Old 09-23-2012, 02:36 PM   #1
newtothescene
Member#: 222368
2006 Cone Dodger
CGM
Default Oil filters that MEET subaru oem bypass psi
Does anyone have a list of the new aftermarket oil filters that MEET the Subaru bypass spec of 23psi? I found a list last night but can't seem to relocate it. I believe these new filters came out this year (WIX, etc.). Just can't get a subaru OEM one soon enough.
Thanks in advance!
DDS
newtothescene is offline   Reply With Quote
Old 09-23-2012, 03:56 PM   #2
Big-E
Member#: 123843
2006 WRX Sedan SGM
Let LED's light your way!
I'm in a good mood today.
Wix: 57712
NAPA (Wix): 7712
CarQuest (Wix): 84712
Old 09-23-2012, 07:20 PM   #3
flstffxe
Member#: 155358
2008 Forester
Steel Silver
Beck Arnely 041-8181
Fram PH9715
Wix 57712
Purolator L14460(Older Purolator filter speced for Subaru too large diameter for some on late models)
flstffxe is offline   Reply With Quote
Old 09-23-2012, 07:54 PM   #4
Tmibiker
Member#: 328048
2002 Impreza 2.5TS
Midnight Black Pearl
In addition to all the filters mentioned, the MANN Filter ML 1018 is a good filter at a good price that's spec'd correctly.
Tmibiker is offline   Reply With Quote
Old 09-23-2012, 08:11 PM   #5
mikeythejew
Member#: 141672
I think the majority of MANN filters are of Purolator design.
mikeythejew is offline   Reply With Quote
Old 09-23-2012, 08:54 PM   #6
Tmibiker
Member#: 328048
2002 Impreza 2.5TS
I'd be interested to see more information on that. I've done a fair bit of research about filters, and I never saw anything to indicate that. I picked up two today, and they were "Made in the USA". I'd be interested to know by who.
Old 09-23-2012, 09:30 PM   #7
Bottom Feeder
Member#: 2808
They are Purolator Classic clones, as is the Motorcraft FL-1998.
Bottom Feeder is offline   Reply With Quote
Old 09-23-2012, 09:50 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Wix: 57712
NAPA (Wix): 7712
the above are the ONLY answers if you need the 'smaller' filter to clear the exhaust
the ONLY other answer is the purolator 14460
none of the rest have been proved to have the correct by pass valve spec and/or an anti drainback valve
and what they LOOK like is irrelevant
Old 09-24-2012, 12:52 AM   #9
newtothescene
Member#: 222368
2006 Cone Dodger
CGM
Thanks Uncle Scotty. I found your post in the other thread I was referring to.
Old 09-26-2012, 02:03 PM   #10
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
Will these filters work for < MY06?
tebriel is offline   Reply With Quote
Old 09-26-2012, 03:16 PM   #11
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Are there any aftermarket filters that meet the FB/FA bypass valve spec AND have the anti drankback valve? I'm having difficulty uncovering that information. Currently have some 14459 Purulator (IIRC, I need to check the receipt) filters, but from what I understand they don't have the PROPER bypass valve spec.
OrbitalEllipses is offline   Reply With Quote
Old 09-26-2012, 07:50 PM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
get your filter at the dealer until there is a known solution
Old 09-26-2012, 08:57 PM   #13
Big-E
