Old 09-24-2012, 04:17 PM   #1
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
Default About to install gauges looking for a decent crimping tool
I hate those cheapo crimpers that distort unevelently terminals and mess up insulated ones like the typical you would find in home depot, looking for a decent crimper.
Most of my crimpring will be 16 awg wires.
I kinda like these Amazon offerings, cost about the same, seems the S & G in the top picture have a better screw type die fastening system:
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 09-24-2012, 08:15 PM   #2
hoffmanEstates
Member#: 122043
04 wagonier
psm
That's over kill..... hop on a Snapon or matco truck. Ask them
hoffmanEstates is offline   Reply With Quote
Old 09-24-2012, 09:43 PM   #3
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
I got some strippers/crimpers from harbor freight. <$10. still work.
aerosaaber is offline   Reply With Quote
Old 09-24-2012, 10:07 PM   #4
Tmibiker
Member#: 328048
2002 Impreza 2.5TS
Midnight Black Pearl
I've got a pair similar to these, and I'm extremely happy with them. From what I understand, Klein makes a lot of specialized electrician and industrial tools.
http://www.amazon.com/Klein-J1005-Journeyman-Crimping-Cutting/dp/B000936OTY/ref=sr_1_1?ie=UTF8&qid=1348535131&sr=8-1&keywords=klein+crimperhttp://www.amazon.com/Klein-J1005-Journeyman-Crimping-Cutting/dp/B000936OTY/ref=sr_1_1?ie=UTF8&qid=1348535131&sr=8-1&keywords=klein+crimper
Pretty good value and versatility if you ask me.
Tmibiker is offline   Reply With Quote
Old 09-27-2012, 09:51 PM   #5
bluemk3
Member#: 263694
World Rally Blue
Why doesnt anyone wire things up right with solder and shrimkwrap.....
bluemk3 is offline   Reply With Quote
Old 09-27-2012, 10:00 PM   #6
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
because
Old 09-29-2012, 12:50 PM   #7
indytruckboy
Member#: 192599
2004 STI
2007 Outback Wagon
Originally Posted by V8 GTFO Lesbic WGN
because
Cold solder. Not done properly.
I think solder is the best way. But OP, I have the first crimper. It is a bit overkill for simple butt connectors. Great for specialized ends. I just brought mine home from work to crimp 8 gauge wire ends for my DIY ground kit.
indytruckboy is offline   Reply With Quote
Old 09-29-2012, 01:20 PM   #8
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Silver solder and shrink-wrap <or> butt-connectors with shrink-wrap built-in.
Old 10-01-2012, 03:42 PM   #9
racereddy20
Member#: 321077
2009 WRX
I work with something similar to number one. I love those things.
racereddy20 is offline   Reply With Quote
Old 10-01-2012, 03:52 PM   #10
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
You mean this? Why you love it?
Old 10-01-2012, 04:14 PM   #11
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
http://www.amazon.com/Klein-J1005-Jo...=klein+crimper
Since you say similar did you get the Greenlee at Home Depot for half the price at $17 vs Klein's $37?
Old 10-01-2012, 08:34 PM   #12
hoffmanEstates
Member#: 122043
04 wagonier
psm
Soldering is a skill only a percentage know how. And ya need a thin solder and good gun and clean ungreasy virgin. Wire.
Old 10-04-2012, 06:59 AM   #13
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
soldering is easy and superior to mechanical crimps:
1) stick end of wire into soldering paste so a bit is on the wire.
2) tin that end by heating until paste bubbles and apply a wee bit of solder...melted solder flows completely into wire braids.
3) repeat on 2nd wire.
4) slip on heat shrink
5) hold two wire sections in contact and parallel and heat until all solder is melted completely and remove heat.
6) continue to hold wires together until solder is firm.
7) shrink heat shrink around two ends.
soldering paste is avail in plumbing section of yer home improvement store for like $3.
mhoerath is offline   Reply With Quote
Old 10-04-2012, 08:42 AM   #14
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Soldering paste(flux) is not necessary with rosin-core solder, the flux is already in the solder. And, the paste you get at the plumbing store may contain acid and is NOT suitable for electrical use. Don't buy solder there either, it will be acid-core.
Get your soldering supplies at Radio Shack, their solder is actually pretty decent (at least it used to be).
Use a temperature-controlled soldering station for the best results, not a gun or high-wattage iron. Too much heat will produce poor results, more is not better.
See the sticky thread here about soldering.
http://forums.nasioc.com/forums/show....php?t=1021577
Old 10-04-2012, 01:22 PM   #15
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
guys this is about crimping tools please.
Old 10-04-2012, 01:32 PM   #16
lavid2002
Member#: 226864
lavid2002 is offline   Reply With Quote
Old 10-04-2012, 01:38 PM   #17
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yes it is, but I had to add some corrected info regarding soldering. Carry on with the original topic.
