Go Back   NASIOC > NASIOC Classifieds > Private Vehicle 'For Sale' Classifieds
Old 09-05-2012, 01:16 AM   #1
telum01
Member Sales Rating: (3)
Member#: 100298
2005 STi
Default GA: 2005 PSM STi *SOLD*
It's time to put my beloved STi up for sale.
Well kept, in great condition aside from a couple of paint blemishes (see pics). Spools like a bat out of hell, handles like nobody's business. Very reliable, never had any major issues at all. No strut clunk (Tokico D-spec rear shocks). Sounds great without being loud. The only reason I'm selling is because I lost my job in May and haven't had a paycheck since, and I'm in the process of getting two companies I just started up and running so I need the cash.
***SCROLL DOWN TO POSTS 15, 21, AND 22 FOR MORE PICS***
2005 WRX STi
104k miles
front axles/CV joints replaced at 84.5k miles
OEM clutch and rear main seal replaced at 87.5k miles
timing belt, water pump, oil pump, etc, replaced at ~95k miles
original engine
paint needs to be touched up in a few places, but otherwise the car is in great condition
title in hand
SOLD
see my member journal on IWSTI for pics and more info about the car and mods.
look at this list of goodness! just look at it!
Current mods:
Cobb AccessPort V2
-Tuned by Mike Sargent
Cusco JDM cat-less downpipe, ceramic coated
Zero/Sports World League cat-back exhaust
Tomei UEL header
Perrin V2 silicone turbo inlet
Deatscheworks 740cc fuel injectors
Deatscheworks 300-LPH fuel pump
SPT Turbo heat shield
Cosworth intake w/ heat shield
Cosworth timing belt guide
Gates "Super Strong" timing belt, tensioners, etc
Subaru 12mm oil pump
Killer B Motorsport Ultimate oil pickup
Killer B Motorsport oil baffle/windage tray
Killer B Motorsport radiator shroud (modified)
Mishimoto radiator
Samco radiator hoses
Grimmspeed 160F thermostat
Grimmspeed lightweight crank pulley
Grimmspeed EBCS
Grimmspeed 3mm phenolic spacers
Grimmspeed TGV deletes
Grimmspeed ported/ceramic-coated intake manifold, throttle body, and TGVs
STi Spec-C Ti front strut brace
Whiteline Steering Rack Bushings
Group N top hats
Group N engine mounts
Group N transmission mount
Group N engine pitch stop
TiC transmission crossmember bushings
TiC Giuyngmyo fender cowl braces
TiC (Not) Bangin' Rear End
TiC Saggy Butt Shims
RCE "black" springs
Kartboy rear subframe "Race" outrigger bushings
Stoptech stainless steel brake lines
Prodrive GC05F 18x8" wheels, British black
Ray's strayt-JDM-tyte Lugs (because i bought them while in Tokyo lol)
Michelin Pilot Super Sport 245/40R18 tires
Autospeed bumper trim (license plate delete)
Oswald Performance front bumper beam
GMS hood dampers
Recaro Pole Position seat, aluminum mounts
Black STi floor mats
Cleared headlights
Hella Supertone 118-dB horns
Subimods bracket and wiring kit for Hella horns
Sony CDX-GT930UI head unit (with iPod hookup routed to glovebox)
Boss Audio 8" amplified subwoofers
Infinity Reference speakers
Forester DIN pocket
Waiting to be installed:
TiC rear diff mount bushings
Kartboy Botox rear subframe lock bolts
http://www.iwsti.com/forums/gd-membe...n-journal.html
telum01 is offline   Reply With Quote
Old 09-06-2012, 03:50 AM   #2
telum01
Member#: 100298
2005 STi
back up top
Old 09-07-2012, 05:23 PM   #3
telum01
Member#: 100298
2005 STi
Fantastic car, up for sale
Old 09-10-2012, 09:06 AM   #4
telum01
Member#: 100298
2005 STi
up top
Old 09-11-2012, 10:44 AM   #5
telum01
Member#: 100298
2005 STi
i need to move this car, so i'm willing to entertain reasonable offers.
Old 09-11-2012, 10:48 PM   #6
gotboost954
Member#: 231214
Do you have any other pics? What needs to be touched up on the paint?
gotboost954 is offline   Reply With Quote
Old 09-11-2012, 11:00 PM   #7
dylangood25
Member Sales Rating: (2)
Member#: 253099
2004 OBP STI
is that vantage yours?
dylangood25 is offline   Reply With Quote
Old 09-12-2012, 12:06 AM   #8
telum01
Member#: 100298
2005 STi
here's some info answering one of the PMs i got earier, hopefully it answers some questions:
I do still have the stock seat, but I've turned it into an office chair that I use on a daily basis. The Recaro is surprisingly comfortable. I'm 5'7" 160 lbs and I can sit in it for hours without a problem. I've done 8 hours in the seat with no issue, so if you're close to my size, it shouldn't be too uncomfortable. Recaros are generally a bit more roomy. If you've ever been in a Bride seat, it's nothing like that at all. I can't sit comfortably in one of those for even a few minutes, let alone hours. However, the seat is hard-mounted to the car without sliders. When I ordered the seat, mounts, base, and sliders, the order was mixed up and the sliders didn't fit with everything else. I modified the mounts (just had to drill an extra pair of holes) and bolted the seat in place exactly where I needed it. So not only is the position fixed, it also transmits a bit more vibrations than you might be used to. The main cause of the vibrations are some bushings in the rear of the car. The bushings are somewhat adjustable in that they are three pieces that can be swapped out for more-or-less stiffness. They are very easy to swap out and take 10 minutes total. The seat is pretty easy to swap out as well.
