#1 |
Member#: 54099
Vehicle:2010 WRX 5dr Satin White Pearl |
This is a difficult question to Google for, since I don't know which component is causing the failure.
I have a 2010 WRX with the factory navigation. It looks like this. I just bought a Sound Ordnance B-8PT subwoofer to put under the seat. When I got it all wired up, the amp would not turn on. I busted out my multi-meter. It shows power on the battery wire all the time and power on the remote turn-on wire when the deck is on. Exactly as it should be. I can't figure out why the thing won't turn on. To test it out, I took a bit of wire and bridged the battery wire to the remote turn-on terminal. Sure enough, the amp fired up and the speaker started working. That tells me the problem is with the remote turn-on wire. The only thing I can think of is that the deck isn't pushing enough amperage through the remote wire. I don't know exactly how to read my multi-meter, but the Battery wire is pushing a lot more current than the remote one. Does my hypothesis seem reasonable? Does anyone know if this is a common issue? I could try tapping the ACC wire off my stereo, or even pull from the cigarette lighter or something, but I'd really like to understand what's going wrong here before I start hacking something up.
#2 |
Member#: 335013
RMIC
Vehicle:2013 Premium WRX 5dr WRB |
Are you using the correct wire? Amp-on/REmote on should be pin 23 on your 24pin harness.
Code:
Pins Numbering
| Latch |
1 2 3 4 5 6 7 8 9 10 11 12
13 14 15 16 17 18 19 20 21 22 23 24
Code:
Pins Assignments Pin Function Car's Color --- ----------------------------- ------------ 1 NC — 2 NC — 3 Steering Wheel Controls + Brown 4 Parking Brake Grey 5 Reverse Gear Brown/Yellow 6 CAN Low (data bus) Light Green/Red 7 Forester only ** * 8 Video Input Ground Sealed (braided shield) 9 Aux input enable Black/Orange 10 Aux Input - Left Yellow 11 Subwoofer out - Audio Ground * * 12 Subwoofer out (in phase) * * 13 Video Output — 14 NC — 15 Steering Wheel Controls – Yellow 16 +12V Ignition (Run) Green/Yellow 17 Vehicle Speed Signal Pink/Green 18 CAN High (data bus) Pink 19 Video Output Ground — 20 Video Input Red 21 Aux Input - Audio Ground Sealed (braided shield) 22 Aux Input - Right Blue 23 Subwoofer out - Amp On * * 24 Subwoofer out (inverted) * * |
#3 |
Member#: 54099
I will double check that. I'm using a harness made by someone here on the forums, and I'm simply using the label he wired as 'Remote turn-on'. However, that wire is Blue, which according to your chart is not the right wire (unless the colors don't match up, I'm not sure).
#4 |
Member#: 54099
Damn, I just double checked and yes, that's the wire I'm using.
#5 |
Member#: 32452
Vehicle:1998 Impreza Turbo 74F FTW |
Maybe the wire puts out enough amps/volts to trigger a standard or solid state automotive relay.That way the amp will turn on/off together with the radio.
It's quite a crude fix, but is may be the best option. |
#6 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
A turn-on wire isn't supposed to supply a large amount of current. It only supplies the voltage as a signal to turn the device (amp etc) on when needed.
Are you sure that is actually a turn-on? Typically the OEM systems don't have one, I know for sure the older ones don't and you have to use the ACC circuit. |
#7 |
Member#: 335013
RMIC
Lets me confirm a few things with you.
Are you talking about the Kenwood OEM Navigation HU? http://img683.imageshack.us/img683/729/subarunavihu.jpg And who harness did you get from? I would just check from the connector coming from your car. Look at the pin numbering and find pin 23. Make sure it is matching that blue wire on the harness you bought. Also this might sound dumb but do you actually have a power source coming to the sub? Powered sub doesn't mean it'll power itself. You still need to run power source to it. The Remote on is just to let the amp in the sub know that the radio is on so it should turn on too. |
#8 |
Member#: 345079
Vehicle:13 Wrx sedan PWM |
He said in the first post that he has power on both the battery and remote lines. The interesting part is getting it to fire up with the jumper wire, even though you have 12v on the remote line.
Does the sub have signal sensing turn on? Some amps will turn on when they receive an audio signal, which makes it easier to integrate into stock systems. I wonder if you need to turn that off somehow? Other than that I'm with Dutch. Get a small 12v relay and see if the remote line has the juice to trigger it. |
#9 |
Member#: 266122
Vehicle:2007 WRX Limited |
Measure the current it takes to turn on the amp. The amp might have a bad signal input.