Member#: 123843
2006 WRX Sedan SGM
PL14459
Specifications:
Anti-Drain Back Valve: Yes
Height: 2.95"
O.D. 3.15"
Relief Valve P.S.I. 12-15
Threads: M20x1.5
Type of Filter: Spin-on
SUBARU B9 Tribeca - 6 cyl. 3.0L F.I. (EZ30D) (VIN 8) 2006-2007
SUBARU BRZ - 4 cyl. 2.0L D.I. (FA20D) (VIN A) 2013
SUBARU Forester - 4 cyl. 2.5L F.I. (FB25BA) (VIN A) 2011
SUBARU Forester - 4 cyl. 2.5L F.I. (FB25BC) (VIN B) 2011
SUBARU Forester - 4 cyl. 2.5L F.I. Turbo (EJ255) (VIN G) 2011
SUBARU Justy - 3 cyl. 1.2L 2 bbl. 1987
SUBARU Legacy - 6 cyl. 3.0L F.I. (EZ30D) (VIN 8) 2008-2009
SUBARU Legacy - 6 cyl. 3.6L D.I. (EZ36D) (VIN D) 2010-2013
SUBARU Outback - 6 cyl. 3.0L F.I. (EZ30D) (VIN 8) 2001-2009
SUBARU Outback - 6 cyl. 3.6L D.I. (EZ36D) (VIN D) 2010-2013
SUBARU SVX - 6 cyl. 3.3L F.I. (VIN 3) (DOHC) 1992-1995
SUBARU SVX - 6 cyl. 3.3L F.I. (VIN 8) (DOHC) 1996-1997
SUBARU Tribeca - 6 cyl. 3.6L F.I. (EZ36D) (VIN 9) 2008-2013
PL14460
Specifications
Anti-Drain Back Valve: No
Height 2.95"
O.D. 3.15"
Relief Valve P.S.I. 20-25
Threads: M20x1.5
SUBARU Baja - 4 cyl. 2.5L F.I. (EJ253) (VIN 6) 2003
SUBARU Baja - 4 cyl. 2.5L F.I. (EJ253) (VIN 6) 2004-2005
SUBARU Forester - 4 cyl. 2.5L F.I. (EJ251) (VIN 6) 2000-2003
SUBARU Forester - 4 cyl. 2.5L F.I. (EJ253) (VIN 6) 1999
SUBARU Forester - 4 cyl. 2.5L F.I. (EJ25D) (VIN 6) 1998
SUBARU Impreza - 4 cyl. 1.8L F.I. (VIN 1) 1996
SUBARU Impreza - 4 cyl. 1.8L F.I. (VIN 2) 1993-1997
SUBARU Impreza - 4 cyl. 2.2L F.I. (EJ222) (VIN 4) 2000-2001
SUBARU Impreza - 4 cyl. 2.2L F.I. (EJ223) (VIN 4) 1999
SUBARU Impreza - 4 cyl. 2.2L F.I. (EJ22E) (VIN 4) 1998
SUBARU Impreza - 4 cyl. 2.5L F.I. (EJ251) (VIN 6) 2000-2003
SUBARU Impreza - 4 cyl. 2.2L F.I. (EJ22EZ) (VIN 4) 1998
SUBARU Impreza - 4 cyl. 2.2L F.I. (VIN 4) 1996-1997
SUBARU Impreza - 4 cyl. 2.2L F.I. (VIN 6) 1995
SUBARU Impreza - 4 cyl. 2.5L F.I. (EJ253) (VIN 6) 1999
SUBARU Impreza - 4 cyl. 2.5L F.I. (EJ25D) (VIN 6) 1998
SUBARU Impreza Outback Sport - 4 cyl. 2.2L F.I. (EJ222) (VIN 4) 2000-2001
SUBARU Impreza Outback Sport - 4 cyl. 2.2L F.I. (EJ223) (VIN 4) 1999
SUBARU Impreza Outback Sport - 4 cyl. 2.2L F.I. (EJ22E) (VIN 4) 1998
SUBARU Impreza Outback Sport - 4 cyl. 2.2L F.I. (VIN 4) 1997
SUBARU Impreza Outback Sport - 4 cyl. 2.5L F.I. (EJ251) (VIN 6) 2002-2003
SUBARU Impreza Outback Sport - 4 cyl. 2.2L F.I. (EJ22EZ) (VIN 4) 1998
SUBARU Impreza WRX - 4 cyl. 2.0L F.I. Turbo (EJ205) (VIN 2) 2002-2003
SUBARU Legacy - 4 cyl. 2.2L F.I. (EJ223) (VIN 4) 1999
SUBARU Legacy - 4 cyl. 2.2L F.I. (VIN 3) FWD 1996-1998
SUBARU Legacy - 4 cyl. 2.2L F.I. (VIN 6) 1990-1996
SUBARU Legacy - 4 cyl. 2.5L F.I. (EJ253) (VIN 6) 2000-2005
SUBARU Legacy - 4 cyl. 2.2L F.I. (EJ22E) (VIN 4) 1998
SUBARU Legacy - 4 cyl. 2.2L F.I. (VIN 4) 1997
SUBARU Legacy - 4 cyl. 2.2L F.I. (VIN 4) AWD 1996
SUBARU Legacy - 4 cyl. 2.2L F.I. Turbo (VIN 6) 1991-1994
SUBARU Legacy - 4 cyl. 2.5L F.I. (EJ25D) (VIN 6) 1998-1999
SUBARU Legacy - 4 cyl. 2.5L F.I. Turbo (EJ259) (SOHC) 2004
SUBARU Legacy - 4 cyl. 2.5L F.I. (VIN 6) 1996-1997
SUBARU Outback - 4 cyl. 2.2L F.I. (VIN 4) 1996
SUBARU Outback - 4 cyl. 2.2L F.I. (VIN 6) 1995
SUBARU Outback - 4 cyl. 2.5L F.I. (EJ253) (VIN 6) 2000-2005