I still have the stock front bumper beam, and three of the OEM BBS wheels (silver), along with a Ray's 57F wheel (bronze), that I have no need for. I'll throw in all the wheels for free at the asking price of the car. I also have a couple other parts that have yet to be installed (Kartboy rear subframe lock bolts and TiC rear differential mount bushings) that will be included with the car. I think I still have the original stock fuel pump, water pump, oil pump, TGV gears/motors, and maybe a few other things. Most of those came off the car when I did 105k mile major service (I did it at about 95k miles). I did remove the front U-brace, I still have it and it's also included with the car. (I removed it for weight reduction from the front. Along with the lightweight front bumper beam and lighter crank pulley, the weight distribution of the car is much better and the handling is phenomenal.)
i don't have any newer pics. my laptop crashed a week ago with the pics i did have, and my home-built PC doesn't have a card reader. i've got a friend that is supposed to bring a card reader over tomorrow, hopefully she remembers.
the hood has a couple swirls from a sponge that had grit in it. the front passenger door has a scrape in the paint from someone's door, and the rear passenger door has a scrape from someone's bumper. unfortunately, i live in an area with the most inconsiderate people on the planet.
the repairs should be paint only, i don't think any body panels need to be replaced at all. but i'll try to get pics tomorrow or the day after.
yep
Old 09-12-2012, 08:44 AM   #9
mordenkanen
Member#: 331942
Can you please send me some better pics of the car inside and out.
PS looking to buy now.
mordenkanen is offline   Reply With Quote
Old 09-12-2012, 10:47 AM   #10
telum01
Member#: 100298
2005 STi
i'll be getting some pics up later today.
Old 09-12-2012, 02:50 PM   #11
telum01
Member#: 100298
2005 STi
pics added to first post. these were the only pics i was able to get off my laptop before it crashed. i'll wash the car and get some better pics of the scratches in the paint. hopefully i'll be able to post them tomorrow when i get a card reader.
Old 09-12-2012, 03:01 PM   #12
StiRhino
Member Sales Rating: (40)
Member#: 245964
2011 STI
If you need a drivers seat I have one and I'm in atlanta. if not I plan on making it into an office chair also.
StiRhino is offline   Reply With Quote
Old 09-12-2012, 03:18 PM   #13
telum01
Member#: 100298
2005 STi
thanks! i'll give you a shout if i need it.
Old 09-12-2012, 05:54 PM   #14
mordenkanen
Member#: 331942
when you need my email address just PM me.
Old 09-12-2012, 07:55 PM   #15
telum01
Member#: 100298
2005 STi
took these using my cell phone so they aren't the best quality. please note the car is dirty and needs a bath lol.
hood swirls from a gritty sponge. two spots on the hood: driver's side edge and leading edge.
scrape from someone else's door (not a ding, metal is fine, only paint was scraped)
scrape from someone else's bumper (just paint)
both doors with scrapes. the scrape on the front door is the thumb-sized one, several inches below the door handle. the long scrape is on the rear door just above the crease in the door.
interior shots (carpet is dirty, just needs to be vacuumed)
Old 09-13-2012, 04:13 AM   #16
telum01
Member#: 100298
2005 STi
PMs replied to.
Also, my thumb needs a tan.
Old 09-13-2012, 08:45 PM   #17
happycorey
Member#: 324849
2005 STI
If this is strangely available in a month I might try to work something out.
happycorey is offline   Reply With Quote
Old 09-14-2012, 12:11 PM   #18
telum01
Member#: 100298
2005 STi
Well I hope for my sake that it isn't, but you won't be disappointed if you do pick it up!
Old 09-15-2012, 04:16 PM   #19
telum01
Member#: 100298
2005 STi
weekend bump
Old 09-16-2012, 06:21 PM   #20
telum01
Member#: 100298
2005 STi
PMs replied to, first post updated with more info
Old 09-18-2012, 10:55 AM   #21
telum01
Member#: 100298
2005 STi
we've been getting rained on so i had to do a very quick wash, but here are some more pics.
Pics of the scrapes on the passenger side doors:
the swirls in the hood. you can't even see them from some angles and yes, you should be able to have them buffed out.
Old 09-18-2012, 10:59 AM   #22
telum01
Member#: 100298
2005 STi
some more pics of the interior. the ones a few posts above were taken with my cell phone. the pics in this post were taken with a Nikon (default "auto" settings). i did NOT clean the interior whatsoever between taking the first set of pics and this set, and even drove the car each day in between. the interior is about as dirty as it gets, and looks dirtier in the pics than in person (especially the floor mats, which are not brown at all.
Old 09-18-2012, 11:59 PM   #23
telum01
Member#: 100298
2005 STi
I need to get this car sold! Plenty of interest, just need someone to pull the trigger!
Old 09-19-2012, 11:15 PM   #24
telum01
Member#: 100298
2005 STi
le bump
Old 09-20-2012, 01:04 AM   #25
Thor6
Member#: 229211
2003 WRX
MBP
I might be able to get this, I'll know within a week. In the meantime, super sexy ride (both) and GLWS!
Thor6 is offline   Reply With Quote
