#1 |
Member#: 246851
SCIC
Vehicle:2007 UGM 2012 LR |
I notice when I first start my car I hear a loud, suction type of noise that lasts for maybe 10 second then the car gets quieter.
I am trying to figure what that is from, because there is some other weird noise when I roll away and I think it may be associated with it. PS: 2012 WRX
#2 |
Member#: 122167
Vehicle:07 Acura TL TypeS Kinetic Blue Pearl |
I believe the newer boxer motors have an air pump. That maybe the noise you hear upon startup.
#3 |
Lil' Ron
Moderator Member#: 140114
Vehicle:06 18G Semi Built SGM WRX |
Without a video it's hard to pinpoint. Subaru's are noisy. It could be the fuel pump, it could be almost anything. You really don't hear the air pump, and they do not always run during startup.
#4 |
Member#: 246851
SCIC
Could be the fuel pump, sounds more likely. It gets pretty dead quiet and all I hear is the engine idle after 10 seconds or so.
The reason I am asking is because I sometimes hear a metal scratching noise, and sounds like it's spinning at the same time when I take off slowly. I am hoping it is not the bearing because the car drives great and I am not hearing a loud vibration or humming noise at high speed like I would if it was a bad bearing. And I doubt it's anything with the clutch...I had the passanger side bearing replaced few month ago because I slid into a guard and that was obvious. The wheel was wiggly when lifted. |
#5 |
Member#: 295846
Vehicle:WRX FP HTA GT3076R Sexual Chocolate |
Air pump
#6 |
Member#: 275250
NWIC
Vehicle:2006 WRX White |
I second the air pump. When they start letting go, they can make a bit of noise. Mine is at that stage right now.
#7 |
Member#: 69300
Vehicle:2012 WRX WR Blue Pearl |
Could it be the ABS self-check? Every time the car starts, the ABS system goes off as a diagnostic...sounds like the "scratching" noise you're hearing. Happens every time I get the car moving after starting it up.
#8 |
Member#: 246851
SCIC
That sounds like it too, the noise sounds like a hollowed grinding like "dunnnnnn, dunnnnn" as I roll off the first 2 seconds...but does it sound like metal..?
#9 |
Member#: 69300
Like others have indicated, it would be tough to pinpoint the sound without a video of some sort, but I do know that my car produces a sort of grinding sound for a very short duration when getting it going after starting, which is due to the above mentioned ABS check.
#10 |
Member#: 246851
SCIC
But I hear it not only at intital start but during in between on/offs as well. And I tend to hear it everytime I'm in some kind of covered drive thru...lol
#11 |
Member#: 311865
SCIC
Vehicle:2005 Subaru Silver |
Here is your answer =
It is your air pump. You will hear the drone from the pump and the thudding sound in the cylinder heads and intake. |
#12 |
Member#: 245218
South East
Vehicle:2013 STI Limited Ice Silver |
air pump
#13 |
Member#: 258165
NWIC
Vehicle:2006 WRX Wagon WRB |
It's the air pump!
#14 |
Member#: 36788
Vehicle:2012 WRX hatch |
My air pump sound presents itself as a loud rattling sound coming from the exhaust after a cold start. Sounds really like a loose heatshield or something under the car or inside the muffler. Stops when the air pump turns off after a minute or so, or if I blip the throttle a bit to rev the engine gently. I have a 3" exhaust with the stock muffler (2012 hatch) so I'm hoping this is normal. Is this what others have heard when talking about the air pump noise?
#15 |
Member#: 190566
Not sure if it was mentioned yet but "air pump".
#16 |
Member#: 219162
Vehicle:2011 WRX Sedan Base Silver |
Something that might pump air?
#17 |
Member#: 204358
SCIC
Vehicle:01 2.5RS W/ EJ257 Black |
To all the morons who posted "it's your fuel pump"... you kids are buckets of stupid.
plz stop posting. |
#18 | |
Member#: 262992
NWIC
Vehicle:2009 wrx pearl white |
#19 |
Member#: 36788
Thank you. It's so alarming I'm surprised there isn't more discussion about it on various forums. Faark it's loud! And also surprising that a downpipe and midpipe, which barely makes the exhaust louder when driving can amplify this sound so much compared to the stock exhaust. It would be good if there was a way to disable it with an ecu tweak rather than having to remove it if you want to get rid of it.
#20 |
Member#: 231315
Vehicle:06 WRX Wgn Black |
LOL :-) My air pump sounds like shictz
#21 |
Member#: 219162
#22 |
Member#: 36788
Interesting. So I assume the valves are closed when the engine is warm, correct? Also will the CEL keep coming back once cleared? Will the engine run rough or are there any other negative side effects?
#23 |
Member#: 219162
Warm = closed. CEL codes will have to be erased by a tweak of your ECU. No side effects to performance/mpg/etc, your cats will just be inefficient on start-up which is a moot point if you are now running with a catless DP. Read the Air Pump Delete thread(s)
#24 |
Lil' Ron
If you "tune out" or turn them off via a tune, they will not come back. If you simply pull fuses, they will stay on. The air pump is for emissions only, and DO NOT RUN AT EVERY START UP. (Some people, especially in here seem to forget this) It does not affect how the motor runs. There is an entire thread about removing the air pump on 06+ motors, read it.
#25 | ||
Member#: 36788
