Old 09-23-2012, 12:01 PM   #1
msp05sti
Member#: 113038
2005 STI PTE5858
NF Performance
Default NF Performance: 2005 STi PTE 5858 1/4 10.7
Event: Cedar Falls Raceway's Midnight Mania
Ambient Temp: 35-37*F
Elevation: 900
Weather: Clear Skies
Track and Conditions: Flat
Tires: Hoosier 245/45/17
Car: 2005 Subaru Impreza WRX STi
Tuner: Nuke of NF Performance
Transmission: 2005 STi 6 Speed with Legacy GT Spec-B 2-6th gear upgrade
Peak HP at RPM: N/A
Peak Torque at RPM: N/A
Baseline hp/tq for a stock on same dyno: N/A
Target Boost: 28psi
Target AFR: 11ish
Fuel: E85
Engine/Power Modifications: STOCK Sleeves EJ257, STOCK Heads (Stock Cams & Valves), STOCK STi Rods, OTS CP Pistons 99.5mm 8.2:1 compression ratio, PTE 5858 .82 A/R V-Band Inlet & Outlet Journal Bearing, ACL Bearings, Fobia full 1.5 headers, Ebay FMIC, Custom 3.5inch Cold Air Intake, Tial 38mm External Wastegates, Replica Cobb Catback, Five O 1400cc injectors, DW300 (Wired directly to battery)
Driveline Modifications: ACT HDSS Clutch Kit with 4 Puck Disk
Suspension Modifications: Stock struts w/ Prodrive Springs
Other Modifications: Seats & Doorcards removed
msp05sti is offline   Reply With Quote
Old 09-23-2012, 08:26 PM   #2
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Virtual dyno?
Congrats on the 10 sec pass
Old 09-23-2012, 08:51 PM   #3
Nuke209
Member#: 108089
2003 WRX
NF Performance
Originally Posted by juanmedina View Post
Virtual dyno?
you can draw it in your own head
Nuke209 is offline   Reply With Quote
Old 09-23-2012, 09:03 PM   #4
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Great run! This seems like an awesome setup!
xluben is offline   Reply With Quote
Old 09-23-2012, 09:11 PM   #5
Nuke209
Member#: 108089
2003 WRX
NF Performance
Yessir. VERY simple and effective
I forgot to mention, this car is reusing STOCK headbolts...
Old 09-23-2012, 09:29 PM   #6
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I wish my car could be like this someday!
Old 09-23-2012, 10:52 PM   #7
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
It can be! Actually, lets put on some good shoes. You'll she how fast your car actually is.
Congrats Ko for accomplishing your 10's! Such a simple setup.
FuJi K is offline   Reply With Quote
Old 09-23-2012, 11:03 PM   #8
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
How did you end up with a PTE over a Garrett, and what has your experience been like since you have local cars to compare it too?
Zee Biker is offline   Reply With Quote
Old 09-23-2012, 11:06 PM   #9
Nuke209
Member#: 108089
2003 WRX
NF Performance
Something different. Everyone has a 35r or 6262/6266. We decided to go with a 5858 to see if we can get it to respond like a 30r. It's slightly laggier than a 30r but as you can see, the results surprised us all
I think it's a nice turbo. Power is pretty linear vs insane torque. Feels good and works great
Also, the journal bearing PTE aren't priced bad at all
Old 09-23-2012, 11:54 PM   #10
eg33GC
Member#: 206851
56 Belair
Pro Street
awesome, glad to see you guys doing it at a REAL track and not the junk **** I worked at.
-jake
eg33GC is offline   Reply With Quote
Old 09-24-2012, 08:17 AM   #11
juanmedina
Member#: 133146
LOL
If it weights the same as Juks car it makes 550whp
Old 09-24-2012, 10:40 AM   #12
msp05sti
Member#: 113038
2005 STI PTE5858
NF Performance
Thanks Fujik, it was some of your words mixed with THE STIGs words/guidance that got me there.
Nuke, Thanks for posting the vids.
Old 09-24-2012, 10:41 AM   #13
Nuke209
Member#: 108089
2003 WRX
NF Performance
Go fast or go home?
Old 09-24-2012, 03:43 PM   #14
NIGO
Member#: 184267
Novice question!
The swap to the legacy gears, is it a simple remove and replace??
NIGO is offline   Reply With Quote
Old 09-24-2012, 03:57 PM   #15
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Originally Posted by NIGO
Novice question!
The guts get replaced with them using the new parts and keys.
Old 09-24-2012, 04:24 PM   #16
happyfeet
Member#: 194580
05 STI
NF Performance
ohhhhhhhhh you very so fast
happyfeet is offline   Reply With Quote
Old 09-24-2012, 07:58 PM   #17
Boss Paco
Member#: 176723
2005 WRX STi
Platinum Silver Metallic
How much were the parts and do you launch in first or second?
Boss Paco is offline   Reply With Quote
Old 09-24-2012, 09:21 PM   #18
AirManCam
Member#: 219513
2006 STI
Nice pass!
AirManCam is offline   Reply With Quote
Old 09-24-2012, 09:32 PM   #19
Nuke209
Member#: 108089
2003 WRX
NF Performance
contact rallispec for their high speed gear set for the 6spd
Old 09-24-2012, 09:54 PM   #20
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Get at Rallispec.
We launch in 1st gear.
Old 09-24-2012, 11:04 PM   #21
xbcaraudio
Member#: 76912
2002 WRX MT
WRX RALLY BLUE
Hi, how does it feels on the street, any dyno graph to take a look on the spoolup?
Good job...
xbcaraudio is offline   Reply With Quote
Old 09-24-2012, 11:08 PM   #22
Boss Paco
Member#: 176723
2005 WRX STi
Tires and clutch setup?
Hopefully I'm not being a pest. Just got my 30r setup together and saving some teething issues. I'm nearly convinced the short geared 6mt is the devil. I've tried launching in both 1st and 2nd and a 1.8x is the best I've gotten on my bfg kdw2. This is on the two step building 8-10psi at 4k. I blow em off and fall flat shifting to fifth.
I have other issues I'm working out with boosting over 21psi but the car runs good. It's definitely faster than I am. 1.86 60', 7.87 @ 89 1/8 and 12.12 @ 115 is my quickest pass to date. I wanna share your company in the tens with my full weight pig.
Old 09-24-2012, 11:21 PM   #23
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Read the first post. Hoosier's and an ACT 4 puck.
Old 09-24-2012, 11:31 PM   #24
Boss Paco
Member#: 176723
2005 WRX STi
Yeah. Saw that. Thanks.
Old 09-24-2012, 11:37 PM   #25
msp05sti
Member#: 113038
2005 STI PTE5858
NF Performance
Good job...
With the Precision billet turbo I do feel some lag but it not extreme. I dont have the graph at this time and only I will be the only one to see it.
