous
Member#: 312637
2008 WRX hatch
Bill
my only engine mods, as far i know, are just a Perrin TBE and the AP. bought it with the exhaust already on.
will do complete data logging tomorrow. didn't do it right while i was driving tonight.
Old 09-24-2012, 02:29 AM   #12
07 Boosty
Member#: 329069
2011 WRX Hatchback
Is the TBE catted? according to the AP map info, Stage2 is for a tbe with high flow cat. Could that possibly have any affect???
07 Boosty is offline   Reply With Quote
Old 09-24-2012, 05:40 AM   #13
fr0st
Member#: 41618
2008 WRX Hatch
wrb
If i remember correctly, Boost creep can happen with a TBE if it's catless?
Old 09-24-2012, 08:42 AM   #14
bacalhau16
Member#: 297565
2011 WRX hatch
You can actually get boost creep with both a catted and catless Downpipe. Its said that a catless may have that issue more frequently.
I feel like it has more to do with the type of exhaust you have. I have a catless dp with the stock exhaust and have had 0 issues running TP stage 2 tune.
bacalhau16 is offline   Reply With Quote
Old 09-24-2012, 09:25 AM   #15
Cobb Tuning
Member#: 4803
I would determine if you are catless or not - on some cars, catless can be the root cause of an overboost condition. There are other things to try, but that is a key piece of information.
Bill
Old 09-24-2012, 01:24 PM   #16
Jackulous
Member#: 312637
2008 WRX hatch
i'm pretty sure it's a high flow cat.
this is what i have..
http://www.perrinperformance.com/sub...o-back-exhaust
****confirmed with Perrin...it IS a high flow cat
Old 09-25-2012, 09:28 AM   #17
Cobb Tuning
Member#: 4803
Ok, next step would be to make sure there is not any damage to any of your wastegate lines. You want to look for cracks, split, etc. (don't forget the side that is not facing you) and disconnected or partially disconnected lines. Here's an explanation of the hardware:
http://www.cobbtuning.com/Technical-...es-s/70674.htm
If that all checks out, then the next step would be to loosen the wastegate arm. Here's a step-by-step on how to do this:
http://www.scoobypedia.co.uk/index.p...urWastegateArm
I would start with 2 full turns (make sure you are loosening and not tightening) and then get some data logs.
Bill