SUBARU Outback - 4 cyl. 2.5L F.I. (EJ25D) (VIN 6) 1998-1999
SUBARU Outback - 4 cyl. 2.5L F.I. (VIN 6) 1996-1997
PL14612
Specifications:
Height 2.93"
O.D. 2.69"
Relief Valve P.S.I. 14-18
Threads: M20-1.5
SUBARU Baja - 4 cyl. 2.5L F.I. (EJ253) (VIN 6) 2006
SUBARU Baja - 4 cyl. 2.5L F.I. Turbo (EJ255) (VIN 6) 2004-2006
SUBARU Forester - 4 cyl. 2.5L F.I. (EJ251) (VIN 6) 2004
SUBARU Forester - 4 cyl. 2.5L F.I. (EJ253) (VIN 6) 2005-2010
SUBARU Forester - 4 cyl. 2.5L F.I. Turbo (EJ255) (VIN 6) 2004-2010
SUBARU Forester - 4 cyl. 2.5L F.I. Turbo (EJ255) (VIN G) 2012
SUBARU Impreza - 4 cyl. 2.5L F.I. (EJ251) (VIN 6) 2004
SUBARU Impreza - 4 cyl. 2.5L F.I. (EJ253) (VIN 6) 2005-2011
SUBARU Impreza - 4 cyl. 2.5L F.I. Turbo (EJ255) (VIN 7) 2009-2010
SUBARU Impreza Outback Sport - 4 cyl. 2.5L F.I. (EJ251) (VIN 6) 2004
SUBARU Impreza Outback Sport - 4 cyl. 2.5L F.I. (EJ253) (VIN 6) 2005-2011
SUBARU Impreza WRX - 4 cyl. 2.0L F.I. Turbo (EJ205) (VIN 2) 2004-2005
SUBARU Impreza WRX - 4 cyl. 2.5L F.I. Turbo (EJ255) (VIN 6) 2006-2007
SUBARU Impreza WRX - 4 cyl. 2.5L F.I. Turbo (EJ255) (VIN 7) 2008-2013
SUBARU Impreza WRX - 4 cyl. 2.5L F.I. H.O. Turbo (EJ257) (VIN 7) 2004-2007
SUBARU Impreza WRX - 4 cyl. 2.5L F.I. H.O. Turbo (EJ257) (VIN 8) 2008-2013
SUBARU Justy - 3 cyl. 1.2L 2 bbl. 1988-1989
SUBARU Justy - 3 cyl. 1.2L 2 bbl. (VIN 7) FWD 1990-1992
SUBARU Justy - 3 cyl. 1.2L F.I. (VIN 7) 1993
SUBARU Justy - 3 cyl. 1.2L F.I. (VIN 7) (Canada) 1995
SUBARU Justy - 3 cyl. 1.2L F.I. (VIN 7) FWD 1990-1994
SUBARU Justy - 3 cyl. 1.2L 2 bbl. (VIN 8) AWD 1990-1992
SUBARU Justy - 3 cyl. 1.2L F.I. (VIN 8) 1993
SUBARU Justy - 3 cyl. 1.2L F.I. (VIN 8) AWD 1990-1994
SUBARU Legacy - 4 cyl. 2.5L F.I. (EJ253) (VIN 6) 2006-2009
SUBARU Legacy - 4 cyl. 2.5L F.I. (EJ253) (VIN B) 2011-2012
SUBARU Legacy - 4 cyl. 2.5L F.I. (EJ253) (VIN C) 2010
SUBARU Legacy - 4 cyl. 2.5L D.I. Turbo (EJ255) (VIN 6) 2008-2009
SUBARU Legacy - 4 cyl. 2.5L D.I. Turbo (EJ255) (VIN F) 2010-2012
SUBARU Legacy - 4 cyl. 2.5L F.I. Turbo (EJ255) (VIN 6) 2005-2007
SUBARU Outback - 4 cyl. 2.5L F.I. (EJ253) (VIN 6) 2006-2009
SUBARU Outback - 4 cyl. 2.5L F.I. (EJ253) (VIN B) 2011-2012
SUBARU Outback - 4 cyl. 2.5L F.I. (VIN B) 2010
SUBARU Outback - 4 cyl. 2.5L D.I. Turbo (EJ255) (VIN 6) 2008-2009
SUBARU Outback - 4 cyl. 2.5L F.I. (EJ253) (VIN C) 2010
SUBARU Outback - 4 cyl. 2.5L F.I. Turbo (EJ255) (VIN 6) 2005-2007
SUBARU Outback - 4 cyl. 2.5L D.I. Turbo (EJ255) (VIN F) 2010
http://www.purolatorautofilters.net/...usedguide.aspx
Old 09-26-2012, 08:59 PM   #14
Big-E
Member#: 123843
2006 WRX Sedan SGM
Wix 57712
Part Number: 57712
UPC Number: 765809577121
Principle Application: Various Subaru (88-12)
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.577
Outer Diameter Top: 2.685
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 23
Beta Ratio: 2/20=2/20
Burst Pressure-PSI: 300
Max Flow Rate: 9-11 GPM
Nominal Micron Rating: 21
SUBARU BAJA H4 2.5L 2458cc
SUBARU BAJA H4 2.5L 2458cc Turbo
SUBARU FORESTER H4 2.5L 2458cc
SUBARU FORESTER H4 2.5L 2458cc Turbo
SUBARU IMPREZA H4 2.0L 1994cc Turbo
SUBARU IMPREZA H4 2.2L 2212cc
