Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 09-25-2012, 12:50 AM   #1
morrocco88
Member Sales Rating: (70)
Member#: 104098
97' LGT 2.3 Dstroke
Rotated BW S256 6speed
Default Custom Borg Warner ROTATED PIPING KIT
I've designed and built a custom rotated kit based on a Borg Warner Airwerks 7670 (S200SX-56). It was built on a 02' Bugeye, and will fit 02'-07' wrx and STI's. I've also confirmed fitment on swapped 93'-01' Impreza, swapped BD and BG Legacy, and an 07' Forester. I made a jig to build a couple extra for some friends of mine, but a couple backed out... So I'm selling them so I'm not out the money.
The turbo can be purchased new for $699 and can be ordered with the following three hp ratings:
44lb = 440hp: S200sx-RS-50
47lb = 470hp: S200sx-RS-51
58lb = 580hp: S200sx-RS-56 (This one made 475whp on 20 psi and pump gas with a built 2.5 liter)
This kit also made 540whp on another car with a larger Garrett turbo, so the diameter of tubing will work for a lot of H.P. goals out there.
They all have the same turbine wheel which is the same aero as the new EFR turbos, but is just not made of the fancy Gama-Ti material. The turbine housing is a T3 inlet with either a .63 or .82 A/R and can be ordered either 3" v-band or 4 bolt oulet, but you should order it 3" v-band since that is what my kit uses, and I would recommend the .63 since the housings run bigger than Garretts. The compressor housing is 3" inlet and 2" outlet. The turbo is Oil cooled, so no more water lines! Just an oil feed line and a drain hose.
The turbo can be purchased from AGP turbo. The three I have listed is a genuine Borg Warner center section and compressor housing with one of AGP's Turbine housings to make it single scroll, as these are all twin scroll originally from Borg Warner.
Here is the 47lb S200sx-RS-51
http://www.agpturbo.com/borg-warner-...-turbocharger/
The kit includes an 2" diameter up-pipe, 3" down-pipe and dump tube for the wastegate. The up-pipe is 2 bolt factory style bottom flange - T3 top flange - and flanged for 44mm v-band Tial wastegate, but can be used with any wastegate that uses the 44mm v-band Tial style flange. The whole kit is made of 16 gauge, 304SS. The up-pipe flanges are 1/2" thick, and there is a nice stainless flex section in the up-pipe, and at the end of the down-pipe to help it easily bolt up to the cat back. The down pipe length is to the stock catback location.
Here are some fitment pictures to show turbo location and wastegate position ect. These are early mock-up/development pics.
Nicely centered from all it's surrounding, and can run IC piping under the manifold if wanted.
Good quality welds throughout!
Fitment on my swapped 97' Legacy GT and another way of routing the IC piping if you choose.
DP has an o2 bung and a bracket to bolt to the factory tranny hanger.
The up-pipe has two nice braces that bolt to the factory up-pipe bracket location.
This Rotated piping kit is $950.
Shipping will be actual shipping charges. If you want to calculate it, you can do it at UPS online. Box dimensions 48 x 24 x 12, and weight is 25lbs. FYI, it was an average of $50 to $85 depending on a few zip codes I tried.
I also have one kit with a different down-pipe that will allow the use of a Garrett turbo with the newer style 3" 4-bolt turbine housing. That friend of mine changed his mind and went with a v-band housing instead.
Please PM me if interested, and DO NOT RESPOND TO THIS THREAD to keep it neat and tidy!
Thanks!
Garris
morrocco88 is offline
Old 09-25-2012, 06:24 PM   #2
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Bump for rotated goodness!
Old 10-03-2012, 01:45 AM   #3
Justin V
Member Sales Rating: (57)
Member#: 98747
07 WRX
Any intent on making a twinscroll uppipe? I know BW has twinscroll options on alot of their turbos
Justin V is offline
Old 10-05-2012, 01:38 AM   #4
WRX2EVOX
Member Sales Rating: (14)
Member#: 203011
04 WRX
Bump for an awesome product and great guy to deal with.
