Old 10-18-2015, 07:42 PM   #1
Jfish959
Member#: 432413
2011 WRX Hatchback
Default 2011 WRX Hatch 700AWHP 6266Gen2
Hi i am new to the Page so this is somewhat my introduction post at the same time. If i have done something wrong or posted in the wrong section please let me know. Still not sure how to use all of the functions of this page. will update with a Video soon.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
SUSPENSION/DRIVETRAIN:
KW V3 Coilovers
Noname Adjustable Lower Control Arms
Whiteline Toe Arms
Whiteline Front and Rear Sway Bars
SPT Strut Tower Brace
SPT Sub Frame Brace
Whiteline Rear Lateral Braces
Whiteline Rear Diff Cradle Bushings
Perrin Spherical Rear End Links
08+ STI 6 Speed Transmission
08+ STI R180 Rear Differential
DCCDPro Center Diff Controller
Custom Made Aluminum Drive Shaft
Competition Clutch Lightweight Flywheel
Competition Clutch Stage 4 Clutch
Torque Solutions Solid Pitch Stop
Perrin Motor Mounts
Cusco Transmission Mount
Whiteline Steering Rack Bushings
WHEELS/BRAKES
Rays Gramlight 57Xtreme 18x9.5
Nitto NT05 Tires 265/35/18
STI Brembo Brakes
DBA Slotted Rotors
Brembo Pads
Goodridge Stainless Brake Lines
Grimmspeed Master Cylinder Brace
MOTOR:
Off The Line Custom Assembled Short Block
Outfront V4 Closed Deck Block
Manley Pistons
Manley Turbo Tuff I Beam Rods
King Main Bearings
King Rod Bearings
OEM Nitride Crank
All Balanced to 8500RPM
Outfront Porting, Polishing, and Bowl Blending
Supertech Dual Spring Valve Kit
Supertech +1mm Inconel Exhaust Valves
Supertech +1mm SS Nitride Intake Valves
GSC S2 Cams
Inch Head Studs
11mm Oil Pump
Mishimoto Oil Cooler
SixStar Motorsports Custom Top Mount Oil Cooler Bracket
Koyorad Radiator
Radium Engineering Catch Can
Aluminum Overflow Tank
TURBO KIT/EXHAUST:
ETS Rotated Turbo Kit
Precision 6266 Gen2 Turbo
ETS Front Mount Intercooler Kit with 4 Inch Core
Tial MV-R 44mm Waste Gate
Tial Q Blow Off Valve
Grimmspeed 3 Port Boost Controller
Tomei Expreme Titanium Cat Back
FUEL SYSTEM:
Custom Return Style Fuel System
Deatschwork 380 In Tank Fuel Pump
Radium Engineering Surge Tank
Twin Walbro 450 Surge Tank Pumps Each On a Separate Breaker
-8 Feed Fuel Line
-6 Return Fuel Line
IAG Fuel Rails
Injector Dynamics ID2000 Injectors
Fuelab 6-Micron Feed Filter
Aeromotive 40-Micron Filter Between Tank and Surge Tank
Aeromotive Fuel Pressure Regulator
TUNING:
Cobb V3 Accessport Tuned on Speed Density
Tuning Done by Corbin Johnson/Johnson Tuning
Tuned On The Fathouse Fabrications AWD Dynojet Dyno
700AWHP/596AWTQ @38Psi E85
545AWHP/470AWTQ @24Psi 93 Octane
Adjustments Still To Be Made
Jfish959 is offline   Reply With Quote
Old 10-18-2015, 09:04 PM   #2
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
Very Impressive!!!!
bluemax189 is offline   Reply With Quote
Old 10-18-2015, 09:24 PM   #3
Jfish959
Member#: 432413
2011 WRX Hatchback
Originally Posted by bluemax189 View Post
Very Impressive!!!!
Thank you!
