South East Region Club
Go Back   NASIOC > NASIOC Regional Areas > South East Region Forum
Old 06-28-2013, 11:13 PM   #1026
blkbugeye
Member#: 287821
2005 WRX STi PSM
*sold* 2002 WRX Sedan MBP
Im down
blkbugeye is offline   Reply With Quote
Old 06-29-2013, 01:07 AM   #1027
flippymcbean
Member#: 198546
2003 Evolution VIII
Lightning Yellow
cool? i'll come with more details as time goes by. i'm probably going to california for 2 weeks in october.
flippymcbean is offline   Reply With Quote
Old 06-29-2013, 01:32 AM   #1028
blkbugeye
Member#: 287821
2005 WRX STi PSM
Sounds good to me.
Old 07-02-2013, 12:52 AM   #1029
flippymcbean
Member#: 198546
2003 Evolution VIII
Lightning Yellow
I'm looking for medium to large sized dog. Any reccomendations?
Old 07-02-2013, 11:31 AM   #1030
yongsik_park
Member#: 228107
2005 Impreza WRX
Dark Grey Metallic
Damn Korean ribs. Lol.
yongsik_park is offline   Reply With Quote
Old 07-03-2013, 11:37 PM   #1031
Brown Ops
Member#: 291770
2004 Impreza WRX STI
Java & satin black
Hey Flippy, do you know what CEL's my car threw?
Brown Ops is offline   Reply With Quote
Old 07-03-2013, 11:38 PM   #1032
Brown Ops
Member#: 291770
Java & satin black
Get a hamster or guinea pig.
Old 07-03-2013, 11:46 PM   #1033
flippymcbean
Member#: 198546
2003 Evolution VIII
Lightning Yellow
The only codes I got were the codes you had before you left. Also when I disconnected the battery the codes never showed up again.
Old 07-04-2013, 02:14 AM   #1034
Brown Ops
Member#: 291770
Java & satin black
Hmmmm. I had forgotten about those CEL's. It was a day before I left too. Dang. Anyway, I linked this thread onto the North Florida Suby Group. People may ask some questions as I don't know all of the details pertaining to how the car is currently acting, noises, etc. It was time for a 20G anyway. I want to figure out what caused that turbo to fail so that I dont waste 1000+ to wreck another snail. Once again man, thank you for your help.
Old 07-04-2013, 11:51 AM   #1035
flippymcbean
Member#: 198546
2003 Evolution VIII
Lightning Yellow
Is that what I get for trying to get a faster car than you? Haha.
Description:
Like I said before, the car had oil. I checked the transmission oil to because if your wife's description, but honestly that has nothing to do with it. The CELs that were showing up were the p0011 and p0021. I think those were the codes. But last time I checked it had to so with the AVCS. I tried to clear them on your AP, but really couldn't figure it out. I don't know if you have to plug the green plugs under the car the dash to do so. So I just did it old school and reset the CELs. The CELs did clear and for the 10-15 minutes I had the car running nothing came back. For now I guess. So come test drive time, i drove it easy. I have it a little kick and no go on boost. It stayed at "0" or slightly below. Gave it one more try in 2nd gear went wide open throttle and nothing. Immediately turned around to investigate the turbo. I checked your vacuum lines near the turbo and intake manifold. Everything seemed okay. I would recommend a few clamps but other than that...it looked fine. On to the turbo. As I look around I seem smoke coming from underneath the heat shield. If I had time I would have let the car cool off and pull the shield off. Just to hot and I had to go to work. I already know about your valve cover gasket. It wasn't that. But other than that, that was all I noticed. My opinion(and I'm not a tech or mechanic) the the indications point me to a bad turbo. Or possible bad wastegate actuator. Possibly stuck open or something. I really don't know. If anyone can help out? It would be greatly appreciated.
Bottom Line: Car want boost. If it was the stock boost controller I know the wastegate should be roughly preloaded to lower psi. I've can my car on just wastegate before. I've run 7psi on the wastegate. That's on a TD04.
Help! Thanks! I do plan on working on it in the near just to check the wastegate and check a few more things. Possibly pull the turbo inlet off to check the turbo by spinning it.
Old 07-06-2013, 01:11 PM   #1036
blkbugeye
Member#: 287821
2005 WRX STi PSM
Im so confused.... what happened? lol
Old 07-06-2013, 06:01 PM   #1037
flippymcbean
Member#: 198546
2003 Evolution VIII
Lightning Yellow
Car won't boost....
Old 07-06-2013, 11:09 PM   #1038
blkbugeye
Member#: 287821
2005 WRX STi PSM
that sucks.....
Old 07-07-2013, 10:13 AM   #1039
flippymcbean
Member#: 198546
2003 Evolution VIII
Lightning Yellow
It does! I hate going slow!
Old 07-07-2013, 01:51 PM   #1040
blkbugeye
Member#: 287821
2005 WRX STi PSM
Old 07-08-2013, 10:46 AM   #1041
flippymcbean
Member#: 198546
2003 Evolution VIII
Lightning Yellow
Bug!!! Pick up the bug
Old 07-08-2013, 11:18 PM   #1042
blkbugeye
Member#: 287821
2005 WRX STi PSM
I would love to. I emailed both of them but havent gotten any replies
Old 07-08-2013, 11:27 PM   #1043
flippymcbean
Member#: 198546
2003 Evolution VIII
Lightning Yellow
Keep on keeping on. Did you tell them that your in the military overseas? That's grounds for scam. Hahaha. I can email them if you want. Let me know.
Old 07-08-2013, 11:31 PM   #1044
flippymcbean
Member#: 198546
2003 Evolution VIII
Lightning Yellow
Just texted him and he replied. I'm asking him to see if he can email you back. What's your email?
Old 07-09-2013, 02:35 AM   #1046
flippymcbean
Member#: 198546
2003 Evolution VIII
Lightning Yellow
I sent him your email. He said he hasn't received any emails.
Old 07-09-2013, 03:18 PM   #1047
Brown Ops
Member#: 291770
Java & satin black
Description:
Hey bro, I linked this onto the group on Wastebook. I just updated the post so hopefully someone will chime in with some advice. One dude said to do a hard reset on the car. Remove power from the battery and hold the brake pedal until the lights no longer light up to drain all of the power from the car. Then reconnect and see what happens. Dude said it could be an electrical issue. I personally doubt that but we can at least eliminate that possibility. Also, to use the AP you simply plug the AP into the OBD2 port under the steering wheel with the cable. Hopefully it is in the center console where I left it. There is no need to connect the green wires or anything like that. Thumb around the AP to find what you need to. It is pretty easy to navigate. Thanks again man.
Old 07-09-2013, 11:22 PM   #1048
blkbugeye
Member#: 287821
2005 WRX STi PSM
Havent got anything yet....
Old 07-09-2013, 11:44 PM   #1049
flippymcbean
Member#: 198546
2003 Evolution VIII
Lightning Yellow
Have you emailed him? I sent you his email via PM
Old 07-10-2013, 03:28 AM   #1050
blkbugeye
Member#: 287821
2005 WRX STi PSM
yea just did. I just saw it because the internet sucks
