#1 |
Member#: 305714
I have a 1996 subaru impreza wrx sti, v3 gc8d, jdm rhd. Does mine have the same motor as the 2002 bugeye wrx?
If I were to need engine parts would I just go to the local parts store and ask for the 2002 wrx parts? Or do some match and some do not? Thanks alot.
#2 |
Member#: 206851
Vehicle:99 V4 EJ20K RS |
no, it is nothing alike.
put wanted ads up here, what do you need? |
#3 |
Member#: 305714
Atm nothing, maybe sparkplugs, maybe a thermostat and also maybe a power steering pump which is the biggest issue...
Thanks for the quick reply btw. |
#4 |
Member#: 206851
you can get plugs and tstat from an 02 wrx.
where do you live? Ps pump should be bought off here for under 50 bucks |
#5 |
Member#: 305714
No way! I live in manitoba, canada. I just got the car and first I want to start off with maintance, fluids, maybe plugs and thermostat, going to get it winter ready also, winter tires, block heater and undercoating just to be safe again rust..
and the reason i asked for power steering pump is because once in awhile when I make a turn ill hear a whine and I am thinking its the power steering pump making some noise... but it only does it once in a while... |
#6 |
Member#: 206851
just be sure to feed the K some quality oil, such as Rotella t6
#7 |
Member#: 305714
Ya definetely would have to get some good quality stuff, thanks alot for the help.
#8 |
Member#: 257043
VIC
Vehicle:1993 JDM WRX Wagon Black |
Squeal doesn't necessarily mean new ps pump needed.
Swap/flush power steering. Use a turkey baster and suck out all the old PS fluid from reservoir. Refill with new. Repeat after a couple days of driving. Also look at replacing your accessory belt. Make sure not to over-tighten the belt. Squealing could also just be belt slippage from worn belt. Plugs for your 96 will be the same as for an 02 wrx. Thermostat will also be from an 02 wrx. Radiator is from an 94 legacy turbo but without the trany cooler (try a legacy racing radiator). Radcap is the same as a 02 wrx. Rad hoses are different. Fuel pump from/for an 02 wrx will work (such as a walbro 255lph). Fuel filter from an 02 wrx will work. Oil filter from an 02 wrx will work. Water pump will be differient unless you have the oil/water heat exchanger. Fuel pressure regulator from an 02 wrx will work. Last edited by TommyAtomic; 09-25-2012 at 09:57 AM. |
#9 |
Member#: 16819
SCIC
Vehicle:2002 MBP WRX, '98 OB Three Gen 1 Legacy Turbos |
Make that '91-'94 Legacy tubo parts (not '96).
Radiator hoses should be the same as the early turbo Legacy. Rocker cover gaskets should be the same as a '97-'99 Legacy EJ25D. The non-oil-cooler water pump is the same a '92-'94 (NOT '91) Legacy turbo. The oil-cooler pump is a WRX pump (as mentioned). |
#10 | |
Member#: 257043
VIC
#11 |
Member#: 334960
W. Canada
Vehicle:1996 WRX - silver 2010 impeza 2.5i - silver |
What about the head gasket? would it be the same as the 02
#12 |
Member#: 51480
International
Vehicle:1984 AM5, 1994 BC4, 2010 BR5 |
No. USDM 02 WRX head gasket is 0.8mm thick and EJ20G and EJ20K gaskets are 1.4mm thick. 02 WRX pistons are 0.3 mm under deck, EJ20G and EJ20K piston protrude the deck by 0.3 mm.
#13 |
Member#: 133923
NWIC
Vehicle:03 Legacy GT wagon I love goooollllllllddddd |
you can get a power steering pump rebuild kit for under $30 from the dealer. pop it all apart and replace the seals. its really fast and easy (if you have an impact gun)