WRX2EVOX is offline
Old 10-05-2012, 01:22 PM   #5
subbi7
Member Sales Rating: (1)
Member#: 241967
02 wrx
bump for twinscroll uppipe
subbi7 is offline
Old 10-05-2012, 06:46 PM   #6
mackeymx
Member Sales Rating: (8)
Member#: 258525
2004 STi-BW7670
R6-Red/White
You have pm sir. Please get back to me ASAP.
mackeymx is offline
Old 10-10-2012, 09:35 PM   #7
sofakingdope
Member#: 274669
whats the price for down pipe only? and price for down pipe and up pipe? shipped 97305
sofakingdope is offline
Old 10-11-2012, 01:15 AM   #8
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Default Please Read People!
Responded to PM's, and NO I'm not building twin scroll up-pipes, or custom stuff for everybodys unique situation. I have what is listed in the first post, they are already built, and that's what I'm selling. If that is what you are interested in, PLEASE SEND ME A PM.
Thanks!
Also, I have great communication, and excellent packing skills. Check my feedback and buy with confidence!
Old 10-30-2012, 02:23 AM   #9
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Bump for back purged welds, and O.C.D attention to detail! Quality made in the USA, Rathgibson stainless tubing. Don't buy crap from China!
Here you can see the hose keeping the inside of the tubing filled with Argon. This ensures the strongest welds and the inside is all smooth with no "sugaring" or crusty stuff.
Thanks for looking!
PLEASE PM ME IF INTERESTED, DO NOT REPLY TO THIS THREAD!
Old 11-05-2012, 09:57 PM   #10
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Bump it up
Old 11-05-2012, 10:22 PM   #11
sleazy07sti
Member Sales Rating: (19)
Member#: 273116
2007 Hawkeye Sti
0bp
Got my kit from this guy...cant wait to put it on also looking forward to doing group buys with this guy,great seller even faster shipment...
sleazy07sti is offline
Old 11-10-2012, 09:04 PM   #12
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
^^^Thank you sir! Bump it up.
Old 11-16-2012, 11:34 AM   #13
NW2TONE
Member Sales Rating: (11)
Member#: 212509
unde your hood makin
your **** go faster
heres the kit in my car with custom fmic piping I made!!
NW2TONE is offline
Old 11-17-2012, 12:01 AM   #14
STi4life06
Member#: 315369
Just go my kit today and I have to say I am very impressed with the craftsmanship of this kit. Great communication throughout. I HIGHLY recommend this kit and seller!! Thanks again man this winters project has officially started!
Bump.... Go rotated!!!!
STi4life06 is offline
Old 12-01-2012, 12:53 PM   #15
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
^^^Thanks! I'm glad you are happy with your purchase and buying experience!
Old 12-04-2012, 01:10 PM   #16
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Bump for winter projects/upgrades! Make this your Christmas gift!
Old 12-10-2012, 12:48 PM   #17
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Bump it up!
Old 01-02-2013, 12:48 PM   #18
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
New Years bump!
Old 01-02-2013, 03:34 PM   #19
Type2
Member Sales Rating: (29)
Member#: 200436
2004 Forester XT
I just wanted to say that I got my parts in very quickly and they look awesome. Everything was packed extremely well. A lot of thought and care went into the production and shipment of this kit. Absolutely, hands down the best communication I've ever had from a seller. Every day for over a week I sent him a laundry list of questions and he answered them all in detail. I took a bunch of pics of the kit if anyone is interested.
Type2 is offline
Old 01-16-2013, 04:30 PM   #20
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
^^^^Thanks for the kind words. I'm glad you are happy with the kit and your buying experience!
Old 01-20-2013, 04:54 PM   #21
CBrodie14
Member#: 289852
95 L sti swapping
green
I also have a rotated kit built by morrocco88 and I back the product 100 % in the craftmanship quality but don't have any experience with fitment just yet. But considering they were all made of the same specs I do not think there will be any fitiment issues big enough to get irrate about.
Pics available to those questioning the buy or not.
Thanks again morrocco88.
CBrodie14 is offline
Old 01-24-2013, 03:26 PM   #22
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
^^^Thanks again for your purchase and feedback!
Old 01-28-2013, 09:14 PM   #23
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Bump for a very affordable, high quality rotated piping kit!
Old 01-31-2013, 01:41 PM   #24
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
I ski, you ski, we all want a bumpski
Old 02-04-2013, 07:22 PM   #25
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
bump bump
Closed Thread
