Welcome to the North American Subaru Impreza Owners Club Friday October 21, 2016
Old 09-23-2012, 01:48 AM   #1
Member#: 266513
1997 legacy gt
Default No fog lights and high beams. No cruise control.
So I just bought I 2002 wrx wagon and the fog lights won't turn on and then all the sudden it would just turn on. When I turn the high beams in it just shuts my lights off a d leaves the parking lights. Plus I have no cruise control. Please help me.
jimmyfa10 is offline   Reply With Quote
Old 09-23-2012, 11:55 AM   #2
Member#: 279510
2012 Impreza Wagon
Check fuses
svxninja is offline   Reply With Quote
Old 09-23-2012, 12:34 PM   #3
Member#: 53443
2001 LL Bean Outback
Have you verified the high beam lamps are good? If they are ok then I suggest you check the switch. See if you can use the flash mode. If the flash mode works then the switch contacts for the normal position would seem to be the trouble. For the CC problem make sure the disconnect switches on the pedals are working correctly and have the correct adjustment.
