Old 09-26-2012, 03:38 AM   #1
ThunderousProduction
Member#: 282899
Default Hard to downshift 5 speed rallispec gears
2006 Subaru Wrx with upgraded gears to rallispec sti set. All up shifts are normal but I am running into a problem where shifting from 4th gear to 3rd gear has become very hard. It doesn't grind or make any noise but to physically
Push into 3rd gear has become difficult. Going from 4th to neutral then moving the shifter from left to right still In neutral allows me to easily go into 3rd. It's simply the straight push from 4th to 3rd that is so difficult. Any ideas?
ThunderousProduction is offline   Reply With Quote
Old 09-26-2012, 05:46 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Any ideas?
who did the install???
Old 09-26-2012, 10:39 AM   #3
Member#: 282899
I did the install at my house with a professional lotus mechanic who worked for NASA helping out. He is extremely knowledgable and everything was silky smooth for 5000 miles
Old 09-26-2012, 08:04 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
well...maybe yer professional dont know about subaru transmissions and screwed the p00ch somewhere and it needs to be taken down again and figure it out
this kind of thing happens all the time...you can know everybody but god himself, and if they never did a subaru transmission, odds are they gonna get it wrong the first time around
Old 09-27-2012, 08:20 AM   #5
Member#: 282899
I have a feeling for some reason I bent a shift fork. its prefectly fine except when put into 4th gear it really doesnt wanna leave it.
Old 09-27-2012, 09:28 AM   #6
wrxtuner25
Member#: 260479
2010 WRX
Like uncle Scotty said I would tear the transmission back down again and you can inspect and see where it's possibly rubbing. If you do it early enough you will prevent further damage. Also check and see if you put the correct viscosity of gear oil in because this can sometimes cause hard shifts as well.
wrxtuner25 is offline   Reply With Quote
Old 09-28-2012, 12:47 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
this issue isnt lube related...
Old 10-05-2012, 07:41 PM   #8
foolio
Member#: 9351
2006 trailblazer SS
black
Start with the basics, check your linkage under the shifter and all that stuff. If there is an issue internal then it would be something around the 3/4 gears. 3/4 sleeve and hub, 3rd syncro, 4th bulk ring, or 3/4 shifter fork. Sometimes on the shifter forks the little nylon tabs wear off so your sleeve is just riding on aluminum. If that happens then you would get a condition like what your describing.
Good Luck
foolio is offline   Reply With Quote
