Vancouver Impreza Club
Old 09-25-2012, 12:05 AM   #1
hipower
Member#: 155756
369 tribeca 7 pass
vf34wrx,06 sti,08cbr600rr
Default check engine and cruise control light on
today my wife was driving the tribeca around and then suddenly the car studdered then the cruise control,check engine and the oil temp light turned on so she parked the car for a couple hours and then turned it back on but the cruise control light and check engine was still on but the oil temp didnt turn back on.So she drove the car home slowly.When she got home i checked the oil dip stick and it was empty so i put in a litre and a half and it was back to full,i notice in the middle of the oil cap threads the oil was burnt.Taking the car to dealer tommorrow but was just wondering what u guy think should i be worried.Car drives fine,no strange noises or leaking any thing just worried cause the the oil underneath the oil cap is burnt and the oil temp was on
hipower is offline   Reply With Quote
Old 09-25-2012, 02:16 AM   #2
notjustforshow
Member#: 143277
05 STI PPP OBP
1098, Z1000
Maybe somehow checking the code before going would help?
Going in blind may end up costing unnecessary dollars.
notjustforshow is offline   Reply With Quote
Old 09-25-2012, 02:18 AM   #3
hipower
Member#: 155756
369 tribeca 7 pass
it still under warrenty
Old 09-25-2012, 03:11 AM   #4
notjustforshow
Member#: 143277
05 STI PPP OBP
1098, Z1000
Warranty or not, I still think it is a good idea to get the code pulled beforehand. If you have time to do this, it may save you some money, should they say the potential repair is not covered by warranty.
You had to add oil, approximately 1.5L in order to get the level into the dipstick range. The remaining cruise control light and cel indicates that the car thinks it is not safe to go on the highway. Something is up, and they may try to say it is not covered because of "supposed" lack of maintenance, so this is why knowing beforehand is a good idea. I don't know if I would clear the code before taking it to the dealer.
For wrx and wrx sti, (2002-2007 average of 50k Miles) the majority of oil pressure light warnings were for broken oil-pickup iirc. Not sure about the other cars.
Old 09-25-2012, 03:37 AM   #5
DIGGYGV8
Member#: 313558
2011 STi Sedan
Check engine + cruise + traction (if you have) is "limp mode"
Anything wrong with the car, it will stutter and keep you in that mode till then.
Best check it out, but it seems it may have died with oil starvation. Hope it goes well.
DIGGYGV8 is offline   Reply With Quote
Old 09-25-2012, 08:06 AM   #6
ofspunk7
Member#: 249401
2005 LGT and 91 MX5
Check the code at a local auto parts store for free.
Check your oil more often!
ofspunk7 is offline   Reply With Quote
Old 09-26-2012, 02:57 AM   #7
hipower
Member#: 155756
369 tribeca 7 pass
good news just got the suv back from the subaru dealership,the check engine and cruise control lights where cause from the automatic transmission shift solenoid needing to be updated.Had them do a hot engine flush and new synthetic oil change,everything seems fine and they said they didnt find anything else wrong
Old 09-26-2012, 03:04 AM   #8
hipower
Member#: 155756
369 tribeca 7 pass
only stutter for a second when the lights turned on after that it drove fine just the lights where on
[/quote] the suv drove fine it didnt die just the check engine light.the cruise control, and my drive indecator turned off
Old 09-30-2012, 05:07 PM   #9
WrxJedi
Member#: 333776
Default Smog Pump
Codes basically are saying your smog pump is out.
WrxJedi is offline   Reply With Quote
Old 10-01-2012, 12:51 PM   #10
2010 WRX Limited
Member#: 217458
1989 Mazda Miata
Classic Red
This is some awesome armchair mechanics going on here.
Here's what I think happened: Engine is shot, car is worthless. Bring it by my house and I won't charge you to get rid of it. hahaha
Good to hear that it's fine, I wouldn't sweat the low oil thing too much, the difference between off the dipstick and full is only 1.5L.
2010 WRX Limited is offline   Reply With Quote
Old 10-01-2012, 04:20 PM   #11
Jeff54
Member#: 129503
2002 It's resting
6 > 4?
I've seen this before. The car is possessed....it's haunted by demons...but you're lucky i found you...i can perform an exorcism on the car for a case of beer.....true story....
Jeff54 is offline   Reply With Quote
