Old 09-25-2012, 12:05 PM   #1
CPU GUY
Member#: 203347
07 STi
Default Installed PIAA Sport Horns on my STI
I just got PIAA sport horn for my 07 STi from amazon. I think they sound better than hella supertones, anyway I am having problems with installing the horn. I went through DIY thread we have in the forum here, but they didn't make any sense to me. I also ordered sickspeed horn harness wiring kit to make it easier to install I am more confused now
here is a link for the kit
http://www.ebay.com/itm/HORN-WIRING-...de6284&vxp=mtr
and installation diagram here
http://sickspeed.com/pages/wiring.html
PIAA sport horn look excatlly like hella supertones from behind, so should I make my own wiring or using the harness kit from sickspeed ? need some help here
These are pics of the horn
these wires came with the horns
here is a link from PIAA website for installing instructions
http://piaa.com/automotive-lamps/ins...ns_install.pdf
I am so confused which way I should go ?
I know number 1 should go to the battery what about 2,3 and 4 ?
Finally I figured it out
CPU GUY is offline   Reply With Quote
Old 09-25-2012, 12:59 PM   #2
Jmhm17
Member#: 224097
2012 WRX Hatch - DGM
Stage 1 - Tuned by Bren
Pretty self explanitory.. I'm trying to think of a easy way to explain it but you have all the info you need in all of the links you provided.
what dont you understand? one side of the horn goes to ground, and the other side either goes right to the stock horn signal wire (if not using the relay) or 86 on your relay, and your horn signal goes to 87 on the relay..
All the harnes does is take the load off the signal wire so it dosnt melt.. you can do it with out the harness but since you already bought it, use it.
Jmhm17 is offline   Reply With Quote
Old 09-25-2012, 08:16 PM   #3
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
you just have to figure out whichj side should be ground and positive (it may not matter)
easiest way to do that?
use wires to the battery and try it out each way.
aerosaaber is offline   Reply With Quote
Old 09-25-2012, 10:33 PM   #4
CPU GUY
Member#: 203347
07 STi
you can see on the diagram there are two vampire clips, but in the real there is only one How I should ground the horns ?
Old 09-25-2012, 10:45 PM   #5
raskal187
Member#: 302996
04 Wrx STI
wr blue
There's a video on YouTube of a 04 Wrx installed with hella tones
raskal187 is offline   Reply With Quote
Old 09-25-2012, 10:46 PM   #6
raskal187
Member#: 302996
04 Wrx STI
wr blue
Sorry if this ain't what you looking for. But I'm pretty sure it would he installed the same way
Old 09-26-2012, 10:15 AM   #7
CPU GUY
Member#: 203347
07 STi
Old 09-27-2012, 07:50 PM   #8
CPU GUY
Member#: 203347
07 STi
anyone help ?
Old 09-29-2012, 08:43 PM   #9
Jmhm17
Member#: 224097
3 and 4 are postive they go to your horns. 2 is the bat ground but I'm not sure you may have to trace them back to the relay and find out what pole they are on. I do not know what the red wire with the vamp clamp on it is. And no idea where you signal wire is. It looks like your missing something. I know there are hundreds of threads on how to wire these horns. I did mine last week and it took 10 min start to finnish. If your having this much trouble i would not use the harness or ask if some one local could help
Just look at the pics you provided and follow them..
Old 09-29-2012, 09:15 PM   #10
omz
Member#: 232060
3&4 are for the horns, the black wire in the horn pic is ground, 2 is a splice for signal to relay, and a ground from signal from relay, and 1 is the relay and power itself.
Seems simple, should be installed in about 3 minutes
omz is offline   Reply With Quote
Old 09-30-2012, 05:39 AM   #11
CPU GUY
Member#: 203347
07 STi
Old 10-04-2012, 08:19 PM   #12
green_banana
Member#: 325976
2008 Impreza STI 5Dr
I ordered this same PIAA 500Hz/600Hz kit. is the relay wiring harness really necessary? I plan to replace the stock low tone (on front core support) and high tone (under passenger side head light). the PIAA website says wiring harness is not necessary.
http://www.piaa.com/automotive-lamps...ries-horn.html
green_banana is offline   Reply With Quote
Old 10-04-2012, 09:26 PM   #13
CPU GUY
Member#: 203347
07 STi
it's not necessary, but it's safer
Old 10-05-2012, 05:29 PM   #14
green_banana
Member#: 325976
I took a look at the service manual. PIAA dual horn kit total current draw is about 5.4A and fuse size the in horn circuit is 15A located in the fuse box under the hood. plus there's already a relay in the factory horn circuit. adding a 2nd relay in the horn circuit seems redundant and another part to fail.
