Old 09-07-2002, 02:13 AM   #1
STEALTH-WRX
Member#: 7822
Multi layer snot green
Default if i run a link ecu can i remove my tvg's
i want to remove my tvg's. do i need my tvg's? i now have a 2.2 and i want as much air in the engine as possible. i a going to make an aluminum adapter to take place of the tvg's. will the motor function properly with out them. if the link will not work, what should i use. thanks in advance.
STEALTH-WRX is offline   Reply With Quote
Old 09-07-2002, 11:36 AM   #2
STEALTH-WRX
Member#: 7822
bump
Old 09-07-2002, 11:40 AM   #3
Blugin
Member#: 5270
2008 EvoX MR
Red
Yes! You can! I am running the link and "ported" tgv's with no side effects whatsoever. The link dosent even need them. It also dosent need a MAF...
Blugin is offline   Reply With Quote
Old 09-07-2002, 11:53 AM   #4
STEALTH-WRX
Member#: 7822
cool. thanks for the info.
DOHC heads running on SOHC ecu-CAN IT BE DONE!? turboL Built Motor Discussion 7 12-20-2006 02:47 AM
Can I remove my back seat without a chainsaw? Blew.by.u Western Canada 10 08-13-2006 01:34 AM
running avcs with link ecu??? scooby Engine Management & Tuning 8 12-19-2004 11:56 PM
OK, Can I remove my PS pump? (Was "What's a good basic UDP?") airengineer Normally Aspirated Powertrain 6 10-04-2004 04:07 PM
LINK ECU Questions, can I rid my car of a few things? STi_Pete Engine Management & Tuning 1 10-03-2002 12:42 AM