Old 10-18-2015, 11:17 PM   #4
VladiWrX
Member#: 145658
On my 5th scoob
and lovin it
Looks really solid, congrats, can we see a full dyno plot?
VladiWrX is offline   Reply With Quote
Old 10-19-2015, 04:17 AM   #5
user1029
Member#: 57064
2008 STi IAG built
HTA86, Meth, 272s, Cos IM
Very nice That is my goal for E85 on my HTA86
user1029 is offline   Reply With Quote
Old 10-19-2015, 12:06 PM   #6
maperformance
Member#: 141043
2015 WRX
Proper set up, good parts, and it shows. Nice build!
maperformance is online now   Reply With Quote
Old 10-19-2015, 12:20 PM   #7
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
That is an awesome, clean, engine bay. Do you show the car at all?
Old 10-20-2015, 02:25 AM   #8
Jfish959
Member#: 432413
2011 WRX Hatchback
yes i do. it doesn't sit in the garage either
Old 10-20-2015, 11:29 AM   #9
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
+2
congrats and can we see the full plot
Old 10-20-2015, 01:04 PM   #10
Dave D.
Member#: 130990
06 Red Ltd.Wagon
Originally Posted by Paul View Post
+2
Looks like the graph goes from 3000 to 6500, scaled in 500rpm increments. That would put the tq/hp crossover point right about where it belongs. But it would be of interest to see the curve at least to 7k rpm.
Old 10-20-2015, 05:41 PM   #11
Jfish959
Member#: 432413
2011 WRX Hatchback
I broke my last phone with the full graph on it. If I can recover it somehow I'll post it up!
Old 10-20-2015, 08:26 PM   #12
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
Corbin tuned!!!
Sent from my iPhone using NASIOC
Shortpersonbk is offline   Reply With Quote
Old 10-20-2015, 08:34 PM   #13
JoshFiricano
Member#: 317193
2013 WRX Premium
Very nice!!!
JoshFiricano is offline   Reply With Quote
Old 10-22-2015, 05:28 PM   #14
billyfishsticks
Member#: 356168
2009 WRX
Red
good job, friend has a 6266 with a similarly built motor and similar mods and is only expecting low 600's because he is uncomfortable with anything over 30 pounds of boost. im sure your car makes people piss themselves.
billyfishsticks is offline   Reply With Quote
Old 10-28-2015, 07:05 PM   #15
Smdavis27
Member#: 219455
2009 WRX Sedan
i never said a word about north of 30 lbs, I was suspecting less than with 8.5:1 due to the 9.5:1
Smdavis27 is offline   Reply With Quote
Old 10-29-2015, 07:52 AM   #16
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
What a beast. Well done sir!
Steve.804 is offline   Reply With Quote
Old 11-04-2015, 04:23 AM   #17
Sti_qa
Member#: 387749
2011 STI
What was the spring in the wastegate ? How many PSI ?
Sti_qa is offline   Reply With Quote
Old 11-07-2015, 12:28 PM   #18
etcatmeat
Member#: 304057
This makes me want to keep my car....
etcatmeat is offline   Reply With Quote
Old 11-07-2015, 08:55 PM   #19
Dube Built
Member#: 410063
killer looking setup man, congrats on the numbers
Dube Built is offline   Reply With Quote
Old 11-09-2015, 11:41 AM   #20
bjohnson_55
Member#: 216580
20psi spring
bjohnson_55 is offline   Reply With Quote
Old 11-10-2015, 02:17 PM   #21
bjohnson_55
Member#: 216580
Actually 23, sorry.
Old 11-10-2015, 06:00 PM   #22
tweed433
Member#: 154510
1997 wrx sti
white
very impressive sir! any particular reason u went with a custom drive shaft?
tweed433 is offline   Reply With Quote
Old 11-12-2015, 02:49 PM   #23
jared-m
Member#: 433734
Very Nice!
jared-m is offline   Reply With Quote