SUBARU IMPREZA H4 2.5L 2458cc
SUBARU IMPREZA H4 2.5L 2458cc Turbo
SUBARU JUSTY L3 1.2L 1189cc
SUBARU LEGACY H4 2.5L 2458cc
SUBARU LEGACY H4 2.5L 2458cc Turbo
SUBARU OUTBACK H4 2.5L 2458cc
SUBARU OUTBACK H4 2.5L 2458cc Turbo
SUBARU OUTBACK SPORT H4 2.2L 2212cc
http://www.wixfilters.com/Lookup/App...aspx?Section=1
Old 09-26-2012, 10:14 PM   #15
hoovillemd
Member#: 54341
2012 STI Limited
obsidian black pearl
What issues would a Mobil 1 filter M1 108 cause with Mobil 1 5w-30. I'm looking at running this combo in my new 2012 STI. Thanks
hoovillemd is offline   Reply With Quote
Old 09-27-2012, 04:17 AM   #16
Uncle Scotty
Member#: 16200
OK buy Nates beans
Old 09-27-2012, 08:55 AM   #17
bluesubie
Member#: 767
04 FXT
-Dennis
Old 09-27-2012, 11:18 AM   #18
CRAZYHAWK
Member#: 198067
2009 IMPREZA 2.5i 4d
WHITE Premium
I use this filter in my 2009 2.5i Impreza.
Bosch/Oil Filter
Part Number: 3300 CHECK THE FIT
Bosch premium oil filter with filtech filtration system screens out more harmful contaminants providing superior oil filtration and increased engine wear protection.
Part Number: 3300
Weight: 0.45 lbs
Media Type: Premium synthetic - filtech
Type: Spin-On
Height: 2.930 in. (74 mm.)
Outside Diameter: 2.690 in. (68 mm.)
By Pass Valve: 14-18 PSI
Quantity Per Box: 1
CRAZYHAWK is offline   Reply With Quote
Old 09-27-2012, 02:56 PM   #19
Big-E
Member#: 123843
2006 WRX Sedan SGM
M1-108 Filter:
O.D.: 2.66 [68mm]
Height: 2.49 [63mm]
I.D.: M20 x 1.5
PSI Relief: Yes
Anti-Drain: Yes
Buyers Guide Application Hyundai, Kia (1994-10), Infiniti, Nissan (1995-11) Mazda (1990-08), Subaru (2004-11) (Mazda B6Y1-14-302; Subaru 15208-KA010)
NOTICE THE ANSWER FOR PSI RELIEF? "YES"?
Ok, so what is the PSI relief pressure / pressure-range? It's greater than zero and less than what?
Old 09-27-2012, 03:37 PM   #20
Bottom Feeder
Member#: 2808
Bosch/Oil Filter
Part Number: 3300
Which is a Purolator PureONE PL14612 without the grippy paint and silicone O-ring. FYI.
Old 09-27-2012, 05:27 PM   #21
CRAZYHAWK
Member#: 198067
WHITE Premium
Thank you.
I found this in a motorcycle forum:
Purolator Pure One PL14612, about $6.
Mobil M1-108, about $12.
Made by Champion.
Bosch 3300, about $6.
Made by Champion.
Wal-Mart SuperTech ST6607
Made by Champion.
Old 09-27-2012, 06:24 PM   #22
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Originally Posted by bluesubie View Post
-Dennis
I figured I'd have to return them. Basically I'm waiting for a 14459.5: filter with ADV of the 14459, but the bypass valve spec of the 14460. Though according to what E posted, it's the correct aftermarket filter thus far.
Old 09-27-2012, 07:35 PM   #23
Bottom Feeder
Member#: 2808
Made by Champion.
Bosch filters have not been made by Champ Labs in years. They are Purolators.
Old 09-28-2012, 01:16 AM   #24
Uncle Scotty
Member#: 16200
OK buy Nates beans
Bosch/Oil Filter
Part Number: 3300
Weight: 0.45 lbs
Type: Spin-On
Quantity Per Box: 1
insufficient and out of subaru spec
Old 09-28-2012, 01:18 AM   #25
Uncle Scotty
Member#: 16200
OK buy Nates beans
having the proper bypass pressure is more important than having an anti drainback valve