#10 | |
Member#: 335013
RMIC
#11 | ||||||
Member#: 54099
Sorry for the multi-quote response here...
![]() Quote:
![]() Quote:
EDIT: I just noticed that the forum software takes random text in people's posts and makes it into a marketing link. That explains why people missed the stuff I linked in the OP. They're probably trained to ignore random links in posts! Sorry for the confusion guys. Last edited by syphon; 05-09-2013 at 02:31 PM. Reason: I think I figured out why people missed some of my info from the OP |
#12 |
Member#: 25837
South East
Vehicle:1996 SVX L AWD Laguna Blue Pearl |
syphon- You're using my "Navi transplant" harness, right? (for a car that originally shipped with a non-nav OEM HU). Did it have the RCA jack for the Navi's subwoofer audio output, or just plain wires?
The wire colors in luan87us's post #2 are the factory wire colors for 2008-up Impreza/WRX/STI. Since your car didn't ship with a Navi, you don't have those wires. The colors on my transplant harness are different. My amp remote turn-on should be BLUE/WHITE, with printing on the wire that says that. Is that not the color on pin 23? Many people have successfully added an B-8PT to the OEM Navi, connecting to the HU's line-level sub out and remote turn-on. Two things you can check:
If your Navi's remote turn-on output is bad, you can instead use the HU's power antenna remote turn-on (pin 14 into the Navi's 14-pin power/speaker socket). That wire should be BLUE (with printing that says "power antenna"). ADDED: On the Subaru OEM Kenwood Navi HUs (unlike all other Subaru HUs that I know of), the power antenna lead is left 'on' the entire time the HU is on. On all other models, the HU shuts off the power antenna lead when you switch to CD, aux, USB, sat radio, etc. Last edited by SVXdc; 05-13-2013 at 09:36 PM. |
#13 |
Member#: 54099
Yep, I'm using your wiring harness. The wire I'm connected to is labeled by you as 'amp turn on' and matches to pin 23 on the wiring diagram above. I'm pretty certain it's the correct wire. I'll fiddle around with the multi-meter to see what I can find, and will consider using the antenna wire if that fails.
#14 |
Member#: 335013
RMIC
Oooh you never said you used the transplant cable lol. That's why I thought it was weird you're using a blue cable. But yeah good luck finding the problem. Hopefully you'll get your sub working soon. SVXDc is a great guy and I think with his help you will be able to figure this out.
#15 |
Member#: 266122
1. Switch the meter to the current measuring function.
2. Connect the meter leads to the current inputs (The common usually doesn't change but the plus input does). 3. Connect the meter in series with the wire you want to measure the current in. 4. Turn on the system and read the current. |
#16 | |
Member#: 54099
Thanks for your help, everyone! |
#17 |
Member#: 66859
Vehicle:2008 STi Hatch Aspen White |
I have the exact same problem! I just installed a 08 OEM nav into a 08 non-nav sti and was also connecting the sound ordnance subwoofer.
And the most puzzling part is, the sub was working great a day before. After I finished installing the sub, I started to install backup cam and tapping the VSS, reverse signal, grounding the parking brake wire ...etc and everything worked great. However, today, as I was driving home, I noticed that the subwoofer stopped working. I fiddled with all the connections and make sure things are connected properly. I measured the voltage across the subwoofer's '+' and '-' terminals and got 12v. But when I measure the voltage aross the remote amp turn on terminal and the ground, I only get 3V. I got the same 3V reading at the HU's remote turn on wire out. I will go and try tapping into that other wire tomorrow. Hopefully, it will fix my problem too. |
#18 |
Member#: 25837
South East
I recommend that you measure how much current that sub draws on its remote turn-on input. For your test, connect to the +12V Battery lead (yellow wire on my harness), connecting your meter as I describe above.
If the B-8PT does draw too much, it could eventually blow the transistor that drives the Navi's power antenna pin too. So it may be better to connect the sub to +12V Accessory (tap into red wire on my harness). What voltage does the Navi's pin 23 measure with nothing else connected? |
#19 |
Member#: 324618
Vehicle:2008 STi DGM |
Hi SVXdc,
I don't mean to hijack the thread, but I needed to contact you, and I couldn't find an email address and I couldn't message you over the forum. Can I have your email so I can get some help with buying a harness from you? I need some clarification... |
