Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 09-22-2012, 11:32 PM   #1
Jetmate492
Member#: 333020
Default 1991 Loyale stuck between gears
I need help bad!!! I was driving my loyale the other day and it got stuck between 4th and 5th. It acts like its in fouth but i cant get it to change. Any advice?
Jetmate492 is offline   Reply With Quote
Old 09-24-2012, 10:27 AM   #2
Jetmate492
Member#: 333020
Anyone help please!!!!!!!!!!!!!!
Old 09-24-2012, 11:21 AM   #3
TurboneX
Member#: 21676
Brat RX,02Foz84Coupe
Does the shifter move at all, does it go thru the gears?
Need more info to figure out if its a linkage problem or trans problem.
TurboneX is offline   Reply With Quote
Old 09-24-2012, 09:34 PM   #4
Jetmate492
Member#: 333020
The shifter will move side to side and some forward movement (its like slop in the linkage) but it will not go thru the gears. The clutch works bc i can press it and crank the car.
Old 09-25-2012, 09:57 PM   #5
Jetmate492
Member#: 333020
Any ideas. I really want to fix my car but dont know which way to go.
Old 09-27-2012, 11:16 AM   #6
TurboneX
Member#: 21676
You will need to get under the car and look at the linkage to see whats binding up. Also try rocking the car back and forth to see if you can get it to shift gears. Does this have the pushbutton 4WD?
Old 09-28-2012, 10:32 PM   #7
Jetmate492
Member#: 333020
Yes its push button 4-wheel drive. Nothing looks bound up with the linkage.
Message Board Statistics All times are GMT -4. The time now is 09:38 AM.
